About BLE advertising and sleep system ON mode in Ble_App_Uart
 I am build an application with features : When I not used nRF it imediately in sleep mode and be wake up by BLE events to send some text, and return to sleep mode ( the reson why I choose system On sleep mode).
1. So I think my nRF make sure
-> advertising continuosly in sleep mode (because my phone will connect to nRF anytime to wake nRF up and send text)
2. To make nRF advertisin continously I did
- set the flags   // init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE => BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; to disable advertising timeout
- in BLE_ADV_EVT_IDLE  I commented sleep_mode_enter();, and call ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST); to restart advertising
    uint32_t err_code;
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
    case BLE_ADV_EVT_IDLE:
        NRF_LOG_INFO("call idle");
        //sleep_mode_enter();
3. To wake up nRF I debug the NRF_LOG_PROCESS() in debug terminal this is 'true' when I connect to device or send some data from  mobile phone to nRF
-> so I think nRF was wake up in these BLE events
4. What is the different between ble_idle and ble_timeout ?  In idle mode can nRF advertising and my phone can connect to it ?
5. Does such continuous advertising make nRF consume a lot of energy? Can you suggest me some another ways ?
my main loop()
    // Enter main loop.
    for (;;)
        idle_state_handle();
        NRF_LOG_INFO("%d", NRF_LOG_PROCESS());
        nrf_delay_ms(200);
the rest of code is similar ble_app_uart ().
Please answer for me 5 above questions. Thank you !
  • Hi Karl, I'm back after weekend  :))
    When the device is in SYSTEM_ON sleep it means that the CPU is in the low-power sleep, but able to wake up to process any incoming events (like an upcoming advertising event), while peripherals may still function as usual. That is to say, the SAADC can for example be sampling while the CPU is sleeping since it does not require CPU interaction to do so. Likewise peripherals like TIMER and RTC can still run while the CPU is sleeping and the device is in SYSTEM_ON sleep.
    I have 2 questions for this quote
    In SYSTEM_ON sleep mode, in my case my nRF will advertising continuosly. (not BLE timeout, not BLE idle) so I means I checked that when my nRF call idle_state_handle(), it's still advertising, receiving data from mobile phone via BLE and send to UART. So Is nRF actually sleeping when it's advertising like that ?
    I measure  the current consumption it show 1.5mA. I disable my loggger ? Does Uart cause this problem ?
    Here is my main.C and skd_config.h
    6153.sdk_config.h
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #if defined(UART_PRESENT)
    #include "nrf_uart.h"
    #if defined(UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME "Nordic_UART_XFinder"                /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION 6000//18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    //#define APP_ADV_DURATION 0//18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)    /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)    /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY 0                                      /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
    int testRamRetention = 5;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                         /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                           /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);               /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;               /**< Handle of the current connection. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[] =                                      /**< Universally unique service identifier. */
            {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name)
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t err_code;
        ble_gap_conn_params_t gap_conn_params;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        gap_conn_params.slave_latency = SLAVE_LATENCY;
        gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    static void nus_data_handler(ble_nus_evt_t *p_evt)
    NRF_LOG_INFO("Received data from BLE NUS. Writing data on UART.");
            uint32_t err_code;
    NRF_LOG_INFO ("Received mobilephone.");
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY)
        uint32_t err_code;
        ble_nus_init_t nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
    static void on_conn_params_evt(ble_conn_params_evt_t *p_evt)
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        uint32_t err_code;
        cp_init.p_conn_params = NULL;
        cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
        cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
        cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
        cp_init.disconnect_on_fail = false;
        cp_init.evt_handler = on_conn_params_evt;
        cp_init.error_handler = conn_params_error_handler;
        NRF_LOG_INFO("call sleep_mode_enter");
        // Prepare wakeup buttons.
        uint32_t err_code;
    static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context)
        uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
        case BSP_EVENT_SLEEP:
            NRF_LOG_INFO("bsp_event_sleep");
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
    void uart_event_handle(app_uart_evt_t *p_event)
        static uint8_t index = 0;
        uint32_t err_code;
        switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
        uint32_t err_code;
            .rx_pin_no = RX_PIN_NUMBER1,
            .tx_pin_no = TX_PIN_NUMBER1,
            .rts_pin_no = RTS_PIN_NUMBER,
            .cts_pin_no = CTS_PIN_NUMBER,
            .use_parity = false,
            .baud_rate = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        uint32_t err_code;
        ble_advertising_init_t init;
        init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
       // init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.srdata.uuids_complete.p_uuids = m_adv_uuids;
        init.config.ble_adv_fast_enabled = true;
        init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    static void buttons_leds_init(bool *p_erase_bonds)
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
          //  NRF_LOG_INFO("call Sleep ON"); => khi không có vi?c g? th? l?p t?c nh?y vào sleep ON
          //  ki?m tra nrf_log_process() == false
          //  ch? c?n có s? ki?n ng?t g? Ä‘ó như truy?n uart qua th? s? t?o ng?t và cho wakeup
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        log_init();
        // Initialize.
        uart_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            //NRF_LOG_INFO("%d", NRF_LOG_PROCESS());
            //nrf_delay_ms(200);
    So am I! :)  - I hope you had a great weekend!
    Yes, your device will then enter SYSTEM_ON sleep in between every advertisement, and then wake up whenever an advertising event is upcoming so that it may process it, and then go back to sleep.
    Currently your advertising interval is 40 ms, which means that your device will wakeup to advertise every 40 ms. Since you are doing indefinite advertising it may be advisable for you to increase this, since this will have a high current consumption.
    Is there any requirements or constraints for your application on how fast it needs to be able to establish a connection?
    Logger and the UART consumes a lot of power, yes. It seems that you have unabled the logger, but the UART peripheral is still enabled an in use in your application.
    Karl
  • Hi Karl,
    1. In sleep ON mode, can my MPU6050 is still active ?. How can I set that. I want to use my MPU6050 to wake my nRF up
    My temporatity idea is using MPU6050 interrupt, but I got the problem if MPU6050 active it will generate the interrupt continously => it's bad idea.
    2. In system ON, can I using timer to wake nRF up => can you suggest for me the example about this topic. Im very appriciate about that.
    3. I want to turn off uart dma (libuartes) to save enegry. Can I do that ?
    4. In main loop
    After idle_state_handle().
    I have to handle some event will be sent via BLE (in this case is set checkBuzzer = true).
    I have some confusions about this problem when handle some applications, events after idle_state_handle() whether it afffect to my sleep mode ?
        for (;;) {
          while(checkBuzzer == true){
            for (uint8_t i = 0; i < 40; ++i)
                value = (i < 20) ? (i * 5) : (100 - (i - 20) * 5);
                ready_flag = false;
                while (app_pwm_channel_duty_set(&PWM1, 0, value) == NRF_ERROR_BUSY);
                while (!ready_flag);
                APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, value));
                nrf_delay_ms(25);
           if(checkBuzzer == false){
              while (app_pwm_channel_duty_set(&PWM1, 0, 100) == NRF_ERROR_BUSY);
    Maybe it seems unrelated to this topic but I have a bunch of sleep mode confusions. Thank you for your help
  • Hello again,
    Yes, your MPU6050 (or other external IC) can still be active while the nRF sleeps, and then wake the nRF whenever it is needed.
    Exactly how you implement this with the MPU you will have to check with the MPU datasheet, but in essence you can use it to wake the nRF if you are able to send it an interrupt signal.
    You can read about the different ways to wake the nRF52833 in the SYSTEM_OFF documentation.
    Unfortunately, I have no personal experience with the MPU6050, and since it is not a Nordic product it is not something we support here in the forum, so I can not advice you on how to best implement this in your MPU6050.
    Perhaps there is a separate forum that supports development with the MPU6050?
    You can see the ble_app_uart BLE peripheral example for a demonstration on how to enter SYSTEM_OFF mode, and prepare to wake up on a button press (or external interrupt).
    This process starts as part of the advertising BLE_ADV_EVT_IDLE event handling.
    You may turn off (disable + uninitialize) any unused peripheral to save power, yes.
    Most of the nrfx drivers will have a separate function for stopping the peripheral, and one for disabling/uniniting the peripheral.
    The program will not return from the idle_state_handler until an event has been generated, and that event has been handled. It is therefore impossible to know when the piece of code that you place next to the idle_state_handler will execute, since you do not know which event it is handling before executing it.
    I would recommend that you place the BLE packet queueing into the appropriate event's handling instead.
    If you have further questions about this that diverge from the original ticket it would be best if you opened a separate ticket for these questions. This will keep the forum tidy and easy to navigate, while we may work on the two issues / tickets in parallel.
    Karl
