Can I download new image in the place of application ?
As per DFU concept the image management command handlers makes it possible to uploadlisttest and confirm the image(s), while the OS management command handlers makes it possible to reset the chip (and run the echo command). Since the DFU support is added to the application, the chip needs to be reset, to give control to MCUboot, which will validate the new uploaded image and swap it with the old image.
But I want to erase old image 1st then download new image using DFU because my application is occupy 90 % of memory so vacant space is not available to download new image and it is hard to add external flash memory because hardware design is completed.
How to do it ?
Any settings is there to do so.
Thanks ,
ram
  • Hello Einar,
    Thanks for your support .
    Ram
  • Hello Einar ,
    Another clarification I want to know .
    My bootloader is secure_bootloader_ble_s132.
    And by this I updated my application ble_app_blinky_s132 via nrf_connect app from mobile.
    So bootloader is always there placed in starting address of flash .Again I put in it bootloader mode and want to update a new application lets ble_app_beacon_s132.
    And I want to new application should overwritten in the place of old application ble_app_blinky_s132.
    It is not possible via Bluetooth bootloader?
    Thanks ,
    Ram
  • Hi Ram,
    Earlier you were describing MCUBoot and SMP server etc. All I have stated before applies to that bootloader, and this is what is used with the nRF Connect SDK.
    What you are describing now is the secure bootloader from the nRF5 SDK. This is a completely different bootloader, that has nothing to do with MCUBoot, SMP server etc. This is a completely different bootloader where the transport is in the bootloader, so things are very different. In the nRF5 SDK bootloader, you can have only a single application bank, and updates via both serial and DFU can work without the need for flash space to store another application image. In fact, you do not need any additional space at all, as long as you can fit the Bootloader, MBR, application and bootloader settings page (and optionally MBR params). For Bluetooth, you also need the SoftDevice.
    To understand the nRF5 SDK bootloader is recommend Getting started with Nordic's Secure DFU bootloader, a step by step guide. You should also refer to the bootloader examples and bootloader modules documentation.
    Key question: Which SDK version are you using? If you are using the nRF5 SDK, then the nRF5 SDK bootloader is what you should use, and this supports what you have requested. But please discard all you have read about the MCUBootloader, both the documentation you linked to an all discussion here. That has absolutely no relevance for the nRF5 SDK bootloader.
  • Hello Einar ,
    So summary of discussion is if I want overwrite application upgrade via OTA,I should use nRF5 SDK bootloader.
    nRF Connect SDK bootloader via OTA is not support overwrite .
    Right ?
    Ram
