Hi Sir/Miss,
In original project, I use nRF52810. But, it's not enough flash in our customer adding requirements.
Therefore, I want to migrate project from nrf52810 to nrf52832_XXAB in IAR.
I still use SoftDevices 112 and SDK 17.0.2.
I remove original files (iar_startup_nrf52810.s and system_nrf52810.c) and add iar_startup_nrf52.s and system_nrf52.c file in project.
And, setting ROM and RAM in linker script. (ROM end: 0x3FFFF, RAM end 0x20007FFF). The begin of memory is same as before.
To add NRF52 and NRF52832_XXAB are in define symbols (Both of them are in Assembler and C/C++ Compiler). Also, I remove NRF52810_XXAA in define.
I don't change stack/Heap size, they're still 2048.
After compiler, IAR displays Fatal Error[Pe035 ]#error directive: "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)" in core_cm4.h
__FPU_PRESENT is set to 1.
I see this article and follow it to include "nrf52.h", "arm_const_structs.h" and "arm_math.h"".
But, the result is same.
Do I miss something else?
Please help to solve it.
Thank you.
