bootloader project in nCS
1. Is bootloader file and firmware file, different for projects build on nCS..?
    Or a single executable build file consists both bootloader & firmware..?
2. Can you suggest a sample program to build a bootloader project..?
    Ubaid_M said:
    1. How does how does the image boot if I have not enabled CONFIG_BOOTLOADER_MCUBOOT=y..?
    Then there is no bootloader. The application will be located at 0x00.
    Ubaid_M said:
    Some preexisting bootloader does the job or if system does not find anything at the address,
    no. See 1.
    Ubaid_M said:
    3. Can you please suggest if this "BOOTLOADER_MCUBOOT" checks for firmware file image code signing before booting the image..?
    Yes it does.
    Ubaid_M said:
    4. If it does, how does it use the key for code signing check on the firmware file..?
    It uses a default key, which you should see when you compile. Some message saying that this is a default key which should not be used for production, and that you should change it.
    Ubaid_M said:
    5. How can I update this key..?
    I believe it says in the same warning.
    Edvin
  • Thank you ,
    It is clearer now.
    Now if I want to generate a private key and add it into the MCUBOOT, what process do I follow..?
    Please suggest.
    Thanks
  • Please see this link on how to generate new key pairs.
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/tfm/docs/technical_references/design_docs/tfm_secure_boot.html#second-stage-bootloader-in-tf-m
    There is also a Kconfig definition
    CONFIG_BOOT_SIGNATURE_KEY_FILE (described as "config BOOT_SIGNATURE_KEY_FILE" in NCS\nrf\modules\mcuboot\Kconfig) where you can set the absolute path of the key file that you have generated.
    Edvin
  • Hello ,
    Thank you for the suggestion, it helps.
    Further, I understand the usual way mcuboot works with SLOT-0, SLOT-1 & SCRATCH memory locations towards swapping of images for firmware update.
    I want to customize a few things here,
    1. I want to map SLOT-1 & SCRATCH memory locations to external serial flash locations.
    2. I want to provide mcuboot SPI interface APIs to interact with external flash.
    So, for the above 2 requirements, kindly suggest how and where I can tweak & build the mcuboot source code.
    If any sample is available wherein mcuboot source code is modified, it would be great.
    Ubaid
    What chip are you using? I believe it is possible to offload this to an external QSPI flash chip by using CONFIG_NORDIC_QSPI_NOR=y. Without knowing the details, perhaps you can look into what this does, and try to implement something similar using SPI.
    The MCUBOOT bootloader project is located in ncs <vX.Y.Z>\bootloader\mcuboot.
    BR,
    Edvin
