I want to add a random delay in range 2000 to 3000 ms before my device perfrom any activity.
pls tell how can do this at earliest
usins some timer or something else
Hakon i added:
1). defined insatnce:
APP_TIMER_DEF(m_my_timer_instance);
2). created a single shot timer in timers_init():
err_code = app_timer_create(&m_my_timer_instance,
APP_TIMER_MODE_SINGLE_SHOT,
sensor_timer_handler);
3). now i am not getting how to use this shared by you:
uint16_t rand_value;
uint8_t bytes_available = 0;
(void)sd_rand_application_bytes_available_get(&bytes_available);
if (bytes_available >= sizeof(rand_value))
err_code = sd_rand_application_vector_get(&rand_value, sizeof(rand_value));
} else {
/* implement your error handling if no rand bytes available */
err_code = app_timer_start(m_my_timer_instance, APP_TIMER_TICKS((rand_value % 1000) + 2000), NULL);
as i dont know how to use it in handler, also i have to add this timer before timer used in line 357 of my code.
pls hlp
gentle reminder
Hakon pls assist at earliest
Could you please explain what is the issue that you are seeing?
Håkon
1). in line 158: i have added
2). in line 573: i have added
battery_level_meas_timeout_handler);
3). i aim to add a random delay before the repeated timer of line 374 starts.
as suggested by you: in line 357 i have added
} else {
4). i am getting error as shown in pic
5). i am not able to add the random delay
