NRF_FAULT_ID_SD_ASSERT @PC 0x15074
I'm having an error in my project where the app_error_fault_handler(...) is triggered generating an NRF_FAULT_ID_SD_ASSERT. I've overwritten the function and stored the ID and PC which is 0x01 (NRF_FAULT_ID_SD_ASSERT) and PC@0x15074.
My Hard- & Software setup:
  • nRF52840-DK (PCA10056)
  • nRF5 SDK v17.0.2
  • S140 v7.2.0
  • FreeRTOS v10.0.0
In my setup I have
  • 24 development boards,
  • connected to 4 different masters -
  • so each master hast to handle 6 devices.
  • The connection interval is fixed @100ms.
I don't know whether the amount of boards is related to the error; maybe only because of more BLE traffic in the area. Unfortunately the error is not quite easy to reproduce and only occurs ever 1-2 days at some boards (different, not the same).
From this post I've learned, that the error can be caused of the application code blocking the softdevice: devzone.nordicsemi.com/.../s140-7-2-0-assert-pc-0x15074
But I've already checked my critialSections and hardware interrupts; I only have one GPIO ISR, with a priority of: GPIOTE_CONFIG_IRQ_PRIORITY 6.
So what kind of code sections can cause such an error?
Is it possible to get more information about the error. I now know the ID and the PC; the "info" field of the app_error_fault_handler(...) unfortunately is 0x00. If I assume that the error is cause from my application code, it would be very helpful to know the function, task or interrupt which caused the error.
I appreciate any kind of help,
Manuel
  • On multiple boards but not always after the same uptime. Sometimes the reset occurs after several days and sometimes after one day. The picture shows a list of the boards and the uptime. Each blue marked line was an assert reset. The DFU update was made 13 days ago.
    It really looks like its a timeslot error, cause more BLE devices in the area means lesser timeslots right?
    On the other hand; I've changed a bit of application code (using FreeRTOS functions like xQueueSend & xQueueSendFromISR) and I think the reset was not that often than before.
    So to clarify:
    Could it be something from within the FreeRTOS, some criticalSections which are called there? Let's say its a critialSection; can I then add some debug features or something to get more that the PC of the error there?
    For the clock:
    I've just updated the boards with the synthesized clock; we will know more tomorrow.
    I see. Combined with the fact that you use the crystal on the DK I think we can almost rule out clock drift as a cause. But It will anyway be interesting to see the results tomorrow.
    Yes, that is true. The more connections, the less time for other things. So if you use radio timeslots, you will get fewer and/or shorter time slots with increasing number of connections.
    That is interesting. What exactly did you do, and what happens if you revert this (just for comparison)?
    That could be. If there are too long critical sections, then this assert can happen. Basically anything that prevents the SoftDevice for doing what it needs within defined timeouts, can cause this.
    You can try to look at the stack trace, but the assert will not happen until the SoftDevice runs, so if it was caused by some application code blocking for too long that will have already happened. It could also be from an interrupt and not a critical section, so what you will see and the usefulness of it depends on what has happened. It is worth checking, though.
