NCS 1.9.1 unable to use PSA crypto methods with OpenThread enabled
I'm unable to use the PSA crypto methods when OpenThread is enabled on NCS 1.9.1. Linking fails with undefined references to PSA crypto methods.
To reproduce, us the nrf/samples/crypto/aes_cbc example, and add the following to prj.conf:
CONFIG_NETWORKING=y
CONFIG_NET_L2_OPENTHREAD=y
Building for the nrf52840dk_nrf52840  yields errors:
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/build/zephyr/zephyr_pre0.map
: && ccache /home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/arm-zephyr-eabi-g++   zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/newlib/liblib__libc__newlib.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/net/l2/openthread/libsubsys__net__ip__l2__openthread.a  zephyr/subsys/net/ip/libsubsys__net__ip.a  zephyr/subsys/net/lib/openthread/platform/libopenthread_platform.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/ieee802154/libdrivers__ieee802154.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a  modules/nrf/subsys/ieee802154/lib..__nrf__subsys__ieee802154.a  modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a  modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a  modules/nrf/drivers/mpsl/temp_nrf5/lib..__nrf__drivers__mpsl__temp_nrf5.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/hal_nordic/nrf_802154/libnrf-802154-platform.a  modules/nrfxlib/nrf_802154/nrf_802154/driver/libnrf-802154-driver.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/libmbedtls_zephyr.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v7e-m/nofp"  -L/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  modules/hal_nordic/nrf_802154/libnrf-802154-platform.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/nrf_802154/sl/sl/lib/nRF52840/soft-float/libnrf-802154-sl.a  -no-pie  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -lm  -Wl,-lc  -L"/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v7e-m/nofp  -Wl,-lgcc  -specs=nano.specs  modules/openthread/build/src/core/libopenthread-ftd.a  modules/openthread/build/third_party/tcplp/libtcplp.a  modules/openthread/build/src/core/libopenthread-mtd.a  modules/openthread/build/src/core/libopenthread-ftd.a  modules/openthread/build/third_party/tcplp/libtcplp.a  modules/openthread/build/src/core/libopenthread-mtd.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/mpsl/lib/cortex-m4/soft-float/libmpsl.a  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedtls.a  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedx509.a  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_psa_crypto_0.9.13.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_mbedcrypto_0.9.13.a  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_psa_crypto_0.9.13.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_cc310_mbedcrypto/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_mbedcrypto_0.9.13.a  -lc  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_psa_3.0.10.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_mbedtls_3.0.10.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/soft-float/liboberon_3.0.10.a  /home/zcornelius/code/nrf-base/ncs/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.13.a  modules/nrfxlib/nrfxlib/nrf_security/src/libmbedcrypto_base.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -lc && cd /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/build/zephyr && /usr/bin/cmake -E echo
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `crypto_init':
/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:56: undefined reference to `psa_crypto_init'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `crypto_finish':
/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:68: undefined reference to `psa_destroy_key'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `generate_key':
/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:95: undefined reference to `psa_generate_key'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:102: undefined reference to `psa_reset_key_attributes'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `encrypt_cbc_aes':
/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:118: undefined reference to `psa_cipher_encrypt_setup'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:125: undefined reference to `psa_cipher_generate_iv'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:132: undefined reference to `psa_cipher_update'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:141: undefined reference to `psa_cipher_finish'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:155: undefined reference to `psa_cipher_abort'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `decrypt_cbc_aes':
/home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:169: undefined reference to `psa_cipher_decrypt_setup'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:176: undefined reference to `psa_cipher_set_iv'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:183: undefined reference to `psa_cipher_update'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:192: undefined reference to `psa_cipher_finish'
/home/zcornelius/zephyr-sdk-0.13.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /home/zcornelius/code/nrf-base/ncs/nrf/samples/crypto/aes_cbc/src/main.c:214: undefined reference to `psa_cipher_abort'
