Increasing MTU ATT to 1020 bytes generates a CMake error
Using the central and peripheral uart samples I have found the following CMake error when trying to increase the MTU ATT to 1020 bytes.
The added lines to the prj.conf are:
CONFIG_BT_BUF_ACL_RX_SIZE=1024
CONFIG_BT_BUF_ACL_TX_SIZE=1024
CONFIG_BT_L2CAP_TX_MTU=1020
#CONFIG_BT_CTLR_DATA_LENGTH_MAX=1024
The CMake error as follows:
CMake Error at C:/v1.8.0/v1.8.0/zephyr/cmake/kconfig.cmake:270 (message):
  command failed with return code: 1
Any help?
Thanks
  • It is a hardware specific limitation - at least that is what I read from the RADIO peripherial specification. A TX packet can only be up to 255 bytes in length - that register has only 8 bits.
    I'm pretty sure you could configure the zephyr BT stack for supporting a RADIO with a larger possible TX packet size, but I don't see this possible with currently available NordiSemi chips that I'm aware of.
  • Thanks, Turbo and Torbjørn,
    One final query. Is it possible to set to CONFIG_BT_L2CAP_TX_MTU=1020 and get the ble stack to split the messages? If yes, how?
    Zephyr specified that CONFIG_BT_L2CAP_TX_MTU can be configured up to 2000.
    docs.zephyrproject.org/.../CONFIG_BT_L2CAP_TX_MTU.html
  • Hi Jörg
    This is both a Bluetooth specification limitation and a hardware limitation (the hardware being designed with the Bluetooth specification in mind).
    For details please refer to Vol 6, part B, chapter 2.4 of the Bluetooth 5.2 specification, in particular this section regarding Data Physical Channel PDU packets (normal packet format in a connection):
    The Length field of the Header indicates the length of the Payload and MIC if
    included. The length field has the range 0 to 255 octets. The Payload shall be
    less than or equal to 251 octets in length. The MIC is 4 octets in length.
    In other words the payload is limited to 251 bytes, and when sending data through ATT you lose 4 bytes for the link layer header and 3 bytes for the ATT header, leaving you with 244 bytes maximum for attribute data.
    The radio hardware allows up to 255 bytes total (not including preamble, header, address or CRC) in order to handle a 251 byte BLuetooth payload plus the 4 byte MIC.
    Higher level protocols such as ATT or L2CAP allow you to send longer packets, but they will be fragmented by the link layer to fit in 251 bytes or less.
    Best regards
    Torbjørn
  • Hi Armand
    This should be possible, yes, but using L2CAP connection oriented channels is not a very common way of sending data over BLE. Then you bypass the entire ATT and GATT layer, which means you can't use normal BLE services.
    Are you sure this is what you want to do?
    Could you give me some information about the application you are working on, and what kind of devices you want to connect?
    Do you have Nordic devices on both sides of the link, or do you want to connect to other devices like phones or PC's?
    Best regards
    Torbjørn
  • Nordic devices on each side. I think I will manually split the messages for now. I just wanted to understand why CONFIG_BT_L2CAP_TX_MTU  can be set up to 2000 on the zephyr specs. Any hint?
