Power consumption increased after DFU implementation
we have a zephyr application on nRF52832 DK with nRF Connect for vscode
Before we added DFU support, we had a power consumption of 28 uA
After adding DFU support, power consumption increased to 8.9 mA
We want to reduce power consumption. What can we do for it?
Best regards
  • I was measuring 28 uA on the custom board before adding dfu support. I turned on the UART peripheral for DFU support to work. After doing these, the current value I measured on the custom board came out as 3.2 mA. When I'm not going to use the dfu support, I also disable the UART peripheral at runtime, so I'm measuring 1.7 mA. I need less power consumption in my application. Can I stop dfu support at runtime when I don't need it for that? Or do you have a suggestion for less power consumption?
    Best Regards,
  • I suspect that the issue may be that the pins on the UART is not disconnected properly. Can you try to put the GPIOs in a disconnected input state (the default power on reset state) after you disable the UART?
    To test it (quick and dirty), try to just write directly to the register:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/gpio.html?cp=4_2_0_19_2#topic
    Assuming you used pins P0.05-P0.08, you can try to add the following:
    NRF_GPIO->PIN_CNF[5] = 0x00000002;
    NRF_GPIO->PIN_CNF[6] = 0x00000002;
    NRF_GPIO->PIN_CNF[7] = 0x00000002;
    NRF_GPIO->PIN_CNF[8] = 0x00000002;
    See if it affects the current consumption.
    If that doesn't work, you can try to add the lines from the initial post in this ticket.
    Just the line turning it off:
     *(volatile uint32_t *)0x40002FFC = 0;
    Edvin
