entering command-line environment
I've installed the nRF Connect SDK, and want to bring up a command-line build environment.
I'm able to do it as it says in the instructions here: Bring up the Toolchain Manager and use the "Open Bash" option from the drop-down menu.
However, I'd like to be able to get into the environment without bringing up the Toolchain Manager. What do I do? What script do I run from git-bash?
I tried running zephyr/zephyr-env.sh, but apparently that's not enough.
Thanks!
    Thanks - your reply helped me to find the solution.
    tl;dr: I should launch Git bash by running the git-bash.exe executable in the SDK's toolchain dir, not my "regular" Git bash, and everything will be set up automagically.
    Git Bash:
    The root dir (the "/" dir) in Git Bash is: The directory of the git-bash.exe executable that was launched.
    When I launch Git bash on my system the "normal" way, it launches my regular git-bash.exe executable from C:\Program Files\Git - and so that is root.
    The Toolchain Manager, otoh, uses the git-bash.exe executable in the SDK's toolchain dir - and so that is root.
    Next, Git bash executes /etc/profile (off of whatever root is). The SDK's /etc/profile executes everything in the profile.d subdir. In particular, profile.d/ncs-env.sh sets up the proper SDK environment.
    So, if I execute the git-bash.exe executable in the SDK's toolchain dir, I don't need to do anything else.
    Windows Command Shell:
    To launch the Windows Command Shell, the Toolchain Manager executes the git-cmd.cmd script in the SDK's toolchain dir. All this script does, really, is execute cmd\env.cmd. Simply bringing up the "regular" Windows command shell and running either git-cmd.cmd or cmd\env.cmd accomplishes the same thing - which is why what I did previously with the Windows command shell worked.
    Windows Power Shell:
    The SDK does not have a pre-packaged way to bring up a Windows Power Shell environment, so, I will not use it.
    Hope this helps Wink
    Thanks!
  • The solution in the suggested answer to simply run "git-bash.exe" in the toolchain folder works great for SDK v1.9.1. However, for SDK v2.0.0, the git-bash.exe file was moved to a separate "toolchains/v2.0.0" folder and running "git-bash.exe" in this folder does not load the correct environment. Any suggestions?
    I would like to be able to directly launch a Git Bash with the SDK v2.0.0 environment without using the option in Toolchain Manager. Using Toolchain Manager, the "Open bash" option works just fine.
    Thanks!
    The toolchain was changed in nRF Connect SDK v2.0.0 to be the Zephyr SDK. and not GNU Arm Embedded Toolchain as in previous versions, so running git-bash.exe will not set up gnuarmemb. It should still set up the environment variables for the new toolchain. If this is not the case, please open a new ticket, as the original issue in this ticket has been solved. Thank you!
    Marte
