Read data from 16bit register TWI on NRF52833.
Hi All,
         I am trying to communicate with IC MAX17201 using I2C interface. I am able to detect the IC and communicate with it.
When I read 8bit registers from the IC I don't have any issue. But when I am trying to read 16bit register from the IC, I am getting errors.The existing code from NRF SDK includes data to read and write 8 bit registers.
I have modified the code a bit in order to read 2bytes from register. I am not able to read 16bit registers. I tried to read NPACKCFG_REG but not able to read it properly. As well as while compiling I am getting warnings like this:-unsigned conversion from 'int' to 'uint8_t' {aka 'unsigned char'} changes value from '437' to '181' [-
#define NPACKCFG_REG     0x1B5
#define MAX17201_ADDRESS_LEN  1
#define MAX17201_ADDR     (0xD8>>1)
#define MAX17201_WHO_AM_I     0x6BU
bool i2c_register_write_max17211(uint16_t register_address, uint16_t value)
      ret_code_t err_code;
      uint8_t tx_data[4];
      tx_data[0] = ( (register_address >> 8)& 0xFF );
      tx_data[1] = register_address & 0xFF;
      tx_data[2] = ((value>>8)& 0xff);
      tx_data[3] = value & 0xFF;
      m_xfer_done = false;
      err_code = nrf_drv_twi_tx(&m_twi, MAX17201_WHO_AM_I, tx_data, sizeof(tx_data), false);
  //Wait until the transmission of the data is finished
    while (m_xfer_done == false)
   // if there is no error then return true else return false
    if (NRF_SUCCESS != err_code)
        NRF_LOG_INFO("FAILED");
        return false;
    NRF_LOG_INFO("SUCCESS");
    return true;
bool i2c_register_read_max17211(uint8_t register_address, uint8_t destination[2], uint8_t number_of_bytes)
    //uint8_t rx_buffer[2];
    //Set the flag to false to show the receiving is not yet completed
    // Send the Register address where we want to write the data
    err_code = nrf_drv_twi_tx(&m_twi, MAX17201_WHO_AM_I, &register_address, 1, true);
    //Wait for the transmission to get completed
    while (m_xfer_done == false){}
    //vTaskDelay(1000);
    // If transmission was not successful, exit the function with false as return value
        return false;
    //set the flag again so that we can read data from the MPU6050's internal register
    // Receive the data from the MPU6050
    //err_code = nrf_drv_twi_rx(&m_twi, MAX17201_WHO_AM_I, destination, number_of_bytes);
    err_code = nrf_drv_twi_rx(&m_twi, MAX17201_WHO_AM_I, &destination[0], sizeof(destination));
    //wait until the transmission is completed
    //vTaskDelay(1000);
    // if data was successfully read, return true else return false
        return false;
    //NRF_LOG_INFO("DATA IS %x",destination);
    return true;
Please help me on how to read multiple bytes from 16bit registers and how to write data into 16 bit registers.
