NRF52840 Zephyr ADC read issue
I am using nrf52840 on usb dongle  and i would like to measure voltage on a specific ADC input pin.
According to the datasheet, i use P0.02/AIN0.
My problem is that adc_read() function returns -22 error.
I am posting the code and the overlay file. Could you please help me what i am doing wrong here?
Thanks a lot guys!
Thanos
&adc
    status = "okay";
    io-channels = <&adc 0>;
#define ADC_RESOLUTION		    12
#define ADC_GAIN			    ADC_GAIN_1
#define ADC_REFERENCE		    ADC_REF_INTERNAL
#define ADC_ACQUISITION_TIME	ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 40)
#define ADC_CHANNEL_AIN0       0
#define ADC_IO_LABEL            DT_GPIO_LABEL(DT_ALIAS(gpiocus1), gpios)
#define ADC_IO_PIN	            DT_GPIO_PIN(DT_ALIAS(gpiocus1), gpios)
const struct device *adc_dev;
const struct device *adc_en_dev;
uint32_t sample_buffer[10] = {0};
static struct adc_channel_cfg adcConfig =
	.gain             = ADC_GAIN,
	.reference        = ADC_REFERENCE,
	.acquisition_time = ADC_ACQUISITION_TIME,
	.channel_id       = 1, // gets set during init
	.differential	  = 0,
// #if CONFIG_ADC_CONFIGURABLE_INPUTS
	// .input_positive   = 0, // gets set during init
// #endif
const struct adc_sequence sequence =
	    .options     = NULL,				// extra samples and callback
		.channels    = BIT(ADC_CHANNEL_AIN0),		// bit mask of channels to read
		.buffer      = sample_buffer,		// where to put samples read
		.buffer_size = sizeof(sample_buffer),
		.resolution  = ADC_RESOLUTION,		// desired resolution
		.oversampling = 0,					// don't oversample
		.calibrate = 0						// don't calibrate
bool adc_init(uint8_t channel)
    int adcInitError;
    adc_dev = DEVICE_DT_GET(DT_NODELABEL(adc));
    if(adc_dev == NULL)
        return false;
    adc_dev = device_get_binding(DEVICE_DT_NAME(DT_NODELABEL(adc)));
    if(adc_dev == NULL)
        return false;
    adcConfig.channel_id = channel;
    adcInitError = adc_channel_setup(adc_dev, &adcConfig);
    if(adcInitError)
        return false;
    return true;
uint32_t readBatteryVoltage(void)
    int readBatteryVoltageError = 0;
    readBatteryVoltageError = adc_read(adc_dev, &sequence);
    if(readBatteryVoltageError == 0)
        return sample_buffer[0];
    return 0;
CONFIG_ADC=y
CONFIG_ADC_ASYNC=y
