Please tell me how to set 128bit UUID to "ble_uuid_t" in [Function for adding the Custom Value characteristic].
OS in development environment :Windows10
HARD :(Taiyo Yuden)EBSHSN Series Evaluation Board : Central / Peripherals
CPU :(Nordic) nRF52832 / ARMR Cortex-M4F 32 bit processor 28-pin Land Grid Array / 15GPIOs / SWD
builder :SEGGER Embedded Studio for ARM Release 3.34a Build 2018022300.35192 Windows x64
Copyright 2014-2018 SEGGER Microcontroller GmbH & Co. KG
Copyright 1997-2018 Rowley Associates Ltd.
GCC/BINUTILS: Built using the GNU ARM Embedded Toolchain version 6-2017-q2-update source distribution
Clang/LLVM: Built using the version 5.0.0 source distribution
Soft Ver:nRF5_SDK_15.3.0_59ac345
I thought about it with reference to [Common type and macro definition> Definition], but I think that it will affect related programs if the [p_cus-> uuid_type] part of the 16-bit setting is not performed even with the 128-bit setting.
(For 16bit)
    ble_uuid_t ble_uuid;
    ble_uuid.type = p_cus->uuid_type;
(For 128bit)
    ble_uuid.type = BLE_UUID_TYPE_VENDOR_BEGIN;
Please tell me the setting method for 128bit.
Thanking you in advance.
    I'm not sure what you are trying to do.
    If you want to add multiple services with different UUID base then you have to follow Hungs example here:
    Hung Bui said:
     For example this code will add 2 services with different UUIDs:
    I strongly suggest that you also go through our 3 part tutorial on Advertising, Service, and Characteristics. I especially recommend going through the service tutorial. It shows you how to setup a custom service with custom UUID.
    regards
    Jared
