Not able to use nordic proprietary AT-Commands on nrf9160
Hello dear People,
I would be very happy if anyone has an idea how to solve this.
The Problem is the following: I am using nordics lte link controller to connect to nb-iot(<modem/lte_lc.h>), but when opening a socket, it times out... (error 116).
Basically for this testing scenario i adapted the udp sample to make tcp connection and send/receive some data:
The code for opening the socket:
 ip to local port and establish tcp-connection:
int tcp_create_conn_socket(const char * host, int port){
  // conn. init: defining socket parameters
  struct sockaddr_in *server4 = ((struct sockaddr_in *)&host_addr);
  server4->sin_family = AF_INET;
  server4->sin_port = htons(port);
  inet_pton(AF_INET, host, &server4->sin_addr);
  // bind server ip to local port and establish tcp-connection:
  int err, sockfd;
  sockfd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);  // Creation of TCP-Socket
  if (sockfd < 0) {
    printk("Failed to create TCP socket: %d\n", errno);
    err = -errno;
    goto error;
  err = connect(sockfd, (struct sockaddr *)&host_addr, sizeof(struct sockaddr_in));  // establishing connection
  if (err < 0) {
    printk("Connect failed : %d\n", errno);
    goto error;
  return sockfd;
error:
  tcp_disconnect(sockfd);
  return err;
my proj.conf file looks the following:
# Copyright (c) 2020 Nordic Semiconductor ASA
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_LOG_PRINTK=y
CONFIG_ASSERT=y
CONFIG_STACK_SENTINEL=y
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# Modem library
CONFIG_NRF_MODEM_LIB=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=1024
CONFIG_MAIN_STACK_SIZE=4096
# LTE parameters
## Network Mode / LTE category
CONFIG_LTE_NETWORK_MODE_LTE_M=n
CONFIG_LTE_NETWORK_MODE_NBIOT=y
#CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
## PSM
#CONFIG_UDP_PSM_ENABLE=y
#CONFIG_LTE_PSM_REQ_RPTAU="00100001"
#CONFIG_LTE_PSM_REQ_RAT="00000000"
## eDRX
CONFIG_UDP_EDRX_ENABLE=n
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="1001"
## RAI
#CONFIG_UDP_RAI_ENABLE=n
#CONFIG_LTE_RAI_REQ_VALUE="4"
the debug output:
*** Booting Zephyr OS build v2.7.99-ncs1  ***
[*] NIS TCP-WRAP TEST-APP
lte-mode: irgend n anderer
D: AT notif: +CEREG: 2,"C37C","01921F0C",9,0,0,"11100000","11100000"
D: Dispatching to 0x178fd
LTE cell changed: Cell ID: 26353420, Tracking area: 50044
D: AT notif: +CSCON: 1
D: Dispatching to 0x17479
RRC mode: Connected
D: AT notif: +CEREG: 1,"C37C","01921F0C",9,,,"00000010","00011111"
Network registration status: Connected - home network
PSM parameter update: TAU: 18600, Active time: 4
lte-mode: nbiot-lte
cesq-response: ERROR
selected band:
ERROR
Connect failed : 116
[!] Err: Not able to initialize and establish TCP server connection
D: AT notif: +CSCON: 0
RRC mode: Idle
my main.c:
void main(void)
  printk("[*] NIS TCP-WRAP TEST-APP\n");
  k_work_init_delayable(&server_transmission_work, transmit_msg); // init worker thread, since modem conn is not reliable from isr
  if(init_lte() < 0) return;
  //if(init_button() < 0) return;
  //if(init_led() < 0) return;
  if (ask_for_current_band() < 0) return;
  sockfd = tcp_create_conn_socket("194.13.83.174", 4444);
  if (sockfd < 0) {
    printk("[!] Err: Not able to initialize and establish TCP server connection\n");
    return;
  printk("[*] Connected to server\n");
  server_connected = true;
  tcp_send_msg(sockfd, "hallo was geht?", 15);
  wait_for_incoming();
  return;
the connection to the server used to work on my thingy, but on the custom devboard my employer wants me to work with there the tcp-connection always times out.
One big difference is on the thingy i was using lte-m and the devboard sim only supports nb-iot which is why I configured the project to use nb-iot only.
this is the code i use to connect to the nb-iot network:
int lte_modem_connect(){
  int err;
  enum lte_lc_lte_mode a;
  k_work_init_delayable(&lte_at_work, get_at);
  if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
          /* Do nothing, modem is already configured and LTE connected. */
  } else {
          lte_lc_lte_mode_get(&a);
          switch(a){
            case LTE_LC_SYSTEM_MODE_PREFER_AUTO:
              printk("lte_mode: prefer auto\n");
            case LTE_LC_SYSTEM_MODE_PREFER_LTEM:
              printk("lte_mode: prefer lte-m\n");
            case LTE_LC_SYSTEM_MODE_PREFER_NBIOT:
              printk("lte-mode: prefer-nbiot");
              printk("lte-mode: irgend n anderer\n");
          printk("");
          err = lte_lc_connect_async(lte_handler);
          if (err) {
                  printk("Connecting to LTE network failed, error: %d\n",
                         err);
                  return;
          //k_msleep(500);
          //k_work_schedule(&lte_at_work, K_NO_WAIT);
  k_sem_take(&lte_connected, K_FOREVER);
  switch(a){
    case LTE_LC_LTE_MODE_LTEM:
    case LTE_LC_LTE_MODE_NBIOT:
      printk("lte-mode: nbiot-lte\n");
Now when I call some at commands (using nrf_modem_at_cmd from  <nrf_modem_at.h>) for example to see which band is in use/available on the modem:
int ask_for_current_band(){
  char response[64];
  nrf_modem_at_cmd(response, 64, "AT%CESQ=1");
  printk("cesq-response: %s\n", response);
  if (nrf_modem_at_cmd_async(band_at_callback, "AT%XCBAND=?")) return -1;
I always get an error (see debug output above), but only when using nordics proprietary at-commands (AT%<command>, like mentioned in https://infocenter.nordicsemi.com/pdf/nrf91_at_commands_v1.0.pdf). Standard AT-Commands (those with a +) seem to work fine....
Do i have to do extra configuration when I want to use the nordic proprietary at-commands like XCBAND or when I am using NB-IOT in general?
My guess so far is that the connection time out is occuring, because nordics lte link controller is eventually also not able to use those to open a socket.
Any help is appreciated and I would be very grateful.
Have a nice day folks,
Jannis
PS: my setup:
Modem firmware version 1.2.3
nrf-connect sdk version 1.9.0
Nordic nrf9160 rev2
  • Hey Charlie,
    That was actually a very good hint, i was using the wrong apn the entire time,
    for anyone facing a similar problem, this is my code to set the apn, while using the LTE link controller to handle the connection:
    void set_apn(){
      char response[256];
      nrf_modem_at_cmd(response, 256, "AT+CGDCONT=0,\"IPV4V6\",\"your.chosen.apn\"");
      printk("set apn: %s\n", response);
    Thank you Charlie for your help!
