NCS1.9.1 VS Code download error
NCS1.9.1, nRF52840 chip,  Windows10 X64, VS Code, JLink V10 Model,
i've connect pins CLK,DIO,GND,3.3V,
now:
J-Flash download(hex) work well,
Keil5 IDE download(nRF SDK) work well,
but VS Code download(NCS) error,   i don't know what happened.
tips:     VS Code download to nRF52840DK will be OK (no use JLink V10 Model).
thanks
Best Regards
    thanks for reply,
    i delete and redo it.
    thanks
    Best Regards
    I was on vacation and hence the delayed response. Do you still face the issue?
    -Priyanka
    thanks for reply.
    The problem remains. I can only download it through J-Flash.
    Your post no reply button, so eply here.
    Best regards
    Sorry for repeating a few questions. I would like to clarify some stuff.
    You are using the nRF52840DK right? (please verify tat it is not a nRF52840-PDK)
    And you are trying to do the basic hello_world sample onto the nRF52840DK?
    Have you tried using west? Does it work well when trying with west?
    Also, could you try shifting the folder "nRF5_Work" to d:/Programs/nRF5_Work and then try again?
    -Priyanka
    yes, i step  two,  and i use nRF52840-DK,not PDK.
    VSCode Support Information.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.22000",
        "vscode": "1.67.2",
        "electron": "17.4.1",
        "node": "v16.13.0"
      "system": {
        "date": "2022-05-21T05:34:09.644Z",
        "vscodeRoot": "d:\\Program\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "02:17:46",
        "osUptime": "02:23:38",
        "cpu": {
          "model": "Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz",
          "speed": "2660 MHz",
          "count": 4
        "memory": {
          "total": "7.99 GB",
          "free": "3.64 GB"
      "workspace": {
        "name": "nRF5_Work (Workspace)",
        "workspaceFile": "d:\\nRF5_Work\\nRF5_Work.code-workspace",
        "folders": [
          "d:\\nRF5_Work"
      "extensions": {
        "internal": {
            "version": "2022.4.219",
            "path": "c:\\Users\\Administrator\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.4.219",
            "isActive": true
            "version": "2022.4.61",
            "path": "c:\\Users\\Administrator\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.4.61",
            "isActive": true
          "nordic-semiconductor.devicetree": null,
          "nordic-semiconductor.kconfig": null
        "external": {
          "marus25.cortex-debug": "1.4.4",
          "ms-vscode.cpptools": "1.9.8",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.15",
          "ms-vscode.js-debug": "1.67.2",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.references-view": "0.0.89",
          "ms-vscode.vscode-js-profile-table": "1.0.1",
          "cschlosser.doxdocgen": "1.4.0",
          "endercat.one-dark-github": "0.0.1",
          "jeff-hykin.better-cpp-syntax": "1.15.13",
          "ms-vscode-remote.remote-containers": "0.234.0",
          "ms-vscode-remote.remote-ssh": "0.80.0",
          "ms-vscode-remote.remote-ssh-edit": "0.80.0",
          "ms-vscode-remote.remote-wsl": "0.66.3",
          "ms-vscode.cpptools-extension-pack": "1.2.0",
          "ms-vscode.cpptools-themes": "1.0.0",
          "trond-snekvik.gnu-mapfiles": "1.1.0"
      "tools": {
        "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.52d",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.0",
        "nrfutil": "Not found",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.12.0",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\python.exe": "3.8.2",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\gperf.exe": "3.1",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9-2019-q4-major",
        "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\gn.exe": "1977",
        "d:\\Program\\v1.9.99\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1"
      "sdks": [],
      "toolchains": [],
      "connectedDevices": [
          "serialNumber": "1050074424"
          "serialNumber": "683608588"
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "d:\\Program\\v1.9.99",
          "toolchain": {
            "path": "d:\\Program\\v1.9.99\\toolchain"
          "ozonePath": "",
          "applications": [
            "${workspaceFolder}\\hello_world",
            "${workspaceFolder}\\button",
            "${workspaceFolder}\\nvs",
            "${workspaceFolder}\\record_text",
            "${workspaceFolder}\\qspi",
            "${workspaceFolder}\\lpuart"
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "welcome": {
            "showOnStartup": false
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "enableTelemetry": true
          "terminalMode": "character"
        "nordic-semiconductor.devicetree": {
          "modules": [
            "${zephyrBase}",
            "${zephyrBase}/../nrf",
          "zephyr": "D:\\Program\\v1.9.99\\zephyr\\",
          "ctxFile": "",
          "defaultBoard": "nrf5340dk_nrf5340_cpuapp"
        "nordic-semiconductor.kconfig": {
          "python": "D:\\Program\\v1.9.99\\toolchain\\opt\\bin\\python.exe"
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "flattenAnonymous": false,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showRTOS": false,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\Scripts\\west.exe",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\Administrator",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\Administrator",
          "Path": "d:\\Program\\v1.9.99\\toolchain\\mingw64\\bin;d:\\Program\\v1.9.99\\toolchain\\mingw64\\libexec\\git-core;d:\\Program\\v1.9.99\\toolchain\\opt\\bin;d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\Scripts;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\windows\\system32;C:\\windows;C:\\windows\\System32\\Wbem;C:\\windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;D:\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;D:\\Program\\v1.9.99\\toolchain\\opt\\bin\\Scripts;D:\\Program\\v1.9.99\\toolchain\\opt\\bin;D:\\Program\\v1.9.99\\toolchain\\bin;D:\\Program\\v1.9.1\\toolchain\\opt\\bin\\Scripts;D:\\Program\\v1.9.1\\toolchain\\opt\\bin;D:\\Program\\v1.9.1\\toolchain\\bin;C:\\Users\\Administrator\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Administrator\\.dotnet\\tools;D:\\Program\\Microsoft VS Code\\bin;D:\\Program\\Python\\Scripts;D:\\Program\\Python;C:\\Users\\Administrator\\AppData\\Local\\GitHubDesktop\\bin;",
          "ZEPHYR_BASE": "d:\\Program\\v1.9.99\\zephyr",
          "GNUARMEMB_TOOLCHAIN_PATH": "d:\\Program\\v1.9.99\\toolchain\\opt",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
          "PYTHONPATH": "d:\\Program\\v1.9.99\\toolchain\\opt\\bin;d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\Lib;d:\\Program\\v1.9.99\\toolchain\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "d:\\Program\\v1.9.99\\toolchain\\opt\\bin"
        "toolchainPath": "d:\\Program\\v1.9.99\\toolchain",
        "toolchainBinPath": "d:\\Program\\v1.9.99\\toolchain\\opt\\bin",
        "toolchainVersion": "1.9.99"
      "terminal": {
        "shell": null,
        "defaultProfile": null
    Best regards
