MAX30101 I2C communication with nRF52 - DK
Hi, I'm currently designing a system which requires Heart Rate monitorization and I'm using the MAX30101 chip to do so. I will be using I2C communication and, therefore, based my code on the twi_sensor example for the nRF52 -DK dev kit. However, I just can not get any values from the sensor. Can anybody help me understand what I'm doing wrong? Thanks in advance.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR          (0x90U >> 1)
#define MAX30101_ADDRESS     0x57
#define MAX30101_CONF_REG    0x09
#define MAX30101_MODE_HR     0x02
#define MAX30101_MODE_SPO2   0x03
#define MAX30101_FIFO_DATA   0x07
#define MAX30101_FIFO_WR_PT  0x04
#define MAX30101_FIFO_RD_PT  0x06
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
static uint8_t m_wr_ptr, m_rd_ptr, m_num_samples;
static uint8_t tx_fifo[2];
 * @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
    ret_code_t err_code;
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg[2] = {MAX30101_CONF_REG, MAX30101_MODE_SPO2};
    err_code = nrf_drv_twi_tx(&m_twi, MAX30101_ADDRESS, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to pointer byte. */
    reg[0] = MAX30101_FIFO_WR_PT;
    err_code = nrf_drv_twi_tx(&m_twi, MAX30101_ADDRESS, reg, 1, false);
    err_code = nrf_drv_twi_rx(&m_twi, MAX30101_ADDRESS, &m_wr_ptr, sizeof(m_wr_ptr));
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Values SpO2: %d .", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
        if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_lm75b_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    tx_fifo[0] = MAX30101_FIFO_RD_PT;
    err_code = nrf_drv_twi_tx(&m_twi, MAX30101_ADDRESS, tx_fifo, 1, false);
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    err_code = nrf_drv_twi_rx(&m_twi, MAX30101_ADDRESS, &m_sample, sizeof(m_sample));
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    NRF_LOG_INFO("\r\nI2C Communication initialized.");
    NRF_LOG_FLUSH();
    LM75B_set_mode();
    NRF_LOG_INFO("\r\nMAX30101 Initialized.");
    NRF_LOG_FLUSH();
    while (true)
        nrf_delay_ms(500);
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
