ESB "Hiccup"
I am currently working on a project in which I want to transmit audio wirelessly from one nRF chip to another. Currently I am using the nRF Dongle to act as the transmitter and a nRF-DK board as the receiver. I have finally gotten them to talk to each other through ESB, and the transmitter is currently sending a digital sine wave table out to the receiver which is then using SPI to interface with an external DAC. The problem lies in these "hiccups" that occur periodically, and while the frequency of the wave is something I can control, I can't seem to get rid of these hiccups. I am new to the Nordic development environment and I don't have much experience in the ESB protocol, and so I'm not sure if it's a hardware limitation, an acknowledgement issue, or something that I've overlooked in my code. At some point, the transmission will live in an SAADC callback function. That version works in terms of the signal path, but is experiencing the same problem that is outlined here. The problem is shown below, and here is my initialization of ESB, along with the transmission. Any help is greatly appreciated!
uint32_t esb_init( void )
    uint32_t err_code;
    uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};
    uint8_t base_addr_1[4] = {0xC2, 0xC2, 0xC2, 0xC2};
    uint8_t addr_prefix[8] = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8 };
    nrf_esb_config_t nrf_esb_config         = NRF_ESB_DEFAULT_CONFIG;
    nrf_esb_config.protocol                 = NRF_ESB_PROTOCOL_ESB_DPL;
    nrf_esb_config.retransmit_delay         = 100;
    nrf_esb_config.bitrate                  = NRF_ESB_BITRATE_2MBPS;
    nrf_esb_config.event_handler            = nrf_esb_event_handler;
    nrf_esb_config.mode                     = NRF_ESB_MODE_PTX;
    nrf_esb_config.selective_auto_ack       = true;
    nrf_esb_config.payload_length           = 2;
    nrf_esb_config.retransmit_count         = 1;
    err_code = nrf_esb_init(&nrf_esb_config);
    VERIFY_SUCCESS(err_code);
    err_code = nrf_esb_set_base_address_0(base_addr_0);
    err_code = nrf_esb_set_base_address_1(base_addr_1);
    err_code = nrf_esb_set_prefixes(addr_prefix, NRF_ESB_PIPE_COUNT);
    return err_code;
int i = 0;
    while (true)
        tx_payload.data[0] = SineWave[i] & 0xFF;
        tx_payload.data[1] = SineWave[i] >> 8;
        tx_payload.noack = true;
        nrf_esb_write_payload(&tx_payload);
        i++;
        if (i >= 80)
            i = 0;
        nrf_delay_ms(50);
  • That is very appreciated thank you so much!
    I am using version 17.1.0 of the SDK.
    Here is the zipped project file:4174.ses.zip
  • Hi
    The project files alone doesn't help me much, I would also need the source files (main.c for instance). Could you include this as well?
    Best regards
    Torbjørn
  • I actually got the transmission to work properly! I am inputting a full swing sine wave (1.65 V DC offset with a 1.65 V amplitude) on the transmitter side and receiving it on the other end (again sending the data through SPI to an external DAC). The new problem I am experiencing is not the repeated interruptions, but the speed of the output wave. Once the input wave goes past around 3 Hz, it appears very digitized on the output. Right now my ADC is sampling every millisecond. If you have any suggestions that would be appreciated!
  • Hi
    It sounds odd that more than 3Hz would be a problem, if you are sampling at 1000Hz.
    Have you checked on the receiving end that you are getting all the samples?
    If you count the samples over time you can check if you receive the expected 1000 samples pr second.
    Are you doing any buffering on the receiving side to handle any inconsistency in timing or minor delays that could happen over the wireless link?
    Also, is the DAC set up to play a 1000 Hz samplerate signal properly?
    If the output appears digitized it could just be that the appropriate filtering is not applied, to remove any frequency components above 500 Hz (half the sampling frequency, as per the Nyquist theorem).
    Best regards
    Torbjørn
  • I ended up fixing the speed issue (it was slowed down due to logging, so taking all unnecessary code out drastically improved the output waveform), but now we are faced with noise on the output. While I can hear the tone that is being transmitted, there is underlying noise that seems to get even worse when I connect ground to the ADC of the transmitter side (ideally no sound at all). I currently have the ADC resolution set to 14 bit and I am removing the bottom 4 bits in order to combat ADC noise. Is there anything else that you think could be causing the problem or that I should look into?
