DEADBEEF from somewhere in SD, both production and alpha
The error I get is app_error_handler 0xDEADBEEF, 360 (line number), src\ll_lm.s0.c
This is with SD 5.2.1
With SD 6.0.0.1-alpha, sometimes I get
app_error_handler 0xDEADBEEF, 783, src\ll_lm.s0.c
What my code does is initialize SoftDevice and start advertising, and it does a few hardware things, starts up one app_timer, then goes into my application loop
Sometimes, my application will run just fine forever, service discovery works, and I can send data back and forth between MCP and my app
Sometimes my loop will run only a few times, and then just freeze, with no error message, but it won't reply to service discovery.
Sometimes my loop will run only a few times, and then output the error message.
Sometimes my loop will run forever, until an attempt at service discovery, at which point I get the error message
This also sounds similar to devzone.nordicsemi.com/.../spurious-s110-crash except with different line numbers
edit: disabling the UART (not initializing it at all and not sending any characters) does not help, the advertising packet is sent only once, and fails to reply to service discovery
edit: there are no interrupts in my application, although I do have one application timer that fires an event handler every 1 millisecond
edit: I added a printf into my app_timer event handler, now sometimes I get "app_error_handler 0xDEADBEEF, 631, src\ll_adv.c", once in every maybe 10 attempts, using 6.0.0.1-alpha
edit: I got line 728 from src\ll_lm.s0.c just once so far, using 6.0.0.1-alpha
  • It seems this is a different issue from the original poster here, so it might be better to post it separately. However, it could sound as if you have a problem with one of your crystals. Have you verified the frequency of your 16 MHz crystal? Also, could you try to use the RC oscillator for the low-frequency clock? Take a look at this for details: https://devzone.nordicsemi.com/index.php/what-low-frequency-clock-sources-can-i-use
  • Ole,
    Please answer regarding my secondary question:
    The reference manual 'CLOCK' section says that to use the RADIO an external crystal oscillator MUST be used however after initializing the soft device and checking HFCLKSTAT, it says the RC is being used. Is the crystal oscillator turned on dynamically for BLE RADIO use?
    The reason this is important is I get RADIO traffic in both directions yet at no time do I check and find the crystal oscillator enabled (on the PCA10001s or my PCBs) so if it never needs to or gets enabled, I can rule out the crystal.
    In addition can you confirm that the stack error that is thrown (reported in many posts now) results from clock/crystal selection/functioning/instability/accuracy. I.e. Does it have anything to do with anything affected by the clock.
    One more note: The PCA10001s have QQFAA GC chips and my PCBs have QFAA C0 chips. All documentation I have found suggest I do not need to consider the differences between these two production codes.
  • The crystal is turned on only for the actual connection and advertising events when using a softdevice. This is handled automatically by the softdevice. This means that the crystal will be on only for very short periods (few ms).
    To verify the crystal is working, you can either do a radio test (DTM or radio_test_example), and check that the carrier is where you're expecting, or manually start the crystal (TASKS_HFCLKSTART in NRF_CLOCK) and use a sniffer probe to see it.
    The assert you're seeing would normally be triggered only by application interrupts running with too high priority, but the fact that that you only see the problem with your custom board makes me suspect a crystal problem.
    I'd still be very happy if you could post this separately, as this seems to become rather messy. I'd also like to see your complete source code and board schematics. If you don't want to share it here, feel free to create a regular support case.
  • Ole,
    Before I ever posted anything I did do a manual start of the crystal prior to initializing the softdevice and it does indeed indicate this in HFCLKSTAT afterward but I was not sure if the status was indicating that I had enabled it or was a confirmation (i.e. cycles had been counted/etc) that it was actually running. Please advise.
    I will move this to a new topic but at the moment I am attempting to get a functioning unit to CES and scrambling quite a bit.
    I had been working directly with Pratyush on issues but he is still out.
    Keith
  • Ole,
    HFCLK started and reflected in HFCLKSTAT reconfirmed
    Keith
