Sleep current during k_sleep()
In a nrf52840 project using Zephyr 3.0 following Zephyr drivers are used:
  • the modbus serial driver(RTU mode) which uses uart1 in interrupt mode
  • the lora-mac driver which uses spi1
  • serial logging on uart0
The application works fine but during inactivity periods the standby current is sometimes much too high: 520uA instead of ~10uA
I know that the uarts don't suspend automatically so immediately before k_sleep() I execute:
pm_device_action_run(uart0, PM_DEVICE_ACTION_SUSPEND);
pm_device_action_run(uart1, PM_DEVICE_ACTION_SUSPEND);
Without success I also tried:
  • executing nrf_uart_errorsrc_get_and_clear() for both uarts before k_sleep().
  • disable logging completely but as well without success.
  • "disable" all unneeded periphery in the device tree.
  • checked thread activity via the Zephyr Thread Analyzer but I could not find excessive activity.
  • executing pm_device_action_run()  for spi1, gpio0, gpio1 , ...
  • modbus_disable() during sleep
Do you have any hints how I could enclose or solve the problem?
Thx  Matthias
  • Is there a easy way to check the power state of ALL periphery of the SoC (nrf52840) under Zephyr?
    (possibly by using pm_device_state_get() but then I would have to define all 10th of device handles manually. Does it exist a easier solution?)
  • Finally I came to following solution to solve my standby current problem:
    1.)
    Running ths function with argument true/false before/after k_sleep() :
    void set_pm_mode_suspend(bool suspend)
      const struct device *uart0 = device_get_binding(DT_LABEL(DT_NODELABEL(uart0)));
      const struct device *uart1 = device_get_binding(DT_LABEL(DT_NODELABEL(uart1)));
      const struct device *spi1 = device_get_binding(DT_LABEL(DT_NODELABEL(spi1)));
      enum pm_device_action action =
           suspend ? PM_DEVICE_ACTION_SUSPEND : PM_DEVICE_ACTION_RESUME;
    #ifdef CONFIG_LOG
      if (suspend)
        while (log_process(false)) ; // flush log buffer, otherwise it is lost
      pm_device_action_run(uart1, action); // -1mA !!
      pm_device_action_run(uart0, action); // -3mA !!
      nrf_uart_errorsrc_get_and_clear((NRF_UART_Type *) DT_REG_ADDR(DT_NODELABEL(uart0)));
      nrf_uart_errorsrc_get_and_clear((NRF_UART_Type *) DT_REG_ADDR(DT_NODELABEL(uart1)));
      uart_irq_rx_disable(uart0);    // no input (eg. shell) used on console port
      if (suspend) uart_irq_rx_disable(uart1);
      pm_device_action_run(spi1, action);
    Remark: with solution above, I could used normal console logging enabled using the default log buffering but mention that log messages from other tasks during set_pm_mode_suspend(true) will be lost.
    2.)
    Enabling a edge triggered GPIO button interrupt will caused additional 15uA current. Because of this level triggered interrupt is used by:
      gpio_pin_interrupt_configure_dt(&button, GPIO_INT_LEVEL_ACTIVE);
    Then disabling the interrupt in the interrupt handler by:
      gpio_pin_interrupt_configure_dt(&button, GPIO_INT_DISABLE);
    And reenable it later eg. by using a rtc timer or some application logic.
    3.)
    Before doing any current measurement, a power cycle is needed after flashing to disable the SWD interface!
    Forther the connection to SWD and the console RxD/TxD has to be disconnected if the power supply is not sourced from the programmers VCC supply (eg. when using the PPK2 power supply).
