Detecting JLINK with nrfjprog
Hi all,
I'm trying something similar to this:
https://devzone.nordicsemi.com/f/nordic-q-a/21628/how-to-use-nrfjprog-dll
i.e. using the nrfprog.dll to connect with a Jlink from a c# application.
Opening the .dll works fine and I now want to use this function:
nrfjprogdll_err_t NRFJPROG_enum_emu_snr(uint32_t serial_numbers[], uint32_t serial_numbers_len, uint32_t * num_available);
wrapped in my App as:
[DllImport("nrfjprog.dll", CallingConvention = CallingConvention.Cdecl)]
private static extern int NRFJPROG_enum_emu_snr(UInt32[] serial_numbers,UInt32 serial_numbers_len, out UInt32 num_available);
The num_available returned is correct, i.e. 1 if one JLINK is connected, 2 if two are connected etc. The serial_numbers and serial_numbers_len are, however, empty.
Looking at the arguments one would think that this is because serial_numbers and serial_numbers_len are not "pointers" and can therefore not "return" any values.
Consequently I try to modify the wrapper to:
private static extern int NRFJPROG_enum_emu_snr(out UInt32[] serial_numbers,out UInt32 serial_numbers_len, out UInt32 num_available);
Unfortunately this result in the following runtime error:
>>Exception thrown: 'System.AccessViolationException' in NRFJPROG.exe
>>An unhandled exception of type 'System.AccessViolationException' occurred in NRFJPROG.exe
>>Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Any ideas on how to make this work ?
Cheers
Eric
    Could you provide  a log either by providing a callback to the cb parameter or by setting jlink to log the output to a file (J-Link log file)?
    Dejan
  • Ok, so one  "success log" and one "fail log" attached. It seems the correct SNR is read also in the fail log but that something goes wrong due to the (obviously) "low target voltage".
    \Eric
    Start
    [SeggerBackend] [Debug] Logger sink registered in Segger backend logger
    [JLink] [Debug] Logger sink registered in JLink logger
    [nRF52] [Debug] open
    [nRF52] [Debug] just_check_family
    [SeggerBackend] [Debug] open_dll
    [SeggerBackend] [Info] Load library at C:\Program Files\SEGGER\JLink\JLink_x64.dll.
    [SeggerBackend] [Info] Library loaded, loading member functions.
    [SeggerBackend] [Info] Member functions succesfully loaded.
    [SeggerBackend] [Debug] dll_version
    [SeggerBackend] [Info] Segger dll version 7.60.c loaded.
    [nRF52] [Debug] connect_to_emu_without_snr
    [SeggerBackend] [Debug] is_connected_to_emu
    [SeggerBackend] [Debug] connect_to_emu_without_snr
    [SeggerBackend] [Debug] ---just_get_num_emus
    [SeggerBackend] [Debug] ---just_connect_to_emu_without_snr
    [SeggerBackend] [Debug] Segger logging enabled.
    [JLink] [None] Firmware: J-Link V9 compiled May  7 2021 16:26:12
    [JLink] [None] Decompressing FW timestamp took 193 us
    [JLink] [None] Hardware: V9.10
    [JLink] [None] S/N: 609100402
    [JLink] [None] OEM: SEGGER
    [JLink] [None] Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [JLink] [None] TELNET listener socket opened on port 19021
    [JLink] [None] WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [JLink] [None] WEBSRV Webserver running on local port 19080
    [JLink] [None] - 28.548ms returns "O.K."
    [JLink] [None] JLINK_HasError()
    [JLink] [None] JLINK_Lock()
    [JLink] [None] JLINK_GetHWStatus(...)
    [JLink] [None] - 0.631ms returns 0
    [JLink] [None] JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [JLink] [None] - 0.006ms returns 0x01
    [JLink] [None] JLINK_ExecCommand("DisableFlashDL", ...).
    [JLink] [None] - 0.018ms returns 0x00
    [JLink] [None] JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [JLink] [None] - 0.013ms returns 0x00
    [JLink] [None] JLINK_SetHookUnsecureDialog
    [JLink] [None] JLINK_SetHookUnsecureDialog(...)
    [JLink] [None] - 0.429ms returns 0
    [JLink] [None] JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [JLink] [None] - 2.100ms returns 0x00
    [JLink] [None] JLINK_SetSpeed(4000)
    [JLink] [None] - 0.552ms
    [JLink] [None] JLINK_GetSN()
    [JLink] [None] - 0.208ms returns 609100402
    [SeggerBackend] [Debug] read_debug_port_idr
    [SeggerBackend] [Debug] read_debug_port_register
    [SeggerBackend] [Debug] ---just_read_debug_port_register
    [SeggerBackend] [Debug] coresight_configure
    [JLink] [None] JLINK_CORESIGHT_Configure()
    [JLink] [None] - 101.321ms returns 0
    [SeggerBackend] [Debug] ---just_select_debug_port_register
    [SeggerBackend] [Debug] Select AP 255, DP Bank 0, AP Bank 255
    [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [JLink] [None] - 1.684ms returns -1
    [SeggerBackend] [Error] JLinkARM.dll reported "-1", "An unknown error.".
    [SeggerBackend] [Debug] ---just_abort_debug_action
    [SeggerBackend] [Debug] Attempting to clear any configuration errors in debug port before closing connection.
    [JLink] [None] JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [JLink] [None] - 1.681ms returns -1
    [JLink] [None] - 1.411ms returns -1
    [JLink] [None] - 1.600ms returns -1
    [JLink] [None] - 1.333ms returns -1
    [JLink] [None] - 1.309ms returns -1
    [JLink] [None] - 1.005ms returns -1
    [JLink] [None] - 0.980ms returns -1
    [JLink] [None] - 1.159ms returns -1
    [JLink] [None] - 0.917ms returns -1
    [JLink] [None] - 1.012ms returns -1
    [JLink] [None] - 1.040ms returns -1
    [JLink] [None] - 1.022ms returns -1
    [JLink] [None] - 0.950ms returns -1
    [JLink] [None] - 0.946ms returns -1
    [JLink] [None] - 1.167ms returns -1
    [JLink] [None] - 0.915ms returns -1
    [JLink] [None] - 0.909ms returns -1
    [JLink] [None] - 0.924ms returns -1
    [JLink] [None] - 1.037ms returns -1
    [JLink] [None] - 0.953ms returns -1
    [JLink] [None] - 1.021ms returns -1
    [JLink] [None] - 0.840ms returns -1
    [JLink] [None] - 0.839ms returns -1
    [JLink] [None] - 0.943ms returns -1
    [JLink] [None] - 0.760ms returns -1
    [JLink] [None] - 0.855ms returns -1
    [JLink] [None] - 0.831ms returns -1
    [JLink] [None] - 0.998ms returns -1
    [JLink] [None] - 0.948ms returns -1
    [JLink] [None] - 0.469ms
    [nRF52] [Debug] read_connected_emu_snr
    [JLink] [None] JLINK_IsOpen()
    [JLink] [None] - 0.272ms returns 0x01
    [SeggerBackend] [Debug] read_connected_emu_snr
    [JLink] [None] - 0.304ms
    [nRF52] [Debug] close
    [JLink] [None] - 0.438ms returns 0x01
    [SeggerBackend] [Debug] close
    [SeggerBackend] [Debug] disconnect_from_emu
    [SeggerBackend] [Debug] ---just_disconnect_from_emu
    [SeggerBackend] [Debug] is_connected_to_device
    [JLink] [None] JLINK_IsConnected()
    [JLink] [None] - 2.951ms returns FALSE
    [SeggerBackend] [Debug] ---just_is_debug_region_powered
    [JLink] [None] - 1.035ms returns -1
    [JLink] [None] - 0.862ms returns -1
    [JLink] [None] - 0.920ms returns -1
    [JLink] [None] - 1.053ms returns -1
    [JLink] [None] - 1.032ms returns -1
    [JLink] [None] - 1.033ms returns -1
    [JLink] [None] - 0.857ms returns -1
    [JLink] [None] - 0.824ms returns -1
    [JLink] [None] - 0.885ms returns -1
    [JLink] [None] - 0.801ms returns -1
    [JLink] [None] - 0.983ms returns -1
    [JLink] [None] - 1.027ms returns -1
    [JLink] [None] - 0.921ms returns -1
    [JLink] [None] - 0.951ms returns -1
    [JLink] [None] - 0.818ms returns -1
    [JLink] [None] - 0.829ms returns -1
    [JLink] [None] - 0.886ms returns -1
    [JLink] [None] - 0.985ms returns -1
    [JLink] [None] - 0.792ms returns -1
    [JLink] [None] - 0.834ms returns -1
    [JLink] [None] - 1.138ms returns -1
    [JLink] [None] - 0.826ms returns -1
    [JLink] [None] - 0.955ms returns -1
    [JLink] [None] - 0.853ms returns -1
    [JLink] [None] - 1.004ms returns -1
    [JLink] [None] - 0.938ms returns -1
    [JLink] [None] - 0.815ms returns -1
    [JLink] [None] - 0.468ms
    [JLink] [None] JLINK_Close()
    [SeggerBackend] [Debug] Segger Backend closed.
    [nRF52] [Debug] nRF family DLL closed
    Start
    [JLink] [None] Decompressing FW timestamp took 183 us
    [JLink] [None] - 28.863ms returns "O.K."
    [JLink] [None] - 0.807ms returns 0
    [SeggerBackend] [Error] Low voltage detected in target device.
    [JLink] [None] - 0.498ms
    [SeggerBackend] [Error] Cannot call read_connected_emu_snr when connect_to_emu_without_snr or connect_to_emu_with_snr has not been called.
    Thank you for the logs.
    I have reported the issue internally. I will get back to you when I get more information related to this issue.
    Dejan
    Any information regarding this issue yet ? I have a workaround for now but it, sort of, messes up the logic of my flow.
    \Eric
    There is an update for nRF Command Line Tools. Please update your nRF Command Line Tools to the version 10.16.0.
    Dejan
