ZCL and BDB commands explenation
I'm new to Nordic Zigbee solutions and where to find information so hoping someone can point me in right direction.
Using 2 nrf52840-DK boards. One is flashed with Nordic Zigbee Network coordinator example. The other is the Nordic Zigbee Ligh bulb example.
Using the example default configuration for libraries etc.
I use the BDB and ZCL commands to control coordinator through PuTTY terminal window. See screen shot.
  1. Other than the terminal "help" for API commands syntax, is there some more detailed documentation available?
    I see a lot of ZCL_xx documented definitions but it's unclear how this related to what the valid ZCL and BDB commands are in terminal. Ex: "BDB start" starts a new PAN and open network for 180 sec for zigbee nodes to join.
  2. Is there a "CLOSE" network BDB or ZCL or other command I can use? I don't want to wait 180 sec if device joins quickly. Any suggestions how to close the PAN with a command and not wait for time-out?
  3. I was not able to make "ZCL attr" cmd to work. Are there there any examples of the command on how to read the attributes and clusters supported on a device (the Nordic Zigbee lightbulb as example) It should show support of LIGHT and ON/OFF/DIM.
    I also tried reading a Securafi smart plug that connected to pan with no luck.
Thanks in advance!
