Thread secure DFU example error
I am working on nRF5 Thread 4.1.0 and I am trying to do implement Thread secure DFU.
I am following infocenter.nordicsemi.com/index.jsp
i have run the command
nrfutil dfu thread -f -pkg app_dfu_package.zip -p COM16 --channel 11 --panid 43981 -r 4 -rs 5000 -a FF03::1
I get the following error:
C:\Development\Thread_DFU>nrfutil dfu thread -f -pkg app_dfu_package.zip -p COM16 --channel 11 --panid 43981 -r 4 -rs 5000 -a FF03::1
Using connectivity board at serial port: COM16
Flashing connectivity firmware...
Connectivity firmware flashed.
Waiting for NCP to promote to a router...
Waiting 20s before starting multicast DFU procedure
Thread DFU server is running... Press <Ctrl + D> to stop.
ff03::1: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 3/3 [00:00<00:00, 3.84it/s]
ff03::1: 37%|████████████████████████████████████████████████████████████████████▏ | 2349/6413 [10:37<17:52, 3.79it/s]Exception in thread Upload thread:
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\threading.py", line 973, in _bootstrap_inner
self.run()
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\threading.py", line 910, in run
self._target(*self._args, **self._kwargs)
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\site-packages\nordicsemi\thread\dfu_server.py", line 290, in _upload
self._send_block(remote,
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\site-packages\nordicsemi\thread\dfu_server.py", line 269, in _send_block
self.protocol.request(request)
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\site-packages\piccata\core.py", line 559, in request
return self._transaction_layer.send_request(request, response_callback, response_callback_args, response_callback_kw)
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\site-packages\piccata\core.py", line 442, in send_request
self._message_layer.send_message(request)
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\site-packages\piccata\core.py", line 216, in send_message
self._transport.send(raw_message, message.remote)
File "C:\Users\spx0847\AppData\Local\Programs\Python\Python39\lib\site-packages\nordicsemi\thread\tncp.py", line 184, in send
src_addr = ipaddress.ip_address(self._ml_prefix + b'\x00\x00\x00\xff\xfe\x00' + struct.pack('>H', rloc16))
struct.error: required argument is not an integer
I have tried the solutions from this ticket as I had similar issues at first,
https://devzone.nordicsemi.com/f/nordic-q-a/82416/thread-secure-dfu
But then I get this error.
Python: 3.9.1, nrfutil: 6.1.3, nrfjprog: 10.15.4 external JlinkARM.dll: 7.58b
  • Hi Edvin,
    After many trials, the only thing which works (i.e. atleast the Thread dfu server is running) is original ncp.hex file (from nrfutil-6.1.3) has to be flashed on to the nrf52840 DK before doing the dfu thread package update.
    But now I get a different error.
    After this there is no response from the client side.
    Tushar
  • Hello Tushar,
    It is a bit "sensitive". I believe you need to start the DFU server shortly after the DFU client has started. At least it is possible to see some logging from the client that some things times out after a while. Do you see the log from the client?
    Without knowing the details exactly, I believe that the client stops looking for the DFU server after a given amount of time. But at the same time, I believe you need to turn on the DFU server after the client is promoted to router (or leader) in it's network. Can you test this?
    Edvin
