Can't connect to nRF52840-DK with Python CHIP Controller
I have an issue in regard to Matter. I would like to commision a device in my network, but I don't know why the Python CHIP Controller returns this error every time I try to talk to the device:
chip-device-ctrl > connect -ble 3840 20202021
Device is assigned with nodeid = 171557
[1648823813.002918][34530:34536] CHIP:IN: Prepared unauthenticated message 0x7f808d8f4940 to 0x0000000000000000 (0) of type 0x20 and protocolId (0, 0) on exchange 28181i with MessageCounter:2474507507.
[1648823813.003042][34530:34536] CHIP:IN: Sending unauthenticated msg 0x7f808d8f4940 with MessageCounter:2474507507 to 0x0000000000000000 at monotonic time: 7839668 msec
[1648823813.003077][34530:34536] CHIP:CTL: Network commissioning parameters are required for BLE auto commissioning.
CHIP Error 0x0000002F: Invalid argument
chip-device-ctrl > [1648823813.019544][34530:34534] CHIP:BLE: BLE removing known devices.
[1648823813.024382][34530:34534] CHIP:BLE: BLE initiating scan.
[1648823813.340056][34530:34534] CHIP:BLE: Failed to start discovery: GDBus.Error:org.bluez.Error.InProgress: Operation already in progress
[1648823843.004362][34530:34536] CHIP:SC: PASESession timed out while waiting for a response from the peer. Expected message type was 33
Failed to establish secure session to device: 50
Segmentation fault (core dumped)
I followed the instructions from this video:
https://www.youtube.com/watch?v=kdMJQFDRoss
Has anyone encountered this same issue? Thanks!
  • Hi
    This is the result of trying what you suggest:
    ./chip_tool/chip-tool pairing ble-thread hex:0e080000000000010000000300000f35060004001fffe0020811111111222222220708fde7466588be63af051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0fff8 1 20202021 3840
    CHIP:CTL: Init failure! Operational Cred Issuer: Error 4175 (0x0000104F)
    CHIP:TOO: Run command failure: Error 4175 (0x0000104F)
  • Hi
    When I suggested that you use chip-tool some time ago, I were a bit premature. Our developers say that this will not be ready for use until nRF Connect SDK v1.9.1.
    I suggested this due to a misunderstanding on my part, sorry about that.
    chip-device-ctrl should work fine with v1.9.1, and you had gotten quite some way with that earlier in this case.
    Does it work for you to go back to chip-device-ctrl, so we know we are working with something stable?
    If so, have a look at Working with Python CHIP Controller, specifically the section on "Using Python CHIP Controller for Matter accessory testing". For the chip-device-ctrl, you already downloaded it from releases, right?
    Sigurd Hellesvik
  • Okay,
    So after I consulted the page https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/matter/python_chip_controller_building.html I have the following issues:
    1. After installing the CHIP controller when I try the BLE interface I get the following:
    sudo out/python_env/bin/chip-device-ctrl --bluetooth-adapter=hci2
    CHIP:DIS: Init admin pairing table with server storage.
    CHIP:IN: local node id is 0x000000000001b669
    CHIP:DL: MDNS failed to join multicast group on eth0 for address type IPv4: Inet Error 1016 (0x000003F8): Address not found
    CHIP:DL: MDNS failed to join multicast group on rndis0 for address type IPv4: Inet Error 1016 (0x000003F8): Address not found
    CHIP:DL: MDNS failed to join multicast group on usb0 for address type IPv4: Inet Error 1016 (0x000003F8): Address not found
    CHIP:ZCL: Using ZAP configuration...
    CHIP:ZCL: deactivate report event
    CHIP:CTL: Getting operational keys
    CHIP:CTL: Generating operational certificate for the controller
    CHIP:CTL: Getting root certificate for the controller from the issuer
    CHIP:CTL: Generating credentials
    CHIP:CTL: Loaded credentials successfully
    CHIP:DL: Platform main loop started.
    2022-05-25 17:29:25,177 ChipBLEMgr   INFO     adapter hci2 cannot be found, expect the ble mac address
      File "out/python_env/bin/chip-device-ctrl", line 789, in <module>
        main()
      File "out/python_env/bin/chip-device-ctrl", line 769, in main
        devMgrCmd = DeviceMgrCmd(rendezvousAddr=options.rendezvousAddr,
      File "out/python_env/bin/chip-device-ctrl", line 155, in __init__
        self.bleMgr.ble_adapter_select("hci{}".format(bluetoothAdapter))
      File "/home/iotlab/connectedhomeip/out/python_env/lib/python3.8/site-packages/chip/ChipBluezMgr.py", line 829, in ble_adapter_select
        self.adapter.adapter_register_signal()
    AttributeError: 'NoneType' object has no attribute 'adapter_register_signal'
    2. And so, I run the following command, which works:
    3. After that, when I try to set the previously obtained Active Operational Dataset I get:
    set-pairing-thread-credential 0e080000000000010000000300000f35060004001fffe0020811111111222222220708fde7466588be63af051000112233445566778899aabbccddeeff030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0fff8
    Pairing Thread Credential is nolonger available, use NetworkCommissioning cluster instead.
    4. And finally, if I try to Commission the Matter accessory device over Bluetooth LE I get:
    connect -ble 3840 20202021 1234
    Device is assigned with nodeid = 1234
    CHIP:BLE: New device scanned: E9:1C:51:27:C0:68
    CHIP:BLE: Device discriminator match. Attempting to connect.
    CHIP:BLE: Scan complete notification without an active scan.
    CHIP:DL: Bluez notify CHIPoBluez connection disconnected
    CHIP:IN: Failed to establish BLE connection: Ble Error 6012 (0x0000177C): Remote device closed BLE connection
    CHIP:BLE: no endpoint for sub complete
    Failed to establish secure session to device: 4050
    CHIP:BLE: PASESession timed out while waiting for a response from the peer. Expected message type was 33
    CHIP Error 4050 (0x00000FD2): Timeout
  • Hi
    Do you get the same errors if you use the chip-device-ctrl installed from https://github.com/nrfconnect/sdk-connectedhomeip/releases/tag/v1.9.1?
    Sigurd Hellesvik
  • Hi
    Actually no, after installing it like this and going through the instructions available here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/matter/python_chip_controller_building.html (which you send it to me), I am able to connect to the device by ble and also send commands (turn the ligh bulb on/off), which is Step 6 from the link.
    However, at Step 7, when I try to get ProductName with the command " zclread Basic ProductName 1234 1 0 ", I receive the following error:
    chip-device-ctrl > zclread Basic ProductName 1234 1 0
    Using PASE connection
    [1654072284.640471][271108:271114] CHIP:IN: Prepared secure message 0x7f7a5fce18 to 0x00000000000004D2 (1)  of type 0x2 and protocolId (0, 1) on exchange 33810i with MessageCounter:2809441.
    [1654072284.640541][271108:271114] CHIP:IN: Sending encrypted msg 0x7f7a5fce18 with MessageCounter:2809441 to 0x00000000000004D2 (1) at monotonic time: 773705553 msec
    [1654072284.752556][271108:271114] CHIP:EM: Received message of type 0x5 with protocolId (0, 1) and MessageCounter:15675771 on exchange 33810i
    2022-06-01 10:31:24,753 root         ERROR    For path: Endpoint = 1, Attribute = <class 'chip.clusters.Objects.Basic.Attributes.ProductName'>, got IM Error: InteractionModelError: UnsupportedAttribute (0x86)
    AttributeReadResult(path=AttributePath(nodeId=1234, endpointId=1, clusterId=40, attributeId=3), status=0, value=ValueDecodeFailure(TLVValue=None, Reason=InteractionModelError(<Status.UnsupportedAttribute: 134>)))
    Now, I don't normally require this, I would like to commission the device to my thread network and after that, control it from a WiFi network... How can achieve this?
    Thank you,
    Mihnea Cristian Marin
