I2S data transmission over BLE
I want to send the I2S MIC Raw data through Ble by using ble_nus_send. I have written one application but it triggers a Cmake error. I have attached the log below, Kindly check and guide me to achieve the above
Creating solution I2S_MIC.emProject
-- Application: D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC
-- Zephyr version: 2.6.99 (D:/v1.7.1/zephyr), build: v2.6.99-ncs1-1
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: nrf5340dk_nrf5340_cpuapp
-- Cache files will be written to: D:/v1.7.1/zephyr/.cache
-- Found dtc: D:/v1.7.1/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (D:/v1.7.1/toolchain/opt)
-- Found BOARD.dts: D:/v1.7.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/build_nrf5340dk_nrf5340_cpuapp/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/build_nrf5340dk_nrf5340_cpuapp/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/build_nrf5340dk_nrf5340_cpuapp/zephyr/dts.cmake
Parsing D:/v1.7.1/zephyr/Kconfig
Loaded configuration 'D:/v1.7.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration 'D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/prj.conf'
See also "D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/build_nrf5340dk_nrf5340_cpuapp/CMakeFiles/CMakeOutput.log".
See also "D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/build_nrf5340dk_nrf5340_cpuapp/CMakeFiles/CMakeError.log".
-- Using NCS Toolchain 1.7.1 for building. (D:/v1.7.1/toolchain/cmake)
warning: SPM_NRF_I2S0_NS (defined at D:/v1.7.1/nrf\subsys\spm/Kconfig:334) was assigned the value
'y' but got the value 'n'. Check these unsatisfied dependencies: IS_SPM (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SPM_NRF_I2S0_NS.html and/or look up
SPM_NRF_I2S0_NS in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: BT_CTLR_RX_BUFFERS (defined at subsys/bluetooth\controller/Kconfig:176) was assigned the
value '2' but got the value ''. Check these unsatisfied dependencies: BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_RX_BUFFERS.html and/or look up
BT_CTLR_RX_BUFFERS in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: BT_CTLR_DATA_LENGTH_MAX (defined at subsys/bluetooth\controller/Kconfig:333) was assigned
the value '251' but got the value ''. Check these unsatisfied dependencies: BT_CTLR_DATA_LENGTH
(=n), BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_DATA_LENGTH_MAX.html and/or
look up BT_CTLR_DATA_LENGTH_MAX in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
might be helpful too.
warning: BT_CTLR_PHY_2M (defined at subsys/bluetooth\controller/Kconfig:417) was assigned the value
'y' but got the value 'n'. Check these unsatisfied dependencies: (BT_CTLR_PHY || BT_CTLR_ADV_EXT)
(=n), BT_CTLR_PHY_2M_SUPPORT (=n), BT_CTLR (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_CTLR_PHY_2M.html and/or look up
BT_CTLR_PHY_2M in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/prj.conf:38: warning: attempt to assign the value 'n' to the undefined symbol BT_NUS_SECURITY_ENABLED
D:/v1.7.1/zephyr/samples/Active_Device_code/I2S_MIC/prj.conf:39: warning: attempt to assign the value '100' to the undefined symbol BT_NUS_UART_BUFFER_SIZE
error: Aborting due to Kconfig warnings
CMake Error at D:/v1.7.1/zephyr/cmake/kconfig.cmake:268 (message):
  command failed with return code: 1
  D:/v1.7.1/zephyr/cmake/app/boilerplate.cmake:554 (include)
  CMakeLists.txt:3 (include)
error: cmake failed
create_nordic_project.py failed (1)
Navin
    Questions regarding our LE Audio solution should be directed to your Regional Sales Manager, as we are not able to discuss future releases or roadmaps here on DevZone. If you do not know who the sales manager for your region is, please send me a private message with your location so I may provide you with their contact information.
