Flashing the code to nRF52832 BLE module.
Hi, I need some help on flashing the code to nRF52832 BLE module.
I would like to mention that I am flashing the code to nRF module using ST-link v2 debugger with the help of open-OCD tool.
Whenever, I flash the example hex file provided by nordic (i.e. ble_app_uart_pca10040_s112.hex file), it is flashed successfully and I could see "Nordic_UART" while scanning for BLE.
However, when I try to flash my custom nRF application, only on repetitive flashing I could see the BLE advertisement.
May I know why it occurs this way? i.e. only after flashing the same code multiple times, it's working?
Please help. Thanks in advance.
  • Hi, thank you for your response.
    Yes, modifications are made in ble_app_uart application. I am flashing the hex file to nRF52832 module using ST link v2 debugger with the help of open OCD tool.
    In nRF5SDK, I'm taking the hex file from the location: examples\ble_peripheral\ble_app_uart\pca10040\s112\ses\Output\Release\Exe
    And you are sure that the flash is not erased between flashing the softdevice and the application?
    I am not sure how to verify this, may I know how can I ensure that the flash is not erased?
    Thank you!
  • Sorry for the late reply. I was out of office last week.
    I am not familiar with the open OCD tool, but I guess you don't actively erase the chip between programming the softdevice and the application.
    Have you tried debugging the application? Is your main() function reached? Do you see any log output? I guess RTT Logging isn't supported over ST Link by default.
    What UART pins is your application using? Are the UART pins connected to anything? If not, perhaps you can try to comment out uart_init() and see if the behavior changes. (The application may crash if the UART's RX pin is left floating).
    Please let me know if you have access to debugging and/or any logs.
    BR,
    Edvin
  • Hi, no worries.
    Thank you for your response!
    Correct. I program the softdevice followed by application. I rarely do mass erase.
    Yes, I am not able to debug/log using ST link.
    I am using UART pins 6(TX) and 8(RX). These UART pins are connected to the application chip (STM32MCU).
    No, this is the challenge I'm facing using ST link debugger. I could only flash the code, not able to debug.
    Thank you.
  • Ok, you need to be able to debug to see why the application faults, or whether the application's main() function is reached at all.
    I guess one more thing you can try is to do is:
    Since you need to program the application twice before it starts working. Try to program it only once, and read back the flash. I don't know how to do that with your programmer, but if you get hold of a JLink you can use nRF Command Line Tools and the command "nrfjprog --readcode my_flash_dump.hex" to read it back. Then we can use that to compare the flash after programming it only once, and after programming it twice. Are they identical?
    Edvin
