NRF5340 Max throughput
I have a nrf5340dk communicating with nrf52840 dongle connected to a pc with UART baud rate of 2M.
Connection parameters are:
  • 7.5ms Conn interval
  • 1ms Slave latency
  • 247 MTU
  • 251 DLE
  • 2M PHY
nrf5340dk is configured as nus peripheral.
In the code, there is a high priority thread that is in an infinite loop calling bt_nus_send with a 244 byte buffer and here are the results I get when profiling the packets:
Although, in here it suggest I should be getting a ~1.3 Mbps throughput with 400 ms connection interval, but instead I get this:
I wanted to ask, is there something that needs to be additionally done to get the ~1.3 Mbps throughput or is this the limitation of the hardware, and if someone knows why I get less throughput when I set connection interval to 400 ms.
Additional info:
  • NRF Connect SDK: v1.8.0 and v1.9.1 were used, there was no difference between them
  • PC is running Windows 10, communicating via Blatann library
  • nrf5340's antenna is a few centimeters away from nrf52840 usb dongle
  • Thank you, that was the reason why the throughput was so slow with 400ms connection interval, this is the result I get after changing the event length:
    There are some weird packet issues for the first 20 seconds of the stream tho.
    I only want to circle back to my previous question, would it be possible to achieve 1.3 Mb/s throughput with the nrf52840 dongle or is this the limit of the hardware/default firmware?
  • Glad to hear that it worked.
    I have not been able to reach 1.3 Mb/s with the pc-ble-driver, and I think it's a combination of overhead of having the serialized softdevice communication and latency introduced by the USB transport. Scheduling of USB events on the PC may be delayed by other OS tasks.
