Device reset happening and i can't able to upload the code
In my project i am using  nrf52840 with my custom board and to upload the code through NRF_CONNECT application with soft device its uploading properly but with  segger emmbedded its giving some error like this .please have look and let me know what is the problem.
after this i have add DEBUG in preprocessor definition and i got this
thank you.
    NO, still same problem i have checked with LOG function configurations also, when comment out the uart_init then it advertising properly and when i uncomment it its not working. so i think in the uart_init() declaration for two UART is not correct so can you please have a look once on uart_init() and let me know any issue with declaration.
    static void uart_init(void)
        uint32_t                     err_code1;
        app_uart_comm_params_t const comm_params1 =
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
    #if defined (UART_PRESENT)
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
         uint32_t                     err_code2;
       app_uart_comm_params_t const comm_params2 =
            .rx_pin_no    = RX_PIN1,
            .tx_pin_no    = TX_PIN1,
    #else
        APP_UART_FIFO_INIT(&comm_params1,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code1);
        APP_ERROR_CHECK(err_code1);
         APP_UART_FIFO_INIT(&comm_params2,
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code2);
        APP_ERROR_CHECK(err_code2);
    thank you.
  • Hi
    Okay, I think you have to use the nrf_drv_uart_init() function to initialize the UART1 instance, as the app_uart does not support two UARTs, and the UART1 is recommended to access through the HW driver, while the UART0 can be accessed through app_uart (or the driver).
    Simon
  • Hello ,
    sorry for the late reply,
    As before i mentioned i have declared two nrf_drv_uart_init() in fifo.c but it gives me error so that's why i asked how to declare two UART's i think i am repeating the same thing again and again . please let me know how to declare two UART's and use it.
    thank you.
  • Hi
    Sorry, but you can check out the Serial Power Library example with two UARTEs that is in the nRF5 SDK v16.0.0. It was removed for later versions for some reason, but should show how to set up two UART instances. Here's the source code:
     * Copyright (c) 2018 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdint.h>
    #include <stdbool.h>
    #include <stddef.h>
    #include "nrf.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_power.h"
    #include "nrf_serial.h"
    #include "app_timer.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "boards.h"
    /** @file
     * @defgroup nrf_serial_uartes_example main.c
     * @ingroup nrf_serial_uartes_example
     * @brief Example of @ref nrf_serial usage. Loopback example using two UARTE peripherals.
     *        Please short Arduino SCL and SDA GPIOs to start transmission.
    #define OP_QUEUES_SIZE          3
    #define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
    static void sleep_handler(void)
        __WFE();
        __SEV();
        __WFE();
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config,
                          RX_PIN_NUMBER, ARDUINO_SCL_PIN,
                          RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                          NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED,
                          NRF_UART_BAUDRATE_115200,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY);
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config,
                          ARDUINO_SDA_PIN, TX_PIN_NUMBER,
    #define SERIAL_FIFO_TX_SIZE 32
    #define SERIAL_FIFO_RX_SIZE 32
    NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    #define SERIAL_BUFF_TX_SIZE 1
    #define SERIAL_BUFF_RX_SIZE 1
    NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA,
                          &serial0_queues, &serial0_buffs, NULL, sleep_handler);
    NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA,
                          &serial1_queues, &serial1_buffs, NULL, sleep_handler);
    NRF_SERIAL_UART_DEF(serial0_uarte, 0);
    NRF_SERIAL_UART_DEF(serial1_uarte, 1);
        ret_code_t ret;
        ret = nrf_drv_clock_init();
        APP_ERROR_CHECK(ret);
        ret = nrf_drv_power_init(NULL);
        ret = app_timer_init();
        // Initialize LEDs and buttons.
        bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS);
        ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config);
        ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config);
        static char tx_message[] = "Hello nrf_serial!\n\r";
        ret = nrf_serial_write(&serial1_uarte,
                               tx_message,
                               strlen(tx_message),
                               NULL,
                               NRF_SERIAL_MAX_TIMEOUT);
        (void)nrf_serial_flush(&serial1_uarte, 0);
        while (true)
            char c;
            ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 1000);
            if (ret != NRF_SUCCESS)
                continue;
            (void)nrf_serial_write(&serial0_uarte, &c, sizeof(c), NULL, 0);
            (void)nrf_serial_flush(&serial0_uarte, 0);
            ret = nrf_serial_read(&serial1_uarte, &c, sizeof(c), NULL, 1000);
                continue;
            (void)nrf_serial_write(&serial1_uarte, &c, sizeof(c), NULL, 0);
    Simon
