Mpsl init hard fault
Hello guys,
I am having problems on addressing an issue with my firmware. Maybe someone can assist me to find out the root cause for this, because I don't understand too much of the error log.
The firmware runs smooth for some time (it varies from time to time, but in most cases it runs for several hours before crash).
See below that the firmware stopped logging to RTT (and it stopped working too) at `[15:12:44.837,554]`. It just freezed.
The output from RTT log is only printed out in the serial monitor if I open GDB Server and close it (I don't understand why this happens too).
I am testing the application by simulating beacons in the NRF Connect app in android, simulating several advertising beacons so that this device can keep scanning.
I am using Bluetooth with whitelisting for scanning devices around.
See the log output below:
[15:12:44.837,554] <inf> lora_receive_task: lora tx config
[16:25:42.304,595] <err> mpsl_init: MPSL ASSERT: 108, 530
[16:25:42.304,626] <err> os: ***** HARD FAULT *****
[16:25:42.304,626] <err> os: Fault escalation (see below)
[16:25:42.304,626] <err> os: ARCH_EXCEPT with reason 3
[16:25:42.304,626] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000010 r2/a3: 0x0000000f
[16:25:42.304,656] <err> os: r3/a4: 0x20002760 r12/ip: 0x2000001f r14/lr: 0x00022e3f
[16:25:42.304,656] <err> os: xpsr: 0x6101001b
[16:25:42.304,656] <err> os: Faulting instruction address (r15/pc): 0x00036f52
[16:25:42.304,656] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[16:25:42.304,687] <err> os: Fault during interrupt handling
[16:25:42.304,779] <err> os: Current thread: 0x200024d0 (ble_task_id)
[16:25:43.033,081] <err> os: Halting system
See below projconf:
# choose RTT console
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG=y
CONFIG_PRINTK=n
CONFIG_LOG_PRINTK=n
CONFIG_LOG_DETECT_MISSED_STRDUP=y
CONFIG_LOG_PRINTK_MAX_STRING_LENGTH=1024
CONFIG_LOG_STRDUP_BUF_COUNT=20
CONFIG_LOG_STRDUP_MAX_STRING=1024
CONFIG_NEWLIB_LIBC=y
CONFIG_CBPRINTF_FULL_INTEGRAL=y
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_NEWLIB_LIBC_FLOAT_SCANF=y
CONFIG_NEWLIB_LIBC_NANO=n
CONFIG_DEBUG=y
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_DEBUG_THREAD_INFO=y
# -- Bluetooth LE
CONFIG_BT=y
CONFIG_BT_BROADCASTER=y
CONFIG_BT_DEBUG_LOG=n
CONFIG_BT_CENTRAL=y
# para usar um (1) filtro de nome
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_NAME_CNT=1
# para usar Le Coded Phy (longa distancia)
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_EXT_ADV=y
CONFIG_BT_USER_PHY_UPDATE=y
# para poder utilizar endereço estatico
CONFIG_BT_SMP=y
CONFIG_BT_PRIVACY=n
# para usar advertising estendido
CONFIG_BT_EXT_ADV=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_LL_SW_SPLIT=n
# -- Lora
CONFIG_SPI=y
CONFIG_GPIO=y
CONFIG_LORA=y
CONFIG_LORA_SX12XX=y
# -- Blinky
CONFIG_HEAP_MEM_POOL_SIZE=10240
CONFIG_ASSERT=y
# -- UART
Support Information:
  "platform": {
    "os": "darwin",
    "osVersion": "Darwin Kernel Version 19.6.0: Thu Jan 13 01:26:33 PST 2022; root:xnu-6153.141.51~3/RELEASE_X86_64",
    "osKernel": "19.6.0",
    "vscode": "1.66.1",
    "electron": "17.2.0",
    "node": "v16.13.0"
  "system": {
    "date": "2022-04-09T19:16:53.373Z",
    "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
    "vscodeUptime": "21:12:36",
    "osUptime": "21:14:20",
    "cpu": {
      "model": "Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz",
      "speed": "2500 MHz",
      "count": 2
    "memory": {
      "total": "6.00 GB",
      "free": "0.06 GB"
  "workspace": {
    "name": "cracha",
    "workspaceFile": null,
    "folders": [
      "/Users/thiago/nRF52_apps/cracha"
  "extensions": {
    "internal": {
        "version": "2022.3.104",
        "path": "/Users/thiago/.vscode/extensions/nordic-semiconductor.nrf-connect-2022.3.104",
        "isActive": true
        "version": "2022.3.31",
        "path": "/Users/thiago/.vscode/extensions/nordic-semiconductor.nrf-terminal-2022.3.31",
        "isActive": true
      "nordic-semiconductor.devicetree": null,
      "nordic-semiconductor.kconfig": null
    "external": {
      "marus25.cortex-debug": "1.4.4",
      "ms-vscode.cpptools": "1.9.7",
      "ms-vscode.js-debug": "1.66.1",
      "ms-vscode.js-debug-companion": "1.0.17",
      "ms-vscode.references-view": "0.0.89",
      "ms-vscode.vscode-js-profile-table": "1.0.0",
      "2gua.rainbow-brackets": "0.0.6",
      "bbenoist.Doxygen": "1.0.0",
      "betwo.vscode-doxygen-runner": "1.7.3",
      "cameronbieganek.julia-color-themes": "0.1.1",
      "ceciljacob.code-plus-theme": "1.0.0",
      "cl.stm8-debug": "1.4.1",
      "cschlosser.doxdocgen": "1.4.0",
      "cweijan.vscode-mysql-client2": "5.0.9",
      "dan-c-underwood.arm": "1.7.4",
      "david-j-lee.github-dark-color-theme": "0.3.2",
      "DotJoshJohnson.xml": "2.5.1",
      "eamodio.gitlens": "12.0.5",
      "espressif.esp-idf-extension": "1.4.0",
      "formulahendry.vscode-mysql": "0.4.1",
      "ghgofort.neon-vommit": "1.2.2",
      "go2sh.cmake-integration-vscode": "0.7.1",
      "guobing.material-color": "1.3.2",
      "hancel.serialport-helper": "0.0.15",
      "httpsterio.henna": "0.11.0",
      "IBM.output-colorizer": "0.1.2",
      "jeff-hykin.better-cpp-syntax": "1.15.13",
      "johnpapa.winteriscoming": "1.4.4",
      "KevinRose.vsc-python-indent": "1.15.0",
      "kosz78.nim": "0.6.6",
      "kuscamara.electron": "0.2.6",
      "lucabockmann.midnight-color": "1.4.0",
      "magson.material-dark-color-theme": "0.0.3",
      "Marcelino-Jorge-Romero.matrix-theme": "0.0.1",
      "MaxfieldWalker.vscode-color-theme-spirited-away": "1.3.2",
      "mechatroner.rainbow-csv": "2.2.0",
      "ms-azuretools.vscode-docker": "1.21.0",
      "ms-python.python": "2022.4.1",
      "ms-python.vscode-pylance": "2022.4.0",
      "ms-toolsai.jupyter": "2022.3.1000901801",
      "ms-toolsai.jupyter-keymap": "1.0.0",
      "ms-toolsai.jupyter-renderers": "1.0.6",
      "ms-vscode-remote.remote-containers": "0.231.5",
      "ms-vscode-remote.remote-ssh": "0.78.0",
      "ms-vscode-remote.remote-ssh-edit": "0.80.0",
      "ms-vscode-remote.remote-wsl": "0.66.0",
      "ms-vscode.cpptools-extension-pack": "1.1.0",
      "ms-vscode.cpptools-themes": "1.0.0",
      "mtxr.sqltools": "0.23.0",
      "mtxr.sqltools-driver-mysql": "0.2.0",
      "octref.vetur": "0.35.0",
      "oguhpereira.spotify-color-theme": "1.3.0",
      "PauloSouza.matrix-revolution-color-theme": "0.0.1",
      "PKief.material-icon-theme": "4.15.0",
      "redhat.vscode-yaml": "1.6.0",
      "Roghib.nani": "1.1.2",
      "tal7aouy.theme": "2.2.0",
      "twxs.cmake": "0.0.17",
      "UstymUkhman.matrix-theme": "0.1.2",
      "yile-ou.paddy-color-theme": "1.9.3",
      "Youssef.viow": "0.3.3",
      "zary-dev.Zary": "1.3.0"
  "tools": {
    "/Applications/SEGGER/JLink/JLinkExe": "7.60c",
    "/usr/local/bin/nrfjprog": "10.15.4",
    "nrfutil": "Not found",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/cmake": "3.21.1",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/west": "0.12.0",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/python3": "3.9.6",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/ninja": "1.10.2",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/gperf": "3.1",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/dtc": "1.6.1",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/arm-none-eabi-gcc": "9-2019-q4-major",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/gn": "1977",
    "/opt/nordic/ncs/v1.9.1/toolchain/bin/git": "2.32.0"
  "sdks": [
      "version": "1.9.1",
      "path": "/opt/nordic/ncs/v1.9.1"
  "toolchains": [
      "version": "1.9.1",
      "path": "/opt/nordic/ncs/v1.9.1/toolchain"
  "connectedDevices": [
      "serialNumber": "683771177"
  "deviceProviders": [
    "nrfjprog"
  "config": {
      "topdir": "${nrf-connect.sdk:1.9.1}",
      "toolchain": {
        "path": "${nrf-connect.toolchain:1.9.1}"
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}"
      "kconfig": {
        "interface": "menuconfig"
      "welcome": {
        "showOnStartup": true
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": true
      "terminalMode": "character"
    "nordic-semiconductor.devicetree": {
      "modules": [
        "${zephyrBase}",
        "${zephyrBase}/../nrf",
      "zephyr": "",
      "ctxFile": "",
      "defaultBoard": ""
    "nordic-semiconductor.kconfig": {
      "root": "",
      "env": {},
      "cfiles": true,
      "disable": false,
      "zephyr": {
        "base": ""
      "python": "",
      "liveValue": true
    "marus25.cortex-debug": {
      "armToolchainPath": null,
      "armToolchainPrefix": "arm-none-eabi",
      "gdbPath": null,
      "objdumpPath": null,
      "JLinkGDBServerPath": null,
      "openocdPath": null,
      "pyocdPath": null,
      "PEGDBServerPath": null,
      "stutilPath": null,
      "stlinkPath": null,
      "stm32cubeprogrammer": null,
      "enableTelemetry": true,
      "flattenAnonymous": false,
      "registerUseNaturalFormat": true,
      "variableUseNaturalFormat": true,
      "dbgServerLogfile": null,
      "showRTOS": false,
      "showDevDebugOutput": "none"
  "environment": {
    "westExe": "/opt/nordic/ncs/v1.9.1/toolchain/bin/west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "GIT_EXEC_PATH": "/opt/nordic/ncs/v1.9.1/toolchain/Cellar/git/2.32.0_1/libexec/git-core",
      "HOME": "/Users/thiago",
      "PATH": "/opt/nordic/ncs/v1.9.1/toolchain/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin",
      "ZEPHYR_BASE": "/opt/nordic/ncs/v1.9.1/zephyr",
      "GNUARMEMB_TOOLCHAIN_PATH": "/opt/nordic/ncs/v1.9.1/toolchain",
      "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
      "USER": "thiago"
    "toolchainPath": "/opt/nordic/ncs/v1.9.1/toolchain",
    "toolchainBinPath": "/opt/nordic/ncs/v1.9.1/toolchain/bin",
    "toolchainVersion": "1.9.1"
  "terminal": {
    "shell": null,
    "defaultProfile": null
