Wpantund program initialization failed when hardware flow control was enabled in coprocessor code
Hi
I plan to enable hardware flow control in the coprocessor code. After successful compilation and burning, I will use Ubuntu to start wpantund and an error will be reported
When I comment out hw-flow-control in my overlay file,wpantund starts normally
Is there any way I can successfully start and initialize wpantund using hardware flow control
  • Hi
    I entered the msddisable command on the j-link commander tool,The test results have not changed and wpantund still cannot be initialized.
    Ethan
  • Hi
    I tried to set up wpantund following the tutorial found in Thread tools, wpantund, with our sample nrf/samples/openthread/coprocessor build with the command:
    west build -b nrf52833dk_nrf52833 -- -DCONFIG_OPENTHREAD_THREAD_VERSION_1_2=y
    No changes to the overlays, so hw-flow-control should be enables.
    Here are the versions I used:
    nRF Connect SDK: v1.9.1
    wpantund: master (25dd5d02dedc5e13f28b6fa72674f3486fa0e404)
    Ubuntu LTS 20.04
    I were able to run wpantund successfully:
    $ sudo wpantund -I leader_if -s /dev/ttyACM0 -b 1000000
    wpantund[30072]: Starting wpantund 0.08.00d (Apr 12 2022 08:40:55) . . .
    wpantund[30072]: 	SOURCE_VERSION = 0.07.01-365-g25dd5d0-dirty
    wpantund[30072]: 	BUILD_VERSION = 0.07.01-365-g25dd5d0-dirty
    wpantund[30072]: Configuration file "/usr/local/etc/wpantund.conf" read.
    wpantund[30072]: Ready. Using DBUS bus ":1.189"
    wpantund[30072]: Running as root without dropping privileges!
    wpantund[30072]: State change: "uninitialized" -> "offline"
    wpantund[30072]: NCP is running "OPENTHREAD/thread-reference-20200818-ncs1-rc3-560-g02e61a2ed; Zephyr; Apr 12 2022 08:44:25"
    wpantund[30072]: Driver is running "0.08.00d (0.07.01-365-g25dd5d0-dirty; Apr 12 2022 08:40:55)"
    wpantund[30072]: Network is not joinable
    wpantund[30072]: [-NCP-]: SLAAC enabled
    wpantund[30072]: Resetting interface(s). . .
    wpantund[30072]: Finished initializing NCP
    Are you able to make it work following the steps I explained above?
    Sigurd Hellesvik
  • Hi
    Thank you for your answer
    The environment we use is different.
    nRF Connect SDK: v1.8.0
    Ubuntu 18.04 LTS
    wpantund The version is not up to date,
    Could you please do the test on THE NCS of V1.8.0? We do not want to update the VERSION of NCS at present.
    Ethan
  • Hi
    I measure my CTS pin is always high level, this should be wrong phenomenon, I think the problem may be here,I've turned CTS-pull-up off.
    Ethan
  • Hi
    I can use flow control now.There should be a problem with my configuration file, wpantund related
    Ethan
