Acceleration values on the LTE terminal for nRF9160
I'm using the default software to check the acceleration values when there is a movement in the Thingy:91 on the LTE Monitor terminal.
The document says that this type of output should be seen on the console: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.9.1/zephyr/samples/sensor/adxl362/README.html#adxl362
But I'm unable to see anything on the console when I move the Thingy:91. Could you please tell me how to see the values acceleration values on the console?
  • West is installed and working properly where I had some security issues to build.
    Currently, the command which was provided above is not working as shown in the below screenshot, could you help me with the command to build the system?
  • Hello Harish,
    The build command in the picture looks correct to me. What happens if you type:
    user@user-ubu:~/ncs/nrf/applications/asset_tracker_v2$ west --version
    West version: v0.13.1
    Do you still get a similar result as shown above?
    By the way: it would help a lot if you could share the terminal output in text format, preferably using the Insert → Code functionality here in DevZone. Analysing logs from a picture is quite a pain in the back.
    Thanks & regards,
    Markus
