nRF52840 SDK16 - nrf_fstorage: addr_is_within_bounds(p_fs, dest, len) check failed in nrf_fstorage_write() with value 0x10.
Hi guys,
I try to integrate the flash logger backend
When I run the code I get the following error:
<error> nrf_fstorage: addr_is_within_bounds(p_fs, dest, len) check failed in nrf_fstorage_write() with value 0x10.
This is the sdk_config section
// <e> NRF_LOG_BACKEND_FLASH_ENABLED - nrf_log_backend_flash - Log flash backend
#ifndef NRF_LOG_BACKEND_FLASH_ENABLED
#define NRF_LOG_BACKEND_FLASH_ENABLED 1
// <e> NRF_LOG_BACKEND_FLASHLOG_ENABLED - Enable flashlog backend.
#ifndef NRF_LOG_BACKEND_FLASHLOG_ENABLED
#define NRF_LOG_BACKEND_FLASHLOG_ENABLED 1
// <o> NRF_LOG_BACKEND_FLASHLOG_QUEUE_SIZE - Logger messages queue size.
// <i> Queue holds log messages pending to be written to flash.
// <i> Note that the queue holds logger messages and thus the queue size determines
// <i> increasing the pool of logger messages (see log message pool configuration).
#ifndef NRF_LOG_BACKEND_FLASHLOG_QUEUE_SIZE
#define NRF_LOG_BACKEND_FLASHLOG_QUEUE_SIZE 8
// </e>
// <e> NRF_LOG_BACKEND_CRASHLOG_ENABLED - Enable crashlog backend.
#ifndef NRF_LOG_BACKEND_CRASHLOG_ENABLED
#define NRF_LOG_BACKEND_CRASHLOG_ENABLED 1
// <o> NRF_LOG_BACKEND_CRASHLOG_FIFO_SIZE - Number of log messages held to be flushed in panic.
// <i> Crashlog FIFO always keeps a defined number of the most
// <i> recent logs (severity level is set on runtime).
// <i> Note that the FIFO holds logger messages and thus the FIFO size determines
#ifndef NRF_LOG_BACKEND_CRASHLOG_FIFO_SIZE
#define NRF_LOG_BACKEND_CRASHLOG_FIFO_SIZE 8
// </e>
// <o> NRF_LOG_BACKEND_FLASH_SER_BUFFER_SIZE - Size of the buffer used for serialize log message.
// <i> Message is trimmed if it is longer. It may happen in case of
// <i> hexdump message. Buffer size must be multiple of 4.
#ifndef NRF_LOG_BACKEND_FLASH_SER_BUFFER_SIZE
#define NRF_LOG_BACKEND_FLASH_SER_BUFFER_SIZE 64
// <h> Flash log location - Configuration of flash area used for storing the logs.
// <o> NRF_LOG_BACKEND_FLASH_START_PAGE - Starting page.
// <i> If 0, then pages directly after the application are used.
#ifndef NRF_LOG_BACKEND_FLASH_START_PAGE
#define NRF_LOG_BACKEND_FLASH_START_PAGE 0
// <o> NRF_LOG_BACKEND_PAGES - Number of pages.
#ifndef NRF_LOG_BACKEND_PAGES
#define NRF_LOG_BACKEND_PAGES 1
// </h>
// </e>
This is my flashlog init function:
void flashlog_init(void) {
  ret_code_t ret;
  int32_t backend_id;
  ret = nrf_log_backend_flash_init(&nrf_fstorage_sd);
  APP_ERROR_CHECK(ret);
  backend_id = nrf_log_backend_add(&m_flash_log_backend, NRF_LOG_SEVERITY_WARNING);
  APP_ERROR_CHECK_BOOL(backend_id >= 0);
  backend_id = nrf_log_backend_add(&m_crash_log_backend, NRF_LOG_SEVERITY_INFO);
  nrf_log_backend_enable(&m_flash_log_backend);
  nrf_log_backend_enable(&m_crash_log_backend);
The error returns from nrf_fstorage_write() when calling the NRF_FSTORAGE_PARAM_CHECK(addr_is_within_bounds(p_fs, dest, len), NRF_ERROR_INVALID_ADDR)
What am I missing?
