displaying numeric's characters with HID Keyboard in BLE, azerty Keyboard
I would like display all keycode azerty Keyboard, I started to use uart_event_handle() and I modified send_key_scan_press_release() for the modifier position key [MODIFIER_KEY_POS]. When I connected to smartphone and I receive the character 'c', I display 5 keys: 12345 and when I receive the character 'd', I display 5 keys : &é"'( it's OK. but when I receive the character 'e' , I display: 123'( . I just added for case 'e' the line kb_key_shift_ctrl_alt_altgr = NO_SPECIFIC_KEY_CODE; after while(size < MAX_KEYS_IN_ONE_REPOR)
I can't understand why the SHIFT key seems to be released on the fourth character. 123' (normally number 4) then 5?
static uint8_t m_sample_key_press_scan_str_number[] = /**< Key pattern to be sent when the key press button has been pushed. */
    0x1E,
    0x1F,
    0x20,
    0x21,
    0x22,
    0x28        /* Key Return */
uint8_t kb_key_shift_ctrl_alt_altgr;  // variable for input report MODIFER_KEY_POS, see macro SHIFT_KEY_CODE, CTRL_KEY_CODE....
void uart_event_handle(app_uart_evt_t * p_event)					//$at_06_04_22
	uint8_t message[UARTE_MAX_DATA_LEN] = "UART OK";
	uint8_t message_erase_bonds[] = "wait cmd Erase bonds";
	uint8_t i;
	static uint8_t * p_key = m_sample_key_press_scan_str;
    static uint8_t   size  = 0;
    static uint8_t data_array[UARTE_MAX_DATA_LEN];
    static uint8_t index = 0;
    //uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
			switch(data_array[0])
				case 'a':
					for (i = 0; i < strlen((const char*)message_erase_bonds); i++)
						app_uart_put(message_erase_bonds[i]);
				case 'b':
					advertising_start(true);
				case 'c':
					p_key = m_sample_key_press_scan_str_number;
					kb_key_shift_ctrl_alt_altgr = SHIFT_KEY_CODE;
					size = 0;
					if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
						while (size < MAX_KEYS_IN_ONE_REPORT)
							keys_send(1, p_key);
							p_key++;
							size++;
				case 'd':
					size = 0;
							p_key++;
							size++;
				case 'e':
					size = 0;
							p_key++;
							size++;
					for (i = 0; i < strlen((const char*)message); i++)
						app_uart_put(message[i]);
        case APP_UART_FIFO_ERROR:
static uint32_t send_key_scan_press_release(ble_hids_t * p_hids,
                                            uint8_t    * p_key_pattern,
                                            uint16_t     pattern_len,
                                            uint16_t     pattern_offset,
                                            uint16_t   * p_actual_len)
    ret_code_t err_code;
    uint16_t offset;
    uint16_t data_len;
    uint8_t  data[INPUT_REPORT_KEYS_MAX_LEN];
    // HID Report Descriptor enumerates an array of size 6, the pattern hence shall not be any
    // longer than this.
    STATIC_ASSERT((INPUT_REPORT_KEYS_MAX_LEN - 2) == 6);
    ASSERT(pattern_len <= (INPUT_REPORT_KEYS_MAX_LEN - 2));
    offset   = pattern_offset;
    data_len = pattern_len;
    do
        // Reset the data buffer.
        memset(data, 0, sizeof(data));
        // Copy the scan code.
        memcpy(data + SCAN_CODE_POS + offset, p_key_pattern + offset, data_len - offset);
        if (bsp_button_is_pressed(SHIFT_BUTTON_ID))
            data[MODIFIER_KEY_POS] |= SHIFT_KEY_CODE;
		data[MODIFIER_KEY_POS] |= kb_key_shift_ctrl_alt_altgr;			//$at_12_04_22
        if (!m_in_boot_mode)
            err_code = ble_hids_inp_rep_send(p_hids,
                                             INPUT_REPORT_KEYS_INDEX,
                                             INPUT_REPORT_KEYS_MAX_LEN,
                                             data,
                                             m_conn_handle);
            err_code = ble_hids_boot_kb_inp_rep_send(p_hids,
                                                     data,
                                                     m_conn_handle);
        if (err_code != NRF_SUCCESS)
        offset++;
    while (offset <= data_len);
    *p_actual_len = offset;
    return err_code;
thanks for help
Alexandre
