Linker giving error when building the ble_app_alert_notification_pca10028_s130
I have installed Segger Studio for ARM v6.22a.
I have also installed the SDK5 version 12.3.0.
I imported the IAR project project  ble_app_start_notification_pca10028_s130 (.eww file)
I also selected internal toolchain on the popup.
I also followed the directions followed for importing KEIL projects into the workspace :https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/segger-embedded-studio-a-cross-platform-ide
I was not able to "import section placement" as the option is not showing up when I right click on the project name. Is it because I am using a non commercial license?
Now when I do the build I get a whole lot of linker errors.
Can you please tell me what I am missing?
Please see error image below:
Rajkumar
  • Hi
    The nRFGo Studio app is outdated at this point and it's strongly recommended using the Programmer app in the nRF Connect for Desktop Programmer application instead.
    Simon
  • Hi Simon,
    Actually I was able to finally flash the softdevice-130 using the nrfgo. I am using nrf51422xxxac.
    I was able to then flash the application using the debugger. However the ble_stack_init() function when it calls sd_softdevice_enable, hits the app_error handler function with error code 8. I have not made any changes to the application, so I was wondering why I am getting this error all the time. I have tried multiple times. I have also tried with other applications.
    My RAM and flash settings are:
    FLASH1 RX 0x1B000 0x00025000;RAM1 RWX 0x200013C8 0x00006c38
    Please tell me where I am going wrong. Thanks.
    regards,
    Rajkumar
  • Hi Simon,
    Sorry, I noticed that I had #defined my "SRAM_segment_end__" to resolve the previous undefined reference error. Now I followed the flash_placement steps and have renamed FLASH to FLASH1 and SRAM to SRAM1.
    I am getting the following error now:
    cannot find run section .fast_run referenced in fast
    Here, attached is my flash_placement.xml. Can you please tell me what is wrong? Thanks.
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="$(FLASH_NAME:FLASH1)">
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START:)" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" runin=".fs_data_run" name=".fs_data" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
      </MemorySegment>
      <MemorySegment name="$(RAM_NAME:RAM);SRAM1">
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START:$(SRAM_START:))" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" keep="Yes" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" />
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
      <MemorySegment name="$(FLASH2_NAME:FLASH2)">
        <ProgramSection alignment="4" load="Yes" name=".text2" />
        <ProgramSection alignment="4" load="Yes" name=".rodata2" />
        <ProgramSection alignment="4" load="Yes" runin=".data2_run" name=".data2" />
      </MemorySegment>
      <MemorySegment name="$(RAM2_NAME:RAM2)">
        <ProgramSection alignment="4" load="No" name=".data2_run" />
        <ProgramSection alignment="4" load="No" name=".bss2" />
      </MemorySegment>
    </Root>
  • Hi Simon,
    After the last error of "
    cannot find run section .fast_run referenced in fast,
    I changed the "RAM_NAME=RAM" to "RAM_NAME="RAM1" and now I am getting the following error:
    undefined reference to `__RAM_segment_end__'
    I am attaching my last flash_placement file here for your reference. This error is not going away. Please check this one.
      </MemorySegment>
      <MemorySegment name="$(RAM_NAME:RAM1);SRAM">
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
    </Root>
  • Hi Simon,
    Can you please clarify the above? Thanks.
    regards,
    Rajkumar
