How to Interface nRF9160 with external MCU for nb-IOT control using AT commands?
I have this development board https://www.nordicsemi.com/Products/Development-hardware/nRF9160-DK .  I would like to use development board as nb-IOT modem and other MCU to control it send data over  nb-IOT modem using AT commands, it is possible to do this?
I have tested this board with nRF desktop software using 2G network and AT command.
As of now, I don't  have nb-IOT sim card available to test, so not able to test.
Query targeting MCU interface :
1) Which RX, TX pin of nRF9160 would be used to control over MCU?
2) Which SDK should I use for AT command functionality?
3) what other changes are needed to work with nb-IOT network ?
please suggest if there is any reference example available for this purpose.
Any help will be appreciated.
Thanks & Regards,
Ashvin
  • Hi
    Thanks for your reply.
    I am able change UART2 pins to another pins and tested with at commands.  UART communication is working now.
    Now, I am trying to detect the SIM card in custom board with AT commands, but getting error in response. I think SIM_1V8 voltage is not getting generated from nRF91.
    I am not using eSIM.
    Test case :
    Measuring Voltage on SIM_1V8 (Pin 49) in DK :
    1) When sim card is connected with DK board and sending AT commands AT+CFUN=1, I am getting 1V8 on P30.
    2) When sim card is not connected with DK board and sending same commands, I am not getting 1V8 on P30.
    3) Only connecting sim card but not getting voltage on P30.
    Is there any SIM_DET pin is being used inside DK board? which is being used for sim inserted into  socket or not.
    I have checked layout of DK board for sim detect but did not found any pin which is connected to sim socket.
    I am following this ref links for sim interface
    NOTE: SIM_1V8 is not getting generated in custom board.
    Custom board AT test.
    AT
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CPIN?
    ERROR
  • Can you create a separate ticket for these questions? They seem to deviate a bit from the original question.
