Random hangs and crashes when sending IPC messages from netcore to appcore
There is already a case on github:
https://github.com/zephyrproject-rtos/zephyr/issues/44586
But essentially we see an issue with nrf5340, where we get random crashes and hangs when sending IPC messages from netcore to appcore. I have created a pretty barebone application which is linked to in the github issue that recreates the issue. I have ordered some nrf5340dk kits, but have not received them yet, but it should be pretty straight forward to port this application to nrf5340dk. The issue seems also very hardware dependent, and currently we only got two devices where the issue happens often, but it happens on all of our devices.
The application is sending a message from the netcore to the application core every second which then logs it using the logging infrastructure. The logging backbone is UART. What we see is that the application either hangs (most common) or reboots both with and without core dumps.
  • Could you share your build/zephyr/zephyr.dts file? If there's more than one uart enabled, we'll need to disable RX on all of them.
    Did you try to run the same sequence of stopping UART RX on the netcore as well?
    Håkon
  • appcore_zephyr.dtsnetcore_zephyr.dts
    I disabled RX on UART instance 0 on netcore,
    NRF_UARTE0->TASKS_STOPRX = 1;
    while(NRF_UARTE0->EVENTS_RXTO == 0);
    NRF_UARTE0->EVENTS_RXTO = 0;
    And I disabled RX on UART instance 0 and 3 on appcore,
    NRF_UARTE3->TASKS_STOPRX = 1;
    while(NRF_UARTE3->EVENTS_RXTO == 0);
    NRF_UARTE3->EVENTS_RXTO = 0;
    This has been working without any crash for 18 minutes as of when I write this. This unusual on this device, but I will have to run it for much longer to be sure that this worked.
    I will however need RX on UART3 on appcore in the production firmware.
  • Unfortunately it seems like it still crashes. I ran a test with both our production firmware and the test application, both finally crashed. The test application is harder to crash now, but the production code (based on one run) crashed much faster than expected.
  • You have both UART0 and UART3 enabled on the appcore - are you using both these?
    Try disabling the unused uart in dts, in case this one is causing problems.
    Håkon
  • Yes, on appcore use UART0 for logging and UART3 for some communication we need in some cases. On netcore I use UART0 for logging. I may be able to disable logging in production because we currently don't have any interface to get that from the device in production. I was actually planning to run a test this weekend to se if the crashes is gone if I do that.
