Implementing DFU trigger library
Board: nRF52833
SoftDevice: s140
SDK version: 17.0.2
I am trying to implement OTA buttonless DFU feature in my custom device (USB Device) which is a central device. So I integrated the buttonless DFU feature into my application and tested it in my nRF52833 DK and it works fine. When testing in my USB custom device it gives a "Bootloader not found" error. Seems like I need to add the DFU trigger library to enter the bootloader.
1. Am I right here?
Then I integrated the DFU trigger library as given in the example \examples\connectivity\ble_connectivity\Main.c. I got the "This module is intended to be used with boards that have the GP pin shortened with the RESET pin." error message. So I've defined the P0.18 pin to BSP_SELF_PINRESET_PIN as it was given in the nRF52833 pinout and the error message went out.
2. Can I use pin 18 as the reset pin to trigger RESET pin as I have no other GPIO connected to it?
Then I tried to test the application but still, I am getting the same error.
How can I solve this issue? Thanks in advance.
    Please check if you have 32kHz crystal on your board ?
    We have an internal 32MHz crystal but no low-frequency 32kHz crystal connected to it. Is it important to have connected?
    If you only flash the softdevice + bootloader would it advertise DFUTarg ?
    No, it doesn't advertise as Dfutarg. When I debug I am getting the following in the log
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: Boot validation failed. No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_stop (0x20002B04)
    <debug> app: timer_activate (0x20002B04)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_ble: Initializing BLE DFU transport
    <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
    <debug> nrf_dfu_ble: Enabling SoftDevice.
    <debug> nrf_dfu_ble: Configuring BLE stack.
    <debug> nrf_dfu_ble: Enabling the BLE stack.
    <debug> nrf_dfu_ble: No advertising name found
    <debug> nrf_dfu_ble: Using default advertising name
    <debug> nrf_dfu_ble: Advertising...
    <debug> nrf_dfu_ble: BLE DFU transport initialized.
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
    <debug> app: Enter main loop
    Appriciate your help.
  • Hi Nabeel,
    If you don't have 32kHz crystal you would need to configure the softdevice to use the 32kHz RC instead.
    Have you tested any BLE example in the SDK ?  Did it work ?
    You would need to change NRF_SDH_CLOCK_LF_SRC configuration in sdk_config.h from 1 to 0 to select the RC instead of the crystal.
    And NRF_SDH_CLOCK_LF_ACCURACY to 0, NRF_SDH_CLOCK_LF_RC_CTIV   to 16 and NRF_SDH_CLOCK_LF_RC_TEMP_CTIV  to 2.
    I've tested flashing ble_app_uart and usbd_ble_uart examples. It didn't advertise.
    It's already in this configuration.
    Please try to debug and check if you get any error/assert.
    I've flashed the usbd_ble_uart example and tried to debug. My debug terminal didn't work but still, I was able to step into the code. My debugging stopped in the ble_stack_init(); function, most particularly in SVCALL(SD_SOFTDEVICE_ENABLE, uint32_t, sd_softdevice_enable(nrf_clock_lf_cfg_t const * p_clock_lf_cfg, nrf_fault_handler_t fault_handler)); function def in nrf_sdm.h file. Though I can't able to access the debug terminal, I'm unable to check what error/assert msg I'm getting.
