Cannot loop send() when trying to send large data in https_client sample on nRF9160
Hi everyone,
I want to send large data with https protocol.
I edited the https_client sample split the data and looped send() for sending the large data.
But when I did send() once, I got error 128. Did the socket close by itself?
After I run send() once, I run close() -> tls_setup() ->connect() again. Then I can do send() again.
This is very time consuming, in a single loop, reconnecting takes 2 or 3 seconds in my environment. So I need a different solution.
Is it possible to loop send() continuously with the socket open? In the past, there have been similar case with the http protocol, but it seems that closing the socket with every send() is the solution.
https://devzone.nordicsemi.com/f/nordic-q-a/46086/nrf9160-dk-http-post-to-my-webserver
Is this still not improving? If I can send quickly even if I close the socket, it may be a solution.
HW:nRF9160DK
FW:modem v1.3.1
SDK v1.9.1
My LTE connection is LTE-M.
Best Regards,
Yukio Oyama
  • My sending data size is not fixed, it is dangerous to set the waiting time to a fixed value.
    One solution then would be to always wait as if you're sending the longest packet you'll be sending, but I agree this is not optimal.
    Can I receive AT notifications after using send()?
    I believe the send() function is actually sending AT-commands to the modem under the hood, which would mean the AT notifications are also there, you'd just have to catch them in your application.
    does the chunk mode of AT#XHTTPCREQ deal with the buffer problem for repeated sending without any countermeasure?
    Have you tried using this AT command? I thought these SLM-specific AT commands were specifically for the Serial LTE Modem application. Though if it works it works, never hurts to try.
    Is there an example of AT command execution in chunk mode?
    Not that I know of.
    When I run recv(), it takes 5-7 seconds to respond.
    Sounds strange, but I could imagine it being due to something like the client not expecting the server to be keep-alive, and waiting for it to terminate the connection?
    Do you know exactly what function call is taking long? Is it recv()?
    You can probably set the timeout to be shorter somehow, maybe with a flag in the recv command.
    It might also be the case that you could set an option for the socket to prevent recv from waiting for a message if no message is available:
    If no messages are available at the socket and O_NONBLOCK is not set on the socket's file descriptor, recv() shall block until a message arrives.
    Einar
  • Hi Einar-san,
    I haven't successfully changed the code to receive AT notifications, but I'm still trying it.
    1, According to your link,
    setsockopt () has a SO_KEEPALIVE option whose initial value seems to be off.
    Do I need to turn this option on to keep keep-alive in http protocol?
    2. Native TLS does not support session resumption according to this thread and this URL.
    I don't understand the configuration of the Config file, so in the https_client sample I can't understand whether TLS is offloaded to the modem or using native TLS. I'm based on the https_client sample, will TLS be offloaded to the modem? I haven't made any TLS related changes in the cfg file. The TLS settings in the cfg file are the same as the https_client sample settings.
    3,Today, I used the Modem shell App and iperf3 to check the effective speed of the uplink in my environment.
    It was 100K ~ 180Kbps.
    *** Booting Zephyr OS build v2.6.0-rc1-ncs1  ***
    Flash regions		Domain		Permissions
    00 01 0x00000 0x10000 	Secure		rwxl
    02 31 0x10000 0x100000 	Non-Secure	rwxl
    Non-secure callable region 0 placed in flash region 1 with size 32.
    SRAM region		Domain		Permissions
    00 07 0x00000 0x10000 	Secure		rwxl
    08 31 0x10000 0x40000 	Non-Secure	rwxl
    Peripheral		Domain		Status
    00 NRF_P0               Non-Secure	OK
    01 NRF_CLOCK            Non-Secure	OK
    02 NRF_RTC0             Non-Secure	OK
    03 NRF_RTC1             Non-Secure	OK
    04 NRF_NVMC             Non-Secure	OK
    05 NRF_UARTE1           Non-Secure	OK
    06 NRF_UARTE2           Secure		SKIP
    07 NRF_TWIM2            Non-Secure	OK
    08 NRF_SPIM3            Non-Secure	OK
    09 NRF_TIMER0           Non-Secure	OK
    10 NRF_TIMER1           Non-Secure	OK
    11 NRF_TIMER2           Non-Secure	OK
    12 NRF_SAADC            Non-Secure	OK
    13 NRF_PWM0             Non-Secure	OK
    14 NRF_PWM1             Non-Secure	OK
    15 NRF_PWM2             Non-Secure	OK
    16 NRF_PWM3             Non-Secure	OK
    17 NRF_WDT              Non-Secure	OK
    18 NRF_IPC              Non-Secure	OK
    19 NRF_VMC              Non-Secure	OK
    20 NRF_FPU              Non-Secure	OK
    21 NRF_EGU1             Non-Secure	OK
    22 NRF_EGU2             Non-Secure	OK
    23 NRF_DPPIC            Non-Secure	OK
    24 NRF_REGULATORS       Non-Secure	OK
    25 NRF_PDM              Non-Secure	OK
    26 NRF_I2S              Non-Secure	OK
    27 NRF_GPIOTE1          Non-Secure	OK
    SPM: NS image at 0x10000
    SPM: NS MSP at 0x200294f0
    SPM: NS reset vector at 0x24c69
    SPM: prepare to jump to Non-Secure image.
    MOSH version:       v1.6.0
    MOSH build id:      custom
    MOSH build variant: dev
    Initializing modemlib...
    mosh:~$ Initialized modemlib
    Network registration status: searching
    mosh:~$ LTE cell changed: Cell ID: 77815387, Tracking area: 9252
    mosh:~$ Currently active system mode: LTE-M
    mosh:~$ RRC mode: Connected
    mosh:~$ RRC mode: Idle
    mosh:~$ at at+cfun?
    +CFUN: 1
    OK
    mosh:~$ at at+cfun=0
    Network registration status: not registered
    OK
    mosh:~$ at at+cfun=1
    OK
    mosh:~$ at at+cereg?
    +CEREG: 0,1,"2424","04A35E5B",7
    OK
    mosh:~$ at at+cgatt?
    +CGATT: 1
    OK
    mosh:~$ at at+cgact?
    +CGACT: 0,1
    OK
    mosh:~$ at at+cops?
    +COPS: 0,2,"44020",7
    OK
    mosh:~$ iperf3 -c speedtest.serverius.net -p 5002 -l 705 -t 30
    iperf_client_end: iperf_set_send_state failed
    iperf3: error - unable to send control message: Socket is not connected
    iperf Failed.
    mosh:~$ sock connect -a speedtest.serverius.net -p 5002
    Socket open and connect family=1, type=1, port=5002, bind_port=0, pdn_cid=0, address=speedtest.serverius.net
    Socket created socket_id=0, fd=4
    mosh:~$ Received data for socket socket_id=0, buffer_size=1:
    mosh:~$ 	�
    mosh:~$ Socket id=0 (fd=4) disconnected so closing.
    mosh:~$ sock list
    There are no open sockets
    mosh:~$ sock listsock connect -a speedtest.serverius.net -p 5002
    mosh:~$ 	�
    mosh:~$ 	�
    mosh:~$ sock connect -a speedtest.serverius.net -p 5002sock listsock connect -a speedtest.serverius.net -p 5002iperf3 -c speedtest.serverius.net -p 5002 -l 705 -t 30
    iperf3: error - unable to send control message: Connection reset by peer
    iperf Failed.
    iperf3: error - the server is busy running a test. try again later
    iperf Failed.
    iperf Failed.
    mosh:~$ iperf3 -c speedtest.serverius.net -p 5002 -l 705 -t 301024
    iperf Failed.
    mosh:~$ iperf3 -c speedtest.serverius.net -p 5002 -l 1024 -l 1024 -l 1024 -l 10242 -l 10240 -l 10241 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024.net -p 5201 -l 1024i.net -p 5201 -l 1024p.net -p 5201 -l 1024e.net -p 5201 -l 1024r.net -p 5201 -l 1024f.net -p 5201 -l 1024..net -p 5201 -l 1024h.net -p 5201 -l 1024e.net -p 5201 -l 1024
    iperf3: error - unable to send control message: Bad file number
    iperf Failed.
    mosh:~$ iperf3 -c iperf.he.net -p 5201 -l 1024
    iperf Failed.
    mosh:~$ iperf3 -c iperf.he.net -p 5201 -l 1024iperf.he.net -p 5201 -l 1024iperf.he.net -p 5201 -l 1024iperf.he.net -p 5201 -l 1024
    mosh:~$ iperf3 iperf.biznetnetworks.com -l 1024-iperf.biznetnetworks.com -l 1024ciperf.biznetnetworks.com -l 1024 iperf.biznetnetworks.com -l 1024
    iperf Failed.
    mosh:~$ iperf3 -c iperf.biznetnetworks.com -l 1024
    Connecting to host iperf.biznetnetworks.com, port 5201
    [  5] local 0.0.0.0 port 0 connected to 117.102.109.186 port 5201
    stream [0]: socket: 5 read: 0 write: 1
    [ ID] Interval           Transfer     Bitrate
    [  5]   0.00-1.01   sec  15.2 KBytes   123 Kbits/sec
    [  5]   1.01-2.08   sec  22.1 KBytes   171 Kbits/sec
    [  5]   2.08-3.10   sec  23.5 KBytes   188 Kbits/sec
    [  5]   3.10-4.06   sec  22.1 KBytes   188 Kbits/sec
    [  5]   4.06-5.10   sec  22.4 KBytes   178 Kbits/sec
    [  5]   5.10-6.11   sec  23.5 KBytes   190 Kbits/sec
    [  5]   6.11-7.11   sec  23.5 KBytes   193 Kbits/sec
    [  5]   7.11-8.05   sec  22.1 KBytes   193 Kbits/sec
    [  5]   8.05-9.01   sec  23.5 KBytes   200 Kbits/sec
    [  5]   9.01-10.13  sec  24.2 KBytes   178 Kbits/sec
    [  5]   0.00-10.13  sec   222 KBytes   180 Kbits/sec                  sender
    [  5]   0.00-10.13  sec   222 KBytes   180 Kbits/sec                  receiver
    iperf Done.
    mosh:~$ iperf3 -c iperf.biznetnetworks.com -l 1024 -R
    Reverse mode, remote host iperf.biznetnetworks.com is sending
    stream [0]: socket: 5 read: 1 write: 0
    [  5]   0.00-1.00   sec  21.4 KBytes   175 Kbits/sec
    [  5]   1.00-2.00   sec  22.1 KBytes   181 Kbits/sec
    [  5]   2.00-3.00   sec  24.2 KBytes   198 Kbits/sec
    [  5]   3.00-4.00   sec  22.8 KBytes   187 Kbits/sec
    [  5]   4.00-5.00   sec  22.1 KBytes   181 Kbits/sec
    [  5]   5.00-6.00   sec  21.4 KBytes   176 Kbits/sec
    [  5]   6.00-7.00   sec  24.2 KBytes   198 Kbits/sec
    [  5]   7.00-8.00   sec  23.5 KBytes   193 Kbits/sec
    [  5]   8.00-9.00   sec  22.1 KBytes   181 Kbits/sec
    [  5]   9.00-10.00  sec  23.5 KBytes   193 Kbits/sec
    [ ID] Interval           Transfer     Bitrate         Retr
    [  5]   0.00-10.00  sec   260 KBytes   213 Kbits/sec    0             sender
    [  5]   0.00-10.00  sec   227 KBytes   186 Kbits/sec                  receiver
    iperf Done.
    mosh:~$ iperf3 -c iperf.biznetnetworks.com -l 1024 -Riperf3 -c iperf.biznetnetworks.com -l 1024
    iperf Failed.
    iperf Failed.
    iperf Failed.
    mosh:~$ iperf3 -c iperf.biznetnetworks.com -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024i -l 1024p -l 1024e -l 1024r -l 1024f -l 1024. -l 1024i -l 1024t -l 1024- -l 1024n -l 1024o -l 1024r -l 1024t -l 1024h -l 1024. -l 1024n -l 1024e -l 1024t -l 1024
    getaddrinfo failed with error code -11 EAI_SYSTEM
    iperf Failed.
    mosh:~$ iperf3 -c iperf.it-north.net -l 1024
    iperf Failed.
    iperf Failed.
    iperf Failed.
    mosh:~$ iperf3 -c speedtest.serverius.net -p 5002 -l 705 -t 30iperf3 -c iperf.it-north.net -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024 -l 1024s -l 1024p -l 1024e -l 1024e -l 1024d -l 1024t -l 1024e -l 1024s -l 1024t -l 1024- -l 1024i -l 1024p -l 1024e -l 1024r -l 1024f -l 1024- -l 1024a -l 1024k -l 1024l -l 1024. -l 1024v -l 1024e -l 1024t -l 1024t -l 1024a -l 1024. -l 1024o -l 1024n -l 1024l -l 1024i -l 1024n -l 1024e -l 1024
    iperf Failed.
    mosh:~$ iperf3 -c speedtest-iperf-akl.vetta.online -l 1024
    iperf Failed.
    mosh:~$ iperf3 -c speedtest-iperf-akl.vetta.online -l 1024iperf3 -c speedtest.serverius.net -p 5002 -l 705 -t 30iperf3 -c iperf.it-north.net -l 1024iperf3 -c iperf.biznetnetworks.com -l 1024
    iperf Failed.
    mosh:~$
    [  5]   0.00-1.01   sec  7.61 KBytes  61.8 Kbits/sec
    [  5]   1.01-2.00   sec  18.0 KBytes   149 Kbits/sec
    [  5]   2.00-3.00   sec  23.1 KBytes   189 Kbits/sec
    [  5]   3.00-4.00   sec  22.5 KBytes   184 Kbits/sec
    [  5]   5.00-6.00   sec  23.5 KBytes   193 Kbits/sec
    [  5]   6.00-7.00   sec  23.5 KBytes   193 Kbits/sec
    [  5]   8.00-9.00   sec  23.5 KBytes   193 Kbits/sec
    [  5]   9.00-10.00  sec  22.7 KBytes   186 Kbits/sec
    [  5]   0.00-10.00  sec   210 KBytes   172 Kbits/sec                  sender
    [  5]   0.00-10.00  sec   210 KBytes   172 Kbits/sec                  receiver
    iperf Done.
    mosh:~$
    mosh:~$ iperf3 -c iperf.biznetnetworks.com -l 1024iperf3 -c speedtest-iperf-akl.vetta.online -l 1024iperf3 -c speedtest.serverius.net -p 5002 -l 705 -t 30
    iperf Failed.
    mosh:~$
    mosh:~$ iperf3 --client ping.online.net --port 5202 -l 3540 --time 30 -V -R
    iperf 3.9-nrf
    nrf9160
    Control connection MSS: using modem default
    iperf Failed.
    iperf 3.9-nrf
    nrf9160
    Time: 22/05/23,06:07:06+36
    Connecting to host ping.online.net, port 5202
    Reverse mode, remote host ping.online.net is sending
          Cookie: nrf9160.6490.844024.6db505597d157d8d
          TCP MSS: 0 (default)
    [  5] local 0.0.0.0 port 0 connected to 62.210.18.40 port 5202
    Starting Test: protocol: TCP, 1 streams, 3540 byte blocks, omitting 0 seconds, 30 second test, tos 0
    [  5]   0.00-1.01   sec  2.77 KBytes  22.4 Kbits/sec
    [  5]   1.01-2.01   sec  15.2 KBytes   125 Kbits/sec
    [  5]   2.01-3.01   sec  17.3 KBytes   142 Kbits/sec
    [  5]   3.01-4.01   sec  15.2 KBytes   125 Kbits/sec
    [  5]   4.01-5.01   sec  16.6 KBytes   136 Kbits/sec
    [  5]   5.01-6.01   sec  17.3 KBytes   142 Kbits/sec
    [  5]   6.01-7.01   sec  15.2 KBytes   125 Kbits/sec
    [  5]   7.01-8.01   sec  15.9 KBytes   130 Kbits/sec
    [  5]   8.01-9.01   sec  14.5 KBytes   119 Kbits/sec
    [  5]   9.01-10.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  10.01-11.01  sec  14.5 KBytes   119 Kbits/sec
    [  5]  11.01-12.01  sec  17.3 KBytes   141 Kbits/sec
    [  5]  12.01-13.01  sec  13.8 KBytes   113 Kbits/sec
    [  5]  13.01-14.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  14.01-15.01  sec  17.3 KBytes   142 Kbits/sec
    [  5]  15.01-16.01  sec  15.9 KBytes   130 Kbits/sec
    [  5]  16.01-17.01  sec  15.9 KBytes   130 Kbits/sec
    [  5]  17.01-18.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  18.01-19.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  19.01-20.01  sec  15.9 KBytes   130 Kbits/sec
    [  5]  20.01-21.01  sec  15.9 KBytes   130 Kbits/sec
    [  5]  21.01-22.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  22.01-23.01  sec  15.9 KBytes   130 Kbits/sec
    [  5]  23.01-24.01  sec  18.0 KBytes   147 Kbits/sec
    [  5]  24.01-25.01  sec  15.9 KBytes   130 Kbits/sec
    [  5]  25.01-26.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  26.01-27.01  sec  18.0 KBytes   147 Kbits/sec
    [  5]  27.01-28.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  28.01-29.01  sec  16.6 KBytes   136 Kbits/sec
    [  5]  29.01-30.01  sec  11.8 KBytes  96.3 Kbits/sec
    Test Complete. Summary Results:
    [  5]   0.00-30.01  sec   532 KBytes   145 Kbits/sec    0             sender
    [  5]   0.00-30.01  sec   469 KBytes   128 Kbits/sec                  receiver
    iperf Done.
    iperf 3.9-nrf
    nrf9160
    Time: 22/05/23,06:07:51+36
          Cookie: nrf9160.6535.922882.71dfed4345cb977b
    [  5]   0.00-1.01   sec  7.61 KBytes  61.7 Kbits/sec
    [  5]   1.01-2.01   sec  12.4 KBytes   102 Kbits/sec
    [  5]   2.01-3.01   sec  13.8 KBytes   113 Kbits/sec
    [  5]   3.01-4.15   sec  13.8 KBytes  99.2 Kbits/sec
    [  5]   4.15-5.11   sec  13.8 KBytes   118 Kbits/sec
    [  5]   5.11-6.04   sec  15.2 KBytes   134 Kbits/sec
    [  5]   6.04-7.03   sec  16.6 KBytes   138 Kbits/sec
    [  5]   7.03-8.04   sec  13.8 KBytes   112 Kbits/sec
    [  5]   8.04-9.03   sec  16.6 KBytes   138 Kbits/sec
    [  5]   9.03-10.01  sec  13.8 KBytes   115 Kbits/sec
    [  5]  10.01-11.05  sec  15.2 KBytes   120 Kbits/sec
    [  5]  11.05-12.02  sec  12.4 KBytes   106 Kbits/sec
    [  5]  12.02-13.04  sec  13.8 KBytes   111 Kbits/sec
    [  5]  13.04-14.07  sec  13.8 KBytes   111 Kbits/sec
    [  5]  14.07-15.01  sec  13.8 KBytes   120 Kbits/sec
    [  5]  15.01-16.07  sec  13.8 KBytes   107 Kbits/sec
    [  5]  16.07-17.02  sec  12.4 KBytes   108 Kbits/sec
    [  5]  17.02-18.16  sec  16.6 KBytes   119 Kbits/sec
    [  5]  18.16-19.13  sec  13.8 KBytes   117 Kbits/sec
    [  5]  19.13-20.04  sec  13.8 KBytes   124 Kbits/sec
    [  5]  20.04-21.14  sec  15.2 KBytes   114 Kbits/sec
    [  5]  21.14-22.01  sec  13.8 KBytes   129 Kbits/sec
    [  5]  22.01-23.03  sec  15.2 KBytes   122 Kbits/sec
    [  5]  23.03-24.12  sec  15.2 KBytes   115 Kbits/sec
    [  5]  24.12-25.04  sec  13.8 KBytes   123 Kbits/sec
    [  5]  25.04-26.03  sec  13.8 KBytes   114 Kbits/sec
    [  5]  26.03-27.09  sec  13.8 KBytes   107 Kbits/sec
    [  5]  27.09-28.01  sec  13.8 KBytes   123 Kbits/sec
    [  5]  28.01-29.05  sec  12.4 KBytes  98.3 Kbits/sec
    [  5]  29.05-30.19  sec  15.2 KBytes   109 Kbits/sec
    [  5]   0.00-30.19  sec   420 KBytes   114 Kbits/sec                  sender
    [  5]   0.00-30.19  sec   420 KBytes   114 Kbits/sec                  receiver
    CPU Utilization: not supported
    iperf Done.
    mosh:~$
    mosh:~$
    Now, I take about 35 seconds to upload a 30KB file based on the https_client sample.
    Although there is header information of http and tls, data redundancy due to encryption, and waiting time after send() that I am adding, I think that it takes a long time compared to the measurement result of iperf. With the measured effective speed, I think that 30KB of data can be transmitted within 5 seconds.
    Best Regards,
    Yukio Oyama
  • Hi!
    1. This doesn't seem like a bad idea, but looking at the Zephyr documentation it looks like this option is not implemented.
    some options are dummy and provided to ease porting of existing code
    2. Looking in the sample documentation:
    Instead of offloading the TLS sockets into the modem, you can use the Mbed TLS library from Zephyr. Using the Zephyr Mbed TLS, you can still use the offloaded sockets. Mbed TLS offers more configuration options than using the offloaded TLS handling
    It looks like the sample uses offloaded sockets by default.
    I also see that the sample has a file called overlay-tfm_mbedtls.conf, containing what I assume are the options required to use mbed TLS instead of offloaded sockets, and the Kconfig file defines a SAMPLE_TFM_MBEDTLS option, so yes by default the sample definitely uses offloaded sockets.
    3. Right, so what takes the most time in your application right now? Is it the wait after recv?
    -Einar
  • Hi Einar-san,
    I built in receiving AT notifications below and checked if there were AT notifications.
    AT_MONITOR(at_notify, ANY, notification_handler);
    There was no AT notification after send(). I couldn't know the end of the send() action through AT notifications.
    I set the timeout of recv() below. Recv() was speed up due to the timeout.
    setsockopt(fd, SOL_SOCKET, SO_RCVTIMEO, (const char*)&tv, sizeof tv);
    I set the timeout time to 1 second. However, it is based on several experiments and is unfounded.
    In the question of what function calls take a long time, if what you mean is the time each function call takes, it was recv().
    However, recv() is a bit faster with the timeout setting, and it only runs once for each file I want to send.
    Therefore, the impact of recv() is small.
    When sending one file, it is the send() loop that takes the longest time as a whole.
    I have set a wait time of 200ms after send().
    When sending a 30KB file, send() loops around 10 times (I have tried various sending sizes, so the number of loops varies. But it is usually around 10 times.)
    The waiting time of 200ms is about 2 seconds in about 10 loops.  In my code, it takes about 35 seconds to send a 30KB file, so I consider the send() calling to take longer than the 200ms wait time.
    Best Regards,
    Yukio Oyama
  • Hello Einarh-san,
    I've been paying attention to whether the send was completed in order for the send() loop to succeed.
    However, in the thread below, Didrick-san said in response to #2 that if the socket could not be assigned to the send queue, it would return an ENOMEM (or ETIMEOUT) error.
    Unfortunately I don't know what function call he said in which sample.
    In code based on my https_client sample, send () returns error 95 (EOPNOTSUPP), so I suspect he's referring to a different sample.
    Do you know what sample it is based on?
    Or is the same error not occurring in send() in the https_client sample I'm trying because the situation isn't happening?
    I think it could be based on "\zephyr\samples\net\sockets\http_client".
    Is this any difference compared to "\nrf\samples\nrf9160\https_client"? Didrik-san says Zephyr's http_client sample can also handle TLS.
    Best Regards,
    Yukio Oyama
