How to Create an Instance of RPC (Remote Procedural Call) using the NRF52840
I'm using SDK 17.0.2 with S113, v7.2.0 on the NRF52840. We currently have an instance of CLI running in our executive loop, and it works fine. We'd also like to implement RPC as well for calling functions from a remote processor.
This is what we have so far:
    // Entering executive loop. Please note, the system WILL NOT EXIT this loop
    // unless a reset occurs.
    for ( ;; )
        if (getRpcActivateFlagStatus())
            // Then service the RPC bytes!
            rpcServerBytePull(); // Not working
             nrf_cli_process(&m_cli_uart); // Working fine
        idle_state_handle();
        // Handle all of the events that were scheduled in the EMQ per
        // iteration of our executive loop. Please note, this is an nRF
        // driver-level API, which dispatches all pushed events to the system
        // EMQ (Event Message Queue).
        app_sched_execute();
Is there a special HW flag in sdk_config.h that needs to be set in order for RPC to operate on UART? My sdk_config.h already enables UART by the way. Also, are there any examples of RPC that I can follow as our SDK does. not come with an RPC example.
  • I think I see the issue here. I'm using a CLI over UART transport layer. Can CLU over UART support commands that are non-strings? For instance, byte-packed Structs as commands.
  • The CLI library uses strcmp() to check for matching commands. If the commands are not in string format (with a \0 string terminator), this will likely fail.
    The UART peripheral/transport can support any byte-data, but you need to handle the received data correctly in the application.
  • Thank you for confirming...using CLI over UART was at the root of my problem. I'm now creating an instance of standard UART in order to send and receive byte-packed data structs. Do I need to stop my CLI process when using my standard instance of UART or can they co-exist together?
    // Spawn an instance of UART
        static bool uart_instance_activated = false;
        if (!uart_instance_activated)
            uart_instance_activated = true;
            uint32_t err_code = NRF_SUCCESS;
            const app_uart_comm_params_t comm_params =
                UART_RX_PIN,
                UART_TX_PIN,
                UART_RTS_PIN_NUMBER,
                UART_CTS_PIN_NUMBER,
                UART_HWFC,
                false,
                NRF_UART_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                          uart_error_handle,
                    APP_IRQ_PRIORITY_LOWEST,
                                  err_code);
  • If the CLI UART backend is enabled, you will need to disable this or not start the CLI at all when using the UART instance for anything else. If you are using different UART instances (0 and 1) for the two libraries, you do not need to disable the CLI.
  • Interesting issue that I'm seeing. Okay, so app_uart_get() is able to receive bytes over the RX line from a requesting app, however, app_uart_put() cannot send any data back in response. We have confirmed this by logic analyzer.
    Here is my code:
    int8_t transportSend( const uint16_t bufferSize, uint8_t *pBuffer )
        if ( pBuffer == NULL )
            NRF_LOG_INFO("NULL?");
            return TRANSPORT_ERROR;
        uint32_t status = NRF_SUCCESS;
        status = app_uart_put( START_BYTE );
        if (status != NRF_SUCCESS)
            NRF_LOG_INFO("Failure in %s() @line %d", __FUNCTION__, __LINE__);
            return status;
        for ( uint16_t i = 0; i < bufferSize; i++ )
            NRF_LOG_INFO("pBuffer[%d] = %d", i, pBuffer[i]);
            // UART is spaming 0xFF so it has to be escaped
            if ( ( pBuffer[i] == START_BYTE ) ||
                 ( pBuffer[i] == STOP_BYTE ) ||
                 ( pBuffer[i] == ESCAPE_BYTE ) ||
                 ( pBuffer[i] == 0xFF ) )
                status = app_uart_put( ESCAPE_BYTE );
                    return status;
                status = app_uart_put( escapeByte( pBuffer[i] ) );
                    return status;
                status = app_uart_put( pBuffer[i] );
                    return status;
        } // end of for-loop
        status = app_uart_put( STOP_BYTE );
            return status;
        return TRANSPORT_SUCCESS;
    Am I using app_uart_put() incorrectly? Also, do functions like
    nrf_pwr_mgmt_run()
    UART functionality?
