Questions: QSPI driver for an external flash with the nRF5 SDK 17.1, nRF52840
Hi guys,
We designed a custom board with the nRF52840 SoC and is trying to use the QSPI interface to communicate with an external flash AS5F18G04SND-10LIN.
We are having some questions here and hope to get some feedback:
1. The nRF52840 datasheet recommended the following pins for QSPI communications (aQFN73 package): p0.18 for CSN, p0.19 for SCK, p0.21, p0.23, p0.22, p1.00 for SIO. While our current design used p0.25 for CSN, p0.22 for SCK, p0.20, p0.21, p0.23, p0.24 for SIO. Is this a problem?
2. I'm trying to build the driver for the external flash we used: AS5F18G04SND-10LIN, starting from the peripheral/QSPI example from the nRF5 SDK, I'm not sure if I fully understand the example though. In the example, the application code called the nrf_drv_qspi_erase, nrf_drv_qspi_write, and nrf_drv_qspi_read functions to erase, write and read the flash. However, from the datasheet of the external flash (MX25R6435FZNIL0) used on the nRF52840 DK, a device operation should start with a command byte (for example, page program would be 0x02). I don' see how these commands are implemented in the example.
3. Can I have some top-level advice on how to build the driver for AS5F18G04SND-10LIN? Like, what should the program flow be like?
Thanks so much for your time guys!
Best,
Richard
