nrf5340 qspi flash dma
Dear nordic engineers:
The only example I can find about flash is under zephyr/samples/drivers/spi_flash. However, the flash writing is pretty slow, and the MCU is halting while waiting for writing result.
If dma buffer is available, I can send the command to write dma data to flash and do other time consuming task. The status of the flash writing can be checked in the next MCU loop.
As I understand there is no dma available in any of the zephyr flash api(flash.h). Do you have examples from nordic internal?  I found a post here https://devzone.nordicsemi.com/f/nordic-q-a/72045/flash-filing-system-for-nrf-connect-sdk  , at least someone in nordic has aware of the useful feature (in the marked answer the config file include "help
Enable support for nrfx QSPI driver with EasyDMA.")
If there is no available example, I would like to implement it but need some guide on how to change nrf_qspi_nor.c and nrfx_qspi and make it accessible from my main.c.  Please provide some hint how I can proceed.
  • Hi
    Thanks for the reply. I've been able to let the thread run by making k_msleep. But I still have a bunch of question about thread, which will be deviate from my origin question about flash writing time.  Please suggest if I should raise a new ticket.
    The setback I have experienced is the thread is somehow locked. In the code, it uses __ASSERT_NO_MSG, I have no idea how to debug with the message. I tried to take __ASSERT_NO_MSG away and get some zephyr message about faulting during interrupt handling but I  have no idea how to debug it.
     * Copyright (c) 2016 Intel Corporation.
    #include <zephyr.h>
    #include <drivers/flash.h>
    #include <device.h>
    #include <devicetree.h>
    #include <stdio.h>
    #include <string.h>
    #include <kernel.h>
    #include <helpers/nrfx_gppi.h>
    #include <nrfx_dppi.h>
    #include <nrfx_timer.h>
    #include <logging/log.h>
    LOG_MODULE_REGISTER(spi_flash, LOG_LEVEL_INF);
    nrfx_timer_t timer1 = NRFX_TIMER_INSTANCE(1);
    nrfx_timer_t timer2 = NRFX_TIMER_INSTANCE(2);
    #if (CONFIG_SPI_NOR - 0) ||				\
    	DT_NODE_HAS_STATUS(DT_INST(0, jedec_spi_nor), okay)
    #define FLASH_DEVICE DT_LABEL(DT_INST(0, jedec_spi_nor))
    #define FLASH_NAME "JEDEC SPI-NOR"
    #elif (CONFIG_NORDIC_QSPI_NOR - 0) || \
    	DT_NODE_HAS_STATUS(DT_INST(0, nordic_qspi_nor), okay)
    #define FLASH_DEVICE DT_LABEL(DT_INST(0, nordic_qspi_nor))
    #define FLASH_NAME "JEDEC QSPI-NOR"
    #elif DT_NODE_HAS_STATUS(DT_INST(0, st_stm32_qspi_nor), okay)
    #define FLASH_DEVICE DT_LABEL(DT_INST(0, st_stm32_qspi_nor))
    #else
    #error Unsupported flash driver
    #if defined(CONFIG_BOARD_ADAFRUIT_FEATHER_STM32F405)
    #define FLASH_TEST_REGION_OFFSET 0xf000
    #elif defined(CONFIG_BOARD_ARTY_A7_ARM_DESIGNSTART_M1) || \
    	defined(CONFIG_BOARD_ARTY_A7_ARM_DESIGNSTART_M3)
    /* The FPGA bitstream is stored in the lower 536 sectors of the flash. */
    #define FLASH_TEST_REGION_OFFSET \
    	DT_REG_SIZE(DT_NODE_BY_FIXED_PARTITION_LABEL(fpga_bitstream))
    #else
    #define FLASH_TEST_REGION_OFFSET 0x00000
    // inhirit from Henrik's flash structure setup
    #define FLASH_BYTES_PER_PAGE 256
    #define FLASH_PAGES_PER_SECTOR 16
    #define FLASH_BYTES_PER_SECTOR (FLASH_BYTES_PER_PAGE*FLASH_PAGES_PER_SECTOR)
    #define FLASH_CHIP_DENSITY	(0x17 /* 23 */)
    #define FLASH_NUM_PAGES (1U << (FLASH_CHIP_DENSITY-8))
    #define FLASH_PAGE_MASK (FLASH_NUM_PAGES - 1)
    #define FLASH_FSYS_SECTOR 0 /* The sector number of the file system sector (containing file pointers) */
    #define FLASH_KVAL_SECTOR 1 /* The sector number of the special key-value sector */
    #define FLASH_BULK_SECTOR 2 /* The first sector of the space dedicated to files */
    #define FLASH_FSYS_START_PAGE (FLASH_FSYS_SECTOR*FLASH_PAGES_PER_SECTOR)
    #define FLASH_KVAL_START_PAGE (FLASH_KVAL_SECTOR*FLASH_PAGES_PER_SECTOR)
    #define FLASH_BULK_START_PAGE (FLASH_BULK_SECTOR*FLASH_PAGES_PER_SECTOR)
    #define FLASH_FSYS_START_ADDRESS (FLASH_FSYS_SECTOR*FLASH_BYTES_PER_SECTOR)
    #define FLASH_KVAL_START_ADDRESS (FLASH_KVAL_SECTOR*FLASH_BYTES_PER_SECTOR)
    #define FLASH_BULK_START_ADDRESS (FLASH_BULK_SECTOR*FLASH_BYTES_PER_SECTOR)
    // if sampling time is too quick ex 1ms, the write_flash will delay the process, and the next page will start from 141 instead of 127
    #define SAMPLE_TIME_ms 		2  // have tried 10us sampling with 100 pages, all good
    #define ANALOG_NUM_BUF_pages 5  // no problem to set 100 pages of buffer
    uint16_t count;
    int st,ed;
    const struct device *flash_dev;
    K_FIFO_DEFINE(flash_write_fifo);
    struct data_item_t {
        void *fifo_reserved;   /* 1st word reserved for use by fifo */
        uint16_t counter;
    void timer1_evt_handler(nrf_timer_event_t event_type, void * p_context)
    	switch(event_type)
    		case NRF_TIMER_EVENT_COMPARE0: ;
    			struct data_item_t tx_data = { .counter=count };
    			size_t size = sizeof(struct data_item_t);
    			char *mem_ptr = k_malloc(size);
    			__ASSERT_NO_MSG(mem_ptr != 0);
    			memcpy(mem_ptr, &tx_data, size);
    			k_fifo_put(&flash_write_fifo, &tx_data);
    			count++;
    			//printk("count: %d\n",count);
    			//Do nothing.
    void timer_init(void)
    	nrfx_err_t err = NRFX_SUCCESS;
    	nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG;
    	err = nrfx_timer_init(&timer1, &timer_cfg, timer1_evt_handler);
    	if(err != NRFX_SUCCESS)
    		LOG_ERR("timer 1 Error! Could not initialize TIMER1: %d\n", err);
    	uint32_t time_ticks = nrfx_timer_ms_to_ticks(&timer1, SAMPLE_TIME_ms);
    	nrfx_timer_extended_compare(&timer1, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    	nrfx_timer_enable(&timer1);
    	IRQ_DIRECT_CONNECT(TIMER1_IRQn, 0, nrfx_timer_1_irq_handler, 0);
    void timer_deinit(void){
    	nrfx_timer_disable(&timer1);
    	irq_disable(TIMER1_IRQn);
    static void flash_write_thread(void *a1, void *a2, void *a3 ){
    	size_t siz, wbsiz;
    	int rc;
    	uint32_t st,ed;
    	printf("\n" FLASH_NAME " SPI flash testing\n");
    	printf("==========================\n");
    	flash_dev = device_get_binding(FLASH_DEVICE);
    	if (!flash_dev) {
    		printf("SPI flash driver %s was not found!\n",
    		       FLASH_DEVICE);
    		return;
    	siz=flash_get_page_count(flash_dev);
    	wbsiz=flash_get_write_block_size(flash_dev);
       // erase is needed before write, otherwise there may be error between write and read
    	printf("\nTest 1: Flash erase\n");
    	st=k_cycle_get_32();
    	rc = flash_erase(flash_dev, FLASH_TEST_REGION_OFFSET,
    			 (ANALOG_NUM_BUF_pages/FLASH_PAGES_PER_SECTOR+1)*FLASH_BYTES_PER_SECTOR); // erase take integer sectors of bytes
    	ed=k_cycle_get_32();
    	if (rc != 0) {
    		printf("Flash erase failed! %d\n", rc);
    	} else {
    		printf("Flash erase succeeded! %d , %d \n",st,ed);
    	uint8_t tembuf[FLASH_BYTES_PER_PAGE];
    	int reads, page_address_write;
    	reads=0;
    	page_address_write=0;
    	while(1){
    		if(!k_fifo_is_empty(&flash_write_fifo)){
    			uint8_t *tmptr=tembuf+2*reads;
    			struct data_item_t  *rx_data = k_fifo_get(&flash_write_fifo, K_FOREVER);
    			*(uint16_t*)tmptr=rx_data->counter;
    			printk(" in write thread %d \n", *tmptr);
    				if(++reads>=128){
    					//printk("addr offset %x \n", FLASH_TEST_REGION_OFFSET+page_address_write*FLASH_BYTES_PER_PAGE);
    					st = k_cycle_get_32()/32;
    					rc = flash_write(flash_dev, FLASH_TEST_REGION_OFFSET+page_address_write*FLASH_BYTES_PER_PAGE, tembuf, FLASH_BYTES_PER_PAGE);
    					ed=k_cycle_get_32()/32;
    					if (rc != 0) {
    						printf("Flash write failed! %d\n", rc);
    						return;
    					}else{
    						printk("page_address_write %d, count %d, write %d, %d \n",page_address_write ,count, st,ed);
    					reads = 0;
    					if(++page_address_write >= ANALOG_NUM_BUF_pages) {
    						timer_deinit();
    						printk("reach page %d\n",ANALOG_NUM_BUF_pages);
    			//k_free(rx_data);
     K_THREAD_DEFINE(write_to_flash_id, 2048, flash_write_thread, NULL, NULL, NULL,
    		7, 0, 0);
    void main(void)
    	count=0;
    	timer_init();
    	//k_thread_start(write_to_flash_id);
    	while(1){
    		k_msleep(15);
    Please give me some indication how I can debug thread and interrupt. I've tried with breakpoint but it doesn't seems to help, the thread just suddenly halted.
    Another question I have about thread is about the sleep time that you suggested.
    question 1. if I have a thread that needs a long time to process (assume extreme case 100ms), is it a "o.k" practice to have a sleep period less than the process time (assume 1ms).
    question 2: assume I have many threads that do multiple signal processings, writing to flash. How do I know which thread will be run during the sleep. Should I plan a specific time for the main thread to sleep and activate a specific thread to run during the sleep time of main thread?
    I hope there are example that can explain this better.
    Thanks for help
  • Hi
    Maybe yo could try just to print something to the log if mem_ptr != 0 ?
    You should skip the remaining code in the timer event handler if this occurs, to avoid writing to the flash_write_fifo if the malloc fails.
    Also, unless you don't use k_malloc anywhere else it is not safe to call this function from an interrupt handler. It is best to only use this method from a thread or a work item (or even better to use statically defined memory structures, rather than dynamic memory allocation).
    If the thread has a positive priority number it can be interrupted by other, more important threads as long as they have a higher interrupt priority (lower number).
    As an example, if you give your time consuming but less critical thread a priority of 5, you can put other more time critical threads at priority 4 or below, and they will be able to interrupt the slow running thread when they have some work to do.
    You don't really know when the different threads are going to run, this is all controlled by the scheduler.
    If you feel that you need to know this information then it sounds like you need a better way to synchronize the different activities in your program.
    As an example, if you have multiple processes that need to access the flash at different times you can use a FIFO to allow the different threads to schedule flash operations, and execute the operations (read the FIFO) from a single thread so that you avoid conflicts.
    Best regards
    Torbjørn
  • Hi Thanks for the answer, I got it to work with your suggestion, putting put fifo out of interrupt handler. One final question to this thread about flash driver, is it needed to erase before writing a new dataset into flash?
    Some other question, is there example on using other zephyr fifo api, like k_fifo_alloc_put(). I get error on zephyr CPU and don't know how to debug. I have tried to run in debug mode, but zephyr doesn't report any error or halting. I feel frustrated when it comes to zephyr, the document is not very clear. Is there forum for zephyr like the one you have hosted very well on the nordic site?
  • Hi
    If you use the low level flash driver then you normally need to erase a page before you can write anything to it, that is correct. Since flash only allows you to clear bits when writing and not set bits any word that is not already 0xFFFFFFFF (all ones) can not be written to without first erasing the page.
    If you use a higher level driver, like NVS, then the page erase is handled for you by the driver, and you don't need to know about the intricacies of working with flash memory.
    Are you saying that the k_fifo_alloc_put() call doesn't return any error codes, but still the application will crash?
    Zephyr is hosted on Github, which means you can raise issues or ask questions through Github directly:
    https://github.com/zephyrproject-rtos/zephyr/issues
    We are also happy to help with Zephyr related questions here on the Devzone Slight smile
    Best regards
    Torbjørn
