MQTT with TLS on AWS EC2
We have our own MQTT broker setup with TLS running on a AWS EC2 cloud service.  I am building my code based on the MQTT_SIMPLE example.  I have only a CA certificate in the certificates.h file.  There is no client private key and no client public certificate.  SEC_TAG is set to 2840.  Port is set to 8883.  Below is the terminal output.  IP address was resolved correctly.  Unfornately, I wasn't able to connect to our MQTT broker.  I kept getting error code 95.
[00:00:00.266,235] <inf> MQTT_SIMPLE: MQTT started
[00:00:00.271,270] <inf> MQTT_SIMPLE: Provisioning certificates
[00:00:00.428,375] <inf> MQTT_SIMPLE: Disabling PSM and eDRX
[00:00:00.439,147] <inf> MQTT_SIMPLE: LTE Link Connecting
[00:00:15.602,569] <inf> MQTT_SIMPLE: LTE Link Connected
[00:00:17.040,008] <inf> MQTT_SIMPLE: IPv4 Address found xxx.xxx.215.238
[00:00:17.047,363] <inf> MQTT_SIMPLE: TLS enabled
[00:00:17.707,611] <err> MQTT_SIMPLE: mqtt_connect -95
[00:00:17.713,256] <inf> MQTT_SIMPLE: Reconnecting in 30 seconds
[00:00:48.585,479] <err> MQTT_SIMPLE: mqtt_connect -95
[00:00:48.591,125] <inf> MQTT_SIMPLE: Reconnecting in 30 seconds
[00:01:19.484,619] <err> MQTT_SIMPLE: mqtt_connect -95
[00:01:19.490,264] <inf> MQTT_SIMPLE: Reconnecting in 30 seconds
The same code was able to connect with test.mosquitto.org with its mosquitto.org.crt (PEM format) and port 8883.  Am I missing anything?  What have I done wrong?
By the way, I am using SDK 1.8.0.
