Python CHIP-TOOL : "CHIP:CTL: Failed in verifying 'Attestation Information' command received from the device: err 604. Look at AttestationVerificationResult enum to understand the errors"
Hello, I'm testing the Matter example : Template (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/matter/template/README.html) with nRF SDK v1.9.99. This example project runs on nRF5340 DK board.
I'm trying to commission the device (Matter template) into a Thread Network created by the Open Thread Border Router running on RaspberryPI. For commissioning, I'm using the CHIP tool who plays the role of Matter controller (http://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/matter/chip_tool_guide.html#).  The CHIP tools runs on a Linux PC (Ubuntu 20.04.4 LTS).
I'm getting an error when running command for commissioning my device into Thread network over Bluetooth LE using the command.
$ sudo ./chip-tool pairing ble-thread <node_id> hex:<operational_dataset> <pin_code> <discriminator>
The error is related to Attestation Information command verification. Here below you can find my output when running the command mentioned before:
[1651655595.445469][3268141:3268146] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1651655595.445508][3268141:3268146] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1651655595.445522][3268141:3268146] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1651655595.445537][3268141:3268146] CHIP:CTL: Verifying attestation
[1651655595.449855][3268141:3268146] CHIP:CTL: Failed in verifying 'Attestation Information' command received from the device: err 604. Look at AttestationVerificationResult enum to understand the errors
[1651655595.449898][3268141:3268146] CHIP:CTL: Error on commissioning step 'AttestationVerification': '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:945: CHIP Error 0x000000AC: Internal error'
[1651655595.449913][3268141:3268146] CHIP:CTL: Failed to perform commissioning step 8
[1651655595.449928][3268141:3268146] CHIP:CTL: Going from commissioning step 'AttestationVerification' with lastErr = '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:945: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
[1651655595.449954][3268141:3268146] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = '../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:945: CHIP Error 0x000000AC: Internal error'
[1651655595.449971][3268141:3268146] CHIP:CTL: Expiring failsafe on proxy 0x7f8178000b60
[1651655595.450018][3268141:3268146] CHIP:DMG: ICR moving to [AddingComm]
[1651655595.450038][3268141:3268146] CHIP:DMG: ICR moving to [AddedComma]
[1651655595.450093][3268141:3268146] CHIP:IN: Prepared secure message 0x7f818d3cc840 to 0xFFFFFFFB00000000 (0)  of type 0x8 and protocolId (0, 1) on exchange 44183i with MessageCounter:2773086.
[1651655595.450133][3268141:3268146] CHIP:IN: Sending encrypted msg 0x7f818d3cc840 with MessageCounter:2773086 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000019F746FE msec
[1651655595.450203][3268141:3268146] CHIP:DMG: ICR moving to [CommandSen]
[1651655595.450254][3268141:3268146] CHIP:DMG: ICR moving to [AwaitingDe]
[1651655595.577666][3268141:3268146] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1651655595.757789][3268141:3268146] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1651655595.847536][3268141:3268146] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1651655595.849437][3268141:3268144] CHIP:DL: Indication received, conn = 0x7f8184118020
[1651655595.849633][3268141:3268146] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1651655595.936877][3268141:3268146] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1651655596.027568][3268141:3268144] CHIP:DL: Indication received, conn = 0x7f8184118020
[1651655596.027692][3268141:3268146] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1651655596.210120][3268141:3268144] CHIP:DL: Bluez disconnected
[1651655596.210153][3268141:3268144] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1651655596.210240][3268141:3268146] CHIP:IN: Clearing BLE pending packets.
[1651655607.453609][3268141:3268146] CHIP:DMG: Time out! failed to receive invoke command response from Exchange: 44183i
[1651655607.453676][3268141:3268146] CHIP:CTL: Received failure response  when disarming failsafe../examples/chip-tool/third_party/connectedhomeip/src/app/CommandSender.cpp:211: CHIP Error 0x00000032: Timeout
[1651655607.453707][3268141:3268146] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1651655607.453739][3268141:3268146] CHIP:TOO: Device commissioning Failure: ../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:945: CHIP Error 0x000000AC: Internal error
[1651655607.453785][3268141:3268146] CHIP:DIS: Closing all BLE connections
[1651655607.453854][3268141:3268146] CHIP:DMG: ICR moving to [AwaitingDe]
[1651655607.454132][3268141:3268141] CHIP:CTL: Shutting down the commissioner
[1651655607.454229][3268141:3268141] CHIP:CTL: Shutting down the controller
[1651655607.454254][3268141:3268141] CHIP:CTL: Shutting down the commissioner
[1651655607.454298][3268141:3268141] CHIP:CTL: Shutting down the controller
[1651655607.454315][3268141:3268141] CHIP:IN: Expiring all connections for fabric 1!!
[1651655607.454350][3268141:3268141] CHIP:CTL: Shutting down the commissioner
[1651655607.454389][3268141:3268141] CHIP:CTL: Shutting down the controller
[1651655607.454404][3268141:3268141] CHIP:IN: Expiring all connections for fabric 2!!
[1651655607.454428][3268141:3268141] CHIP:CTL: Shutting down the commissioner
[1651655607.454466][3268141:3268141] CHIP:CTL: Shutting down the controller
[1651655607.454480][3268141:3268141] CHIP:IN: Expiring all connections for fabric 3!!
[1651655607.454501][3268141:3268141] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1651655607.454650][3268141:3268141] CHIP:DMG: IM WH moving to [Uninitialized]
[1651655607.454667][3268141:3268141] CHIP:DMG: IM WH moving to [Uninitialized]
[1651655607.454679][3268141:3268141] CHIP:DMG: IM WH moving to [Uninitialized]
[1651655607.454690][3268141:3268141] CHIP:DMG: IM WH moving to [Uninitialized]
[1651655607.454702][3268141:3268141] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1651655607.454742][3268141:3268141] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1651655607.454944][3268141:3268141] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-rit9kH)
[1651655607.455335][3268141:3268141] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1651655607.455379][3268141:3268141] CHIP:DL: NVS set: chip-counters/total-operational-hours = 17 (0x11)
[1651655607.455395][3268141:3268141] CHIP:DL: Inet Layer shutdown
[1651655607.455407][3268141:3268141] CHIP:DL: BLE shutdown
[1651655607.466156][3268141:3268141] CHIP:DL: System Layer shutdown
[1651655607.466269][3268141:3268141] CHIP:TOO: Run command failure: ../examples/chip-tool/third_party/connectedhomeip/src/controller/CHIPDeviceController.cpp:945: CHIP Error 0x000000AC: Internal error
In the file ble_commissioning_matter_template.txt, you can find the logging of my Matter device (Matter template example).
I: Init CHIP stack
I: Swap type: none
D: 1233 [DL]Boot reason: 6
I: 1303 [DL]BLE address: DD:CB:23:39:D9:41
I: 1331 [DL]OpenThread started: OK
I: 1338 [DL]Setting OpenThread device type to MINIMAL END DEVICE
I: Swap type: none
I: 1356 [ZCL]Using ZAP configuration...
I: 1365 [ZCL]Initiating Admin Commissioning cluster.
I: 1375 [ZCL]OpCreds: Initiating OpCreds cluster by writing fabrics list from fabric table.
D: 1392 [DIS]Add fabric pairing table delegate
D: 1401 [DIS]Init fabric pairing table with server storage
I: 1412 [IN]Loading from storage for fabric index 1
I: 1422 [IN]Loading from storage for fabric index 2
I: 1432 [IN]Loading from storage for fabric index 3
I: 1442 [IN]Loading from storage for fabric index 4
I: 1452 [IN]Loading from storage for fabric index 5
I: 1462 [DMG]AccessControl: initializing
I: 1470 [DMG]Examples::AccessControlDelegate::Init
I: 1480 [DMG]AccessControl: unable to load stored ACL entries; using empty list instead
I: 1497 [DMG]AccessControl: setting
D: 1504 [IN]UDP::Init bind&amp;listen port=5540
E: 1512 [IN]SO_REUSEPORT failed: 109
D: 1519 [IN]UDP::Init bound to port=5540
D: 1527 [IN]BLEBase::Init - setting/overriding transport
D: 1538 [IN]TransportMgr initialized
D: 1549 [DIS]Add fabric pairing table delegate
D: 1558 [DL]Using Thread extended MAC for hostname.
I: 1569 [IN]Loading from storage for fabric index 1
I: 1581 [IN]Loading from storage for fabric index 2
I: 1593 [IN]Loading from storage for fabric index 3
I: 1604 [IN]Loading from storage for fabric index 4
I: 1616 [IN]Loading from storage for fabric index 5
D: 1630 [SC]Assigned local session key ID 1
D: 1639 [SC]Waiting for PBKDF param request
D: 1647 [DL]CHIPoBLE advertising set to on
I: 1656 [DIS]Updating services using commissioning mode 1
D: 1667 [DL]Using Thread extended MAC for hostname.
D: 1677 [DL]Using Thread extended MAC for hostname.
I: 1688 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15
E: 1706 [DIS]Failed to advertise commissionable node: Error CHIP:0x00000003
D: 1720 [DIS]Scheduling discovery timeout in 900s
E: 1729 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
I: 1742 [DIS]Updating services using commissioning mode 1
D: 1753 [DL]Using Thread extended MAC for hostname.
D: 1764 [DL]Using Thread extended MAC for hostname.
I: 1774 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15
E: 1793 [DIS]Failed to advertise commissionable node: Error CHIP:0x00000003
D: 1806 [DIS]Scheduling discovery timeout in 900s
E: 1816 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
I: 1829 [IN]CASE Server enabling CASE session setups
I: 1839 [DIS]Delaying proxy of operational discovery: missing delegate
I: 1853 [SVR]Joining Multicast groups
D: 1860 [ZCL]Emitting StartUp event
D: 1867 [EVL]LogEvent event number: 0x0000000000000000 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0028 event id: 0x0 Sys timestamp: 0x000000000000074B
D: 1897 [ZCL]GeneralDiagnosticsDelegate: OnDeviceRebooted
D: 1908 [DMG]Endpoint 0, Cluster 0x0000_0033 update version to bfb24910
D: 1922 [EVL]LogEvent event number: 0x0000000000000001 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0033 event id: 0x3 Sys timestamp: 0x0000000000000782
I: 1952 [SVR]Server Listening...
I: 1958 [DL]Device Configuration:
I: 1965 [DL]  Serial Number: TEST_SN
I: 1972 [DL]  Vendor Id: 65521 (0xFFF1)
I: 1980 [DL]  Product Id: 32768 (0x8000)
I: 1988 [DL]  Hardware Version: 0
I: 1995 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 2007 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 2022 [DL]  Manufacturing Date: (not set)
I: 2030 [DL]  Device Type: 65535 (0xFFFF)
I: 2040 [SVR]SetupQRCode: [MT:Y.K9042C00KA0648G00]
I: 2049 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 2063 [SVR]https://dhrishi.github.io/connectedhomeip/qrcode.html?data=MT%3AY.K9042C00KA0648G00
I: 2081 [SVR]Manual pairing code: [34970112332]
I: 2091 [DL]CHIP task running
I: 2102 [DL]CHIPoBLE advertising started
D: 2112 [DMG]Endpoint 0, Cluster 0x0000_002A update version to bc1cc0cc
D: 2125 [DMG]Endpoint 0, Cluster 0x0000_002A update version to bc1cc0cd
D: 2139 [EVL]LogEvent event number: 0x0000000000000002 priority: 1, endpoint id:  0x0 cluster id: 0x0000_002A event id: 0x0 Sys timestamp: 0x000000000000085B
I: 2169 [SWU]Starting the Default Provider timer, timeout: 86400 seconds
I: 14942 [DL]BLE connection established (ConnId: 0x00)
I: 14953 [DL]Current number of connections: 1/1
I: 14962 [DL]CHIPoBLE advertising stopped
D: 16758 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 16770 [BLE]local and remote recv window sizes = 5
I: 16780 [BLE]selected BTP version 4
I: 16788 [BLE]using BTP fragment sizes rx 20 / tx 20.
D: 16856 [DL]ConnId: 0x00, New CCCD value: 0x0001
D: 16865 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 6)
D: 16878 [IN]BLE EndPoint 0x20009a28 Connection Complete
I: 16889 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 23)
D: 16953 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 16965 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 17051 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 17148 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 17246 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 17258 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 17343 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 17355 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 17367 [EM]Received message of type 0x20 with protocolId (0, 0) and MessageCounter:699162204 on exchange 62855r
D: 17388 [EM]Handling via exchange: 62855r, Delegate: 0x20006478
D: 17400 [SC]Received PBKDF param request
D: 17408 [SC]Peer assigned session ID 30865
D: 17417 [SC]Found MRP parameters in the message
D: 17427 [SC]Including MRP parameters in PBKDF param response
I: 17439 [IN]Prepared unauthenticated message 0x2002da30 to 0x0000000000000000 (0)  of type 0x21 and protocolId (0, 0) on exchange 62855r with MessageCounter:4212018463.
I: 17470 [IN]Sending unauthenticated msg 0x2002da30 with MessageCounter:4212018463 to 0x0000000000000000 at monotonic time: 000000000000443E msec
D: 17497 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 17511 [SC]Sent PBKDF param response
E: 17518 [DL]Long dispatch time: 164 ms, for event type 16388
D: 17586 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 17598 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 17684 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 17695 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 17782 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 17793 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 17806 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 17879 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 17890 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 17976 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 17988 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 18074 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 18085 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 18172 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 18184 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 18196 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 14)
D: 18269 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 18281 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 18367 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 18464 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 18477 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 18562 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 18574 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 18659 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 18757 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 18769 [EM]Received message of type 0x22 with protocolId (0, 0) and MessageCounter:699162205 on exchange 62855r
D: 18790 [EM]Found matching exchange: 62855r, Delegate: 0x20006478
D: 18803 [SC]Received spake2p msg1
I: 20425 [IN]Prepared unauthenticated message 0x2002d9c0 to 0x0000000000000000 (0)  of type 0x23 and protocolId (0, 0) on exchange 62855r with MessageCounter:4212018464.
I: 20457 [IN]Sending unauthenticated msg 0x2002d9c0 with MessageCounter:4212018464 to 0x0000000000000000 at monotonic time: 0000000000004FE9 msec
D: 20484 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 20497 [SC]Sent spake2p msg2
E: 20503 [DL]Long dispatch time: 1746 ms, for event type 16388
D: 20579 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 20590 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 20669 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 20680 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 20759 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 20770 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 20849 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 20861 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 20873 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 20939 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 20950 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 21029 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 21040 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 21119 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 21130 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 7)
D: 21209 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 21221 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 21299 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 21390 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 21480 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 21492 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 21569 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 21581 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 21593 [EM]Received message of type 0x24 with protocolId (0, 0) and MessageCounter:699162206 on exchange 62855r
D: 21614 [EM]Found matching exchange: 62855r, Delegate: 0x20006478
D: 21627 [SC]Received spake2p msg3
D: 21634 [SC]Sending status report. Protocol code 0, exchange 62855
I: 21647 [IN]Prepared unauthenticated message 0x2002da48 to 0x0000000000000000 (0)  of type 0x40 and protocolId (0, 0) on exchange 62855r with MessageCounter:4212018465.
I: 21678 [IN]Sending unauthenticated msg 0x2002da48 with MessageCounter:4212018465 to 0x0000000000000000 at monotonic time: 00000000000054AE msec
D: 21705 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 21718 [IN]New secure session created for device 0xFFFFFFFB00000000, LSID:1 PSID:30865!
I: 21736 [SVR]Commissioning completed session establishment step
I: 21749 [DIS]Updating services using commissioning mode 0
D: 21760 [DL]Using Thread extended MAC for hostname.
D: 21771 [DL]Using Thread extended MAC for hostname.
I: 21781 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15
E: 21800 [DIS]Failed to advertise extended commissionable node: Error CHIP:0x00000003
D: 21817 [DIS]Scheduling extended discovery timeout in 900s
E: 21828 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
D: 21841 [DL]CHIPoBLE advertising set to off
I: 21849 [SVR]Device completed Rendezvous process
E: 21859 [DL]Long dispatch time: 278 ms, for event type 16388
D: 21870 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 21882 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 17)
D: 21975 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 21986 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22065 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22154 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22245 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22257 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 22335 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 22346 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22425 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22515 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22604 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 22617 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
I: 22631 [EM]Received message of type 0x2 with protocolId (0, 1) and MessageCounter:5687792 on exchange 62856r
D: 22652 [EM]Handling via exchange: 62856r, Delegate: 0x20008ec0
D: 22664 [IM]Received Read request
D: 22672 [DMG]IM RH moving to [AwaitingDestruction]
I: 22683 [IN]Prepared secure message 0x2002dae8 to 0xFFFFFFFB00000000 (0)  of type 0x1 and protocolId (0, 1) on exchange 62856r with MessageCounter:15114281.
I: 22712 [IN]Sending encrypted msg 0x2002dae8 with MessageCounter:15114281 to 0xFFFFFFFB00000000 (0) at monotonic time: 00000000000058B8 msec
E: 22738 [DL]Long dispatch time: 134 ms, for event type 16388
D: 22750 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 22761 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 22829 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 22840 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 22919 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 22930 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 6)
D: 23009 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 23021 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 23100 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 23190 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 23324 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 23337 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 23415 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 23426 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 23439 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:5687793 on exchange 62857r
D: 23460 [EM]Handling via exchange: 62857r, Delegate: 0x20008ec0
I: 23472 [DMG]AccessControl: checking f=0 a=p s=0xFFFFFFFB00000000 t= c=0x0000_0030 e=0 p=o
I: 23490 [DMG]AccessControl: implicit admin (PASE)
D: 23499 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
D: 23516 [DMG]ICR moving to [AddingComm]
D: 23524 [DMG]ICR moving to [AddedComma]
D: 23531 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 23546 [IN]Prepared secure message 0x2002dad8 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 62857r with MessageCounter:15114282.
I: 23575 [IN]Sending encrypted msg 0x2002dad8 with MessageCounter:15114282 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000005C17 msec
D: 23601 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 23614 [DMG]ICR moving to [CommandSen]
D: 23622 [DMG]ICR moving to [AwaitingDe]
E: 23630 [DL]Long dispatch time: 203 ms, for event type 16388
D: 23684 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 23695 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 23774 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 23785 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 23864 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 23876 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 23889 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 17)
D: 23955 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 23966 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 24045 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 24135 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 24147 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 24270 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 24281 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 24359 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 24373 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:5687794 on exchange 62858r
D: 24393 [EM]Handling via exchange: 62858r, Delegate: 0x20008ec0
I: 24406 [DMG]AccessControl: checking f=0 a=p s=0xFFFFFFFB00000000 t= c=0x0000_0030 e=0 p=o
I: 24423 [DMG]AccessControl: implicit admin (PASE)
D: 24433 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0002
D: 24454 [DMG]ICR moving to [AddingComm]
D: 24461 [DMG]ICR moving to [AddedComma]
D: 24469 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 24484 [IN]Prepared secure message 0x2002dad8 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 62858r with MessageCounter:15114283.
I: 24512 [IN]Sending encrypted msg 0x2002dad8 with MessageCounter:15114283 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000005FC0 msec
D: 24539 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 24552 [DMG]ICR moving to [CommandSen]
D: 24560 [DMG]ICR moving to [AwaitingDe]
E: 24567 [DL]Long dispatch time: 208 ms, for event type 16388
D: 24629 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 24640 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 24719 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 24730 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 24809 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 24820 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 17)
D: 24899 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 24911 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 24990 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 25080 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 25170 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 25182 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 25260 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25271 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 25284 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:5687795 on exchange 62859r
D: 25304 [EM]Handling via exchange: 62859r, Delegate: 0x20008ec0
I: 25317 [DMG]AccessControl: checking f=0 a=p s=0xFFFFFFFB00000000 t= c=0x0000_003E e=0 p=o
I: 25334 [DMG]AccessControl: implicit admin (PASE)
D: 25344 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
I: 25360 [ZCL]OpCreds: Certificate Chain request received for PAI
D: 25372 [DMG]ICR moving to [AddingComm]
D: 25380 [DMG]ICR moving to [AddedComma]
D: 25388 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 25405 [IN]Prepared secure message 0x2002dad8 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 62859r with MessageCounter:15114284.
I: 25434 [IN]Sending encrypted msg 0x2002dad8 with MessageCounter:15114284 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000006359 msec
D: 25460 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 25473 [DMG]ICR moving to [CommandSen]
D: 25481 [DMG]ICR moving to [AwaitingDe]
E: 25489 [DL]Long dispatch time: 218 ms, for event type 16388
D: 25529 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25540 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 25619 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25630 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 25709 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25721 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 25733 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 25799 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25811 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 25889 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25900 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 25979 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 25991 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26069 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26081 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 26094 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26159 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26170 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26249 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26260 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26339 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26350 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26429 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26441 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 26453 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26519 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26531 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26609 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26620 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26699 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26710 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26789 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26801 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 26814 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26879 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26890 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 26969 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 26980 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27059 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27070 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27149 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27194 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 27207 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27284 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27295 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27374 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27385 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27464 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27476 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27554 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27566 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 27578 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27644 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27655 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27734 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27745 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27824 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27835 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 27914 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 27926 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 27938 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 28004 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28016 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 28094 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28105 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 17)
D: 28185 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28196 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 28275 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 28365 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 28455 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 28467 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
I: 28481 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:5687796 on exchange 62860r
D: 28501 [EM]Handling via exchange: 62860r, Delegate: 0x20008ec0
I: 28514 [DMG]AccessControl: checking f=0 a=p s=0xFFFFFFFB00000000 t= c=0x0000_003E e=0 p=o
I: 28531 [DMG]AccessControl: implicit admin (PASE)
D: 28540 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0002
I: 28557 [ZCL]OpCreds: Certificate Chain request received for DAC
D: 28569 [DMG]ICR moving to [AddingComm]
D: 28577 [DMG]ICR moving to [AddedComma]
D: 28585 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 28602 [IN]Prepared secure message 0x2002dad8 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 62860r with MessageCounter:15114285.
I: 28631 [IN]Sending encrypted msg 0x2002dad8 with MessageCounter:15114285 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000006FD7 msec
D: 28657 [DMG]ICR moving to [CommandSen]
D: 28665 [DMG]ICR moving to [AwaitingDe]
E: 28673 [DL]Long dispatch time: 219 ms, for event type 16388
D: 28684 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28696 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 28769 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28780 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 28859 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28870 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 28950 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 28961 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 28973 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29039 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29050 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29129 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29141 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29219 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29230 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29309 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29321 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 29334 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29399 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29410 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29489 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29501 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29579 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29591 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29670 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29681 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 29694 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29759 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29770 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29850 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29861 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 29939 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 29950 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30029 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30041 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 30054 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30119 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30131 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30254 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30266 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30344 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30356 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30435 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30446 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 30459 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30524 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30535 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30614 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30625 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30704 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30715 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30795 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30806 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 30818 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30884 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30896 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 30974 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 30986 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 31064 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31076 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 31155 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31166 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 31178 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 31244 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31255 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 31334 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31346 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 31424 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31435 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 31515 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31526 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 31538 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 10)
D: 31605 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31616 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 31695 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 31785 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 31797 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 31875 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 31886 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 31965 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 32055 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 32068 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:5687797 on exchange 62861r
D: 32089 [EM]Handling via exchange: 62861r, Delegate: 0x20008ec0
I: 32101 [DMG]AccessControl: checking f=0 a=p s=0xFFFFFFFB00000000 t= c=0x0000_003E e=0 p=o
I: 32118 [DMG]AccessControl: implicit admin (PASE)
D: 32128 [DMG]Received command for Endpoint=0 Cluster=0x0000_003E Command=0x0000_0000
I: 32144 [ZCL]OpCreds: received an AttestationRequest
D: 32184 [DMG]ICR moving to [AddingComm]
D: 32192 [DMG]ICR moving to [AddedComma]
D: 32200 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 32217 [IN]Prepared secure message 0x2002dad8 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 62861r with MessageCounter:15114286.
I: 32247 [IN]Sending encrypted msg 0x2002dad8 with MessageCounter:15114286 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000007DF6 msec
D: 32273 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32286 [DMG]ICR moving to [CommandSen]
D: 32294 [DMG]ICR moving to [AwaitingDe]
E: 32301 [DL]Long dispatch time: 247 ms, for event type 16388
D: 32369 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32381 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32459 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32471 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32549 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32561 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32640 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32651 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 32663 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32729 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32741 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32819 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32831 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 32909 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 32920 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33000 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33011 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 33024 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33134 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33145 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33224 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33236 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33314 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33325 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33405 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33416 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 33428 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33494 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33506 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33584 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33596 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33674 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33686 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33765 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33776 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 33789 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33854 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33866 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 33944 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 33956 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34034 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34045 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34125 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34136 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 34148 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34214 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34226 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34304 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34316 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34394 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34405 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34485 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34496 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 34508 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34574 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34586 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34664 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34676 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34754 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34765 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34845 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34856 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 34868 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 34934 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 34946 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35024 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35036 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35114 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35125 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35205 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35216 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 35228 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35294 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35305 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35384 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35395 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35474 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35485 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35565 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35576 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 35588 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35654 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35665 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35744 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35755 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35834 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35845 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 35925 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 35936 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 35949 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 10)
D: 36015 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 36026 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 36150 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 36240 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
D: 36252 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 3)
D: 36330 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
D: 36341 [DL]Write request received for CHIPoBLE RX (ConnId 0x00)
I: 36354 [EM]Received message of type 0x8 with protocolId (0, 1) and MessageCounter:5687798 on exchange 62862r
D: 36375 [EM]Handling via exchange: 62862r, Delegate: 0x20008ec0
I: 36388 [DMG]AccessControl: checking f=0 a=p s=0xFFFFFFFB00000000 t= c=0x0000_0030 e=0 p=o
I: 36405 [DMG]AccessControl: implicit admin (PASE)
D: 36415 [DMG]Received command for Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0000
D: 36431 [DMG]ICR moving to [AddingComm]
D: 36439 [DMG]ICR moving to [AddedComma]
D: 36447 [DMG]Decreasing reference count for CommandHandler, remaining 0
I: 36461 [IN]Prepared secure message 0x2002dad8 to 0xFFFFFFFB00000000 (0)  of type 0x9 and protocolId (0, 1) on exchange 62862r with MessageCounter:15114287.
I: 36490 [IN]Sending encrypted msg 0x2002dad8 with MessageCounter:15114287 to 0xFFFFFFFB00000000 (0) at monotonic time: 0000000000008E8A msec
D: 36516 [DL]Sending notification for CHIPoBLE TX (ConnId 00, len 20)
D: 36530 [DMG]ICR moving to [CommandSen]
D: 36537 [DMG]ICR moving to [AwaitingDe]
E: 36545 [DL]Long dispatch time: 204 ms, for event type 16388
E: 36557 [SVR]Failsafe timer expired
E: 36564 [SVR]Commissioning failed (attempt 1): Error CHIP:0x00000032
D: 36576 [IN]Clearing BLE pending packets.
I: 36585 [BLE]Releasing end point&apos;s BLE connection back to application.
I: 36598 [DL]Closing BLE GATT connection (ConnId 00)
D: 36613 [SC]Assigned local session key ID 2
D: 36621 [SC]Waiting for PBKDF param request
D: 36630 [DL]CHIPoBLE advertising set to on
I: 36638 [DIS]Updating services using commissioning mode 1
D: 36649 [DL]Using Thread extended MAC for hostname.
D: 36660 [DL]Using Thread extended MAC for hostname.
I: 36671 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15
E: 36689 [DIS]Failed to advertise commissionable node: Error CHIP:0x00000003
D: 36690 [DIS]Scheduling discovery timeout in 900s
E: 36690 [DIS]Failed to finalize service update: Error CHIP:0x0000001C
I: 36691 [ZCL]OpCreds: Call to FailSafeCleanup
D: 36691 [ZCL]Failsafe timeout, tell platform driver to revert network credentials.
E: 36692 [DL]Long dispatch time: 135 ms, for event type 32785
D: 36692 [DL]Notification for CHIPoBLE TX done (ConnId 0x00)
E: 36692 [BLE]no endpoint for BLE sent data ack
I: 36694 [DL]BLE GAP connection terminated (reason 0x16)
I: 36703 [DL]Current number of connections: 0/1
I: 36717 [DL]CHIPoBLE advertising started
I: 66724 [DL]CHIPoBLE advertising mode changed to slow
</pre>
In the Open Thread Border Router Web Interface, I can see only the router that is present on the Open Thread Network. It means that my Matter device failed to be commissioned to the network. Could you help me please to solve the Verification Attestation Information error ?
