ble disconnects Immediately after connection.
Hi All,
I'm using nrf Connect SDK v1.7.0 with Vs Code
So here I can see in the debug prints that Bluetooth device is able to get connection successfull callback and Immediately I get disconnection callback with this error reason.
BT_HCI_ERR_CONN_FAIL_TO_ESTAB           0x3e
I wish to know, what does it mean and how to prevent it?
  • What sample project is your central application based on?
    I've picked an example from Nordic webinar from YouTube, PFA
    an you show us how you clear the BT conn variables upon a disconnect?
    Below function is called inside disconnect callback.
    void ClearBleConn(void)
      if(default_conn)
          { /* Connection instance for central role */
            bt_conn_unref(default_conn);
            default_conn = NULL;
    I assume the CONFIG_BT_MAX_CONN is set to some value by default in your application either way?
    It was two by default and I made it 5 now, still the problem persists.
    Regards
    Viswa N M
  • Hmm, okay. What environment are you testing your application in? Are the devices located right next to each other? You can try increasing the TX power (example here) on your peripheral devices.
    Can you share some more details on what samples exactly the central/peripherals are based on?
    A sniffer trace of the connection might give us a better idea of what the problem (on air) is.
    Simon
    Did you solve this in the end?
    I am struggling with a similar issue. My central can't re-connect to my peripheral with the same error. I have reported it here :  BT_HCI_ERR_CONN_FAIL_TO_ESTAB every time on re-connection
    Would you have any ideas? Thanks.
  • Related
