51822 bootloader setting
    recently I'm building dfu function on my board, using nrf51822 qfaa and softdevice s110.
Here is the situation, I get two 51822 modules:
-one is Raytac MDBT40, using nRF51822 QFAAH00, called A
-the other I'm not sure, using nRF51822 QFAAH10, called B
From Nordic document, the x in the build code is 0..9 for production release.
At first, I run dfu_dual_bank_ble sample code on 51DK. Here is the original bootloader address:
I got B module earlier than A. I change to custom board and change address:
It works well on B.
Then, I repeat the steps on A module. The same bootloader can be loaded to A, but it can't work, even advertising.
I've checked if I only load s110 and application, it works.
Is there something I misunderstood or miss checking?
Thank you very much.
  • I forgot that the keil projects for the bootloader had this. If it works, that is completely fine. What the different command does is quite self explaining. The --reset flag will reset the device when the programming is complete. So if you don't have the --reset flag, you will need to reset the device manually, either by power cycling it, or by using the command nrfjprog --reset.
    The --family NRF51 just tells the programmer that it is an nRF51 chip. If you don't specify it, the programmer will check a register that says what chip it is.
    Edvin
