nRF Connect SDK DFU over BLE fails with bad State: Remote error: Unknown(1)?
I am having trouble setting up DFU over BLE in nRF Connect SDK. I am using NCS 1.9.1.
I have followed these instructions with my own project on both the nrf52840 devkit and a custom board: https://devzone.nordicsemi.com/guides/nrf-connect-sdk-guides/b/software/posts/ncs-dfu
Side note: The DFU UUID in this guide did not work for me: I used the UUID that is shown in the iOS nRF Connect Device Manager App when no devices are found:
BT_UUID_128_ENCODE(0x8d53dc1d, 0x1db7, 0x4cd3, 0x868b, 0x8a527460aa84)
With this UUID, I was able to connect with the device manager. However, when I start the image upgrade with "erase application settings" enabled and mode "test and confirm", I get this message: "State: Remote error: Unknown(1)". If I try again after that, the state says "UPLOADING..." until it times out. (restarting the app recreates the unknown(1) error).
When I try uploading the same firmware image to the same device via the nRF Connect for iOS app, I get more details. The log looks good until I get a message "Length of data to send exceeds MTU". This seems straightforward, but I am failing to get it resolved.
Is 252 (as stated in the above guide) the correct MTU length? If not, how do I change it? I've tried messing around with several of the CONFIG_ values, but it doesn't appear to update because I see in the nRF Connect iOS app the MTU is the default 23.
Any help appreciated, thank you!
EDIT:
for anyone else who comes across this problem:
- "Length of data to send exceeds MTU" is an expected message and doesn't indicate a problem
- The issue ended up being that I had set CONFIG_HEAP_MEM_POOL_SIZE=256, which is too small for the DFU to allocate the buffer needed to write to flash. OK values I tested are 4096 and 0(instead of allocating from heap, a static buffer is used). Optimal size is probably sizeof(struct flash_img_context)
