nRF52840 random disconnection
Good morning,
We have a new equipment based on the nRF52840 and s140.
                Just now, a new problem has appeared and it is very strange, as it seems to be a ‘random’ error:
                We have already assembled tens of equipment, and most of them are perfectly working with any smartphone (using both your ‘nRF Connect’ application or our own application).
                But, we have a few smartphones that show a strange behavior: they are able to perfectly connect to some of our nRF52840-based equipment, and in a few ones, they are able to connect but they get disconnected after a few seconds. Same equipment is connecting to other smartphones without problems (without disconnecting).
                This is (step by step) what it is happening a few times:
  • Equipment (nRF52840) is advertising.
  • Smartphone stablish connection with equipment using pin number
  • First time, the connection is perfectly working.
  • If smartphone is disconnected and connected back again with same equipment (Already bonded), then connection is stablished but smartphone disconnects after 30”, approximately. Same behavior is happening with both nRF connect application and our own application. Looking at log in nRF application we see: ‘Connection terminated by peer (status 19)’or ‘GATT_CONN_TIMEOUT’
Why is it happening?
Which is the reason?
How can we solve this?
 Could you help us? (For your information, we have set MIN_CONN_INTERVAL to 7.5m and MAX_CONN_INTERVAL to 100ms)
Thank you
  • Thank you so much.
    I will try to catch that trace with sniffer.
    In what regards legacy bonding: which is the parameter I have to set instead of LESC? (Some messages above, I specified how bonding is setup)
    Dani
  • Hi Dani,
    If you want to disable LESC you can set SEC_PARAM_LESC = 0 in peer_manager_init().
    And to make it easier for the sniffer set :
    sec_param.io_caps      = BLE_GAP_IO_CAPS_NONE;
    Please keep other settings as-is.
  • Furthermore, in what regards my application: We are doing write and read requests and also indications.
    Most of the services that are implemented have two characteristics: one for transmission and one for reception. All of them are similarly implemented.
    I have just send the implementation of one of this services to Brian: he will sent it to you.
    Let me know your assessment.
    Dani.
  • Hi Dani,
    I don't see anything suspicious from your service file. It's almost identical to our NUS (UART) service.
    Please try to capture the sniffer trace (with MITM setting remove, you can use BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM instead).
  • First of all I have set SEC_PARAM_LESC = 0 with no bonding, I have tried to connect to nRFConnect Application. After discovering services, my device should constantly send information to smartphone, and now, it is not receiving nothing.
    Please, look at attached log output from nRFConnect tool
    nRF Connect, 2022-05-18
    A-SMART 2 (F9:4F:3C:FA:8E:43)
    V	14:35:20.700	Connecting to F9:4F:3C:FA:8E:43...
    D	14:35:20.700	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	14:35:22.804	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
    D	14:35:22.808	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	14:35:22.808	Connected to F9:4F:3C:FA:8E:43
    D	14:35:22.833	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	14:35:22.854	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_CONSENT (3)
    I	14:35:23.460	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	14:35:24.040	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
    D	14:35:26.169	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
    I	14:35:26.169	Device bonded
    D	14:35:26.179	wait(1600ms)
    V	14:35:27.793	Discovering services...
    D	14:35:27.793	gatt.discoverServices()
    D	14:35:27.805	[Callback] Services discovered with status: 0
    I	14:35:27.805	Services discovered
    V	14:35:27.845	Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    - Central Address Resolution [R] (0x2AA6)
    Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    Unknown Service (00001000-0000-1000-8000-00805f9b34fb)
    - Unknown Characteristic [R W] (00001001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00001002-1212-efde-1523-785feabcd123)
    Unknown Service (00002000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00002001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00002002-1212-efde-1523-785feabcd123)
    Unknown Service (00003000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00003001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00003002-1212-efde-1523-785feabcd123)
    Unknown Service (00004000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00004001-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00004002-1212-efde-1523-785feabcd123)
    Unknown Service (00005000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [R W] (00005001-1212-efde-1523-785feabcd123)
    Unknown Service (00006000-1212-efde-1523-785feabcd123)
    - Unknown Characteristic [N R] (00006002-1212-efde-1523-785feabcd123)
    Secure DFU Service (0xFE59)
    - Secure Buttonless DFU [I W] (8ec90004-f315-4f60-9fb8-838830daea50)
    D	14:35:27.845	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	14:35:27.848	gatt.setCharacteristicNotification(00001002-1212-efde-1523-785feabcd123, true)
    D	14:35:27.849	gatt.setCharacteristicNotification(00002002-1212-efde-1523-785feabcd123, true)
    D	14:35:27.850	gatt.setCharacteristicNotification(00003002-1212-efde-1523-785feabcd123, true)
    D	14:35:27.852	gatt.setCharacteristicNotification(00004002-1212-efde-1523-785feabcd123, true)
    D	14:35:27.853	gatt.setCharacteristicNotification(00006002-1212-efde-1523-785feabcd123, true)
    I have also saved the sniffer trace following next procedure (Attached):Android_Pairing_without_bonding_18_05_22.pcapng
    - Device advertising
    - Device connected using nRFConnect (with Wireshark all frames appear as empty, and as I have said, looking at nRFConnect, no services information is given)
    - Device is disconnected from nRFConnect and it starts advertising again
    Hope it helps
    Dani
