IV Index and LPN devices that leave mesh
We're developing an LPN product that will leave the mesh and stay off the mesh for up to 3 days (possibly more). When it rejoins the mesh, the central server/gateway could have some resets in between.
Is there a chance the IV index will prevent the nodes from communicating once reconnected to the mesh?
I am looking at this thread and wondering how much is safe to change:
https://devzone.nordicsemi.com/f/nordic-q-a/80558/bt-mesh-iv-update-parameters-timers
Thank you
    I'm really hoping there's a clear why to validate that the secure beacon update is actually being sent.
    I called for a client:
        status = net_state_iv_index_set(30, p_prov_data->flags.iv_update);
        //status = net_state_iv_index_set(p_prov_data->iv_index, p_prov_data->flags.iv_update);
    And left it at default for the server.
    At no point was the server able to communicate to the client, even when trying to set up publishing and subscription in nRF Mesh. (Updating TTL fails)
    I'm in a situation now where I'm sending out a replacement unit to a client and I'm realizing that there's no real gaurentee that the two will talk now.
    Does the server send out the secure beacon by default or is it only enabled by the setting in the app?
    Alex Ross said:
    I am a little hesitant to switch to nRF Connect SDK because of the project development timeline.
    I have no issues understanding that rationale, especially if far in devlopment (and with devices out there already.) We are keeping some track of key values for the new SDK (memory requirements, power usage, etc.) although I do not currently have LPN power usage numbers at hand.
    Alex Ross said:
    I assume the phone app compatibility hasn't changed?
    Phone app is unchanged, as is the mesh specification, mesh models, etc. In fact nRF Connect SDK has slighlty better model coverage (and is the place where all new functionality will be developed.)
    Alex Ross said:
    Do you have any suggestions on how to create a scenario where the IV index is bad so I can see what's going wrong?
    For testing purposes you could lift the restriction of 192 hours between IV Index Updates, or maybe even hard code some IV Index "jump" to a new value, for instance set back the IVI for a node to emulate it being "behind".
    I am yet to hear back from the team, but will check with them and (hopefully) get back to you tomorrow.
    Please note Thursday is public holiday here in Norway, and many take Friday off as well for the long weekend.
    Terje
    I noticed you had a second set of questions.
    The beacon is a collective effort of the network, where at any one place in the network topology one is expected to get, on average, one beacon every ten seconds. I.e. with two nodes, each node would send a beacon every 20 seconds, for a 10 second average. All nodes participate in this, as mandated by spec, and there is no setting controlling it.
    It must be provisioned into the network, and as such "synced" with the IVI, yes. Does the system have provisioning support at the customer location, or is it "pre-provisioned" (so that provisioning is out-of-scope for the customer?)
    You will likely need some action from the application in order to recover the IVI. As mentioned in my previous reply, I will get back to you, hopefully before week-end (i.e. tomorrow.)
    Terje
    I got some feedback from our mesh team.
    tesc said:
    If the LPN is not in a friendship, it will try to initiate one. If there has been IV Index updates, this will fail repeatedly, at which point the LPN should check Secure Network Beacons to see if an IV Index Recovery is needed. Some action may be needed from the application.
    The IV Index Recovery will be triggered if receiving a secure beacon with an IV Index higher than the current one. Beacons are sent through the network every 10 seconds (on average), which means there is some waiting time, and the node must be in a scanning state in order to receive the beacon. The recovery procedure itself is instantaneous (it updates a few variables in memory.)
    It does however depend on a couple of prerequisites: It can only happen after a timeout of 192 hours, and only if the node is not in the mimddle of an IVI Update. In order for the LPN to know that 192 hours has passed, it must have been on for that amount of time since the timer was last reset. Timer status is stored periodically, so the total "on time" might be divided in several sessions.
    tesc said:
    Similarly if the LPN is in a friendship, but has not polled through an IV Index Update, some action may be needed from the application.
    Staying in friendship beyond one IV Index update is not possible, since the maximum PollTimeout corresponds to 96 hours. In other words: In order to keep the friendship, one must have one successful poll at least once every IV Index. I did the calculations wrong when checking max PollTimeout for that previous answer, and found an erroneous max PollTimout that was longer than 96 hours. Correct number is 96 hours max.
    Terje
  • So I actually have some units now having the issue I've seen before.
    Essentially I have a switch that when triggered, the client sends a notification over mesh to the server. This works, I can see the message come in on the server. However, sending messages down to the client are being ignored.
    How can I be sure I'm sending out a secure beacon? Shouldn't the fact that I can receive a message from the client mean that the IV indexes are good?
    The client is sealed and potted so there's not a lot of physical debugging I can do I'm afraid. (I really need to make a DFU backdoor)
