IV Index and LPN devices that leave mesh
We're developing an LPN product that will leave the mesh and stay off the mesh for up to 3 days (possibly more). When it rejoins the mesh, the central server/gateway could have some resets in between.
Is there a chance the IV index will prevent the nodes from communicating once reconnected to the mesh?
I am looking at this thread and wondering how much is safe to change:
https://devzone.nordicsemi.com/f/nordic-q-a/80558/bt-mesh-iv-update-parameters-timers
Thank you
    Alex Ross said:
    I overrode a client's IV index to be 42 (within). This caused by server to update to IV index 42 as well
    This would be expected behavior, and is explained by client sharing secure beacon which server receives, server noticing it is behind and therefore performing IVI Recovery.
    Alex Ross said:
    however, even the client can't send a message to the server anymore
    Where does it fail, is it in the sending, or that the server never seem to receive anything? What is the sequence number and IV Index bits of those packets?
    Do you have minimal examples for reproducing this on a DK?
    Based on your descriptions, it sounds like for instance sequence number not being reset could be an explanation, or if the replay protection is not working properly (not reset) when doing IVI Recovery. From what I recall, IV Index is not fully stored neither in packets sent nor in replay list, rather only the least significant bit is used (since the node knows what IV Indexes are possible for the current IV Index and IV Index update state.) If there's a bug somewhere, that sounds like a possible place.
    Alex Ross said:
    Does the nRF Mesh app for iOS have it's own IV index?
    I do not quite understand what youi mean by that. The nRF Mesh apps (both Android and iOS) follows the Bluetooth mesh specification, which means they should also be able to participate in IV Index Update and IV Index Recovery. I will double check if the phone apps do indeed have IVI Recovery functionality.
    You mention in a separate thread (nRF Mesh App stops workings after IV update) that you think this is a sequence number issue. I agree. Can you share the logs (or other information)I from your testing on this?
    Terje
    It's worth noting that we took the advice from another thread and set NETWORK_SEQNUM_FLASH_BLOCK_SIZE from 8192 and changed it to 512.
    I added in the sequence number/IV index
    I'll repeat this with units with a fresh IV index and see if there's any hints there.
    Let me know if there's anywhere I could add debug messages to better see the error.
    Right now the error coming back is timeout so it might be that the server is rejecting messages from the phone
    Here's the nRF Mesh app for Android log while doing it:
    I/MSHandlerLifeCycle: isMultiSplitHandlerRequested: windowingMode=1 isFullscreen=true isPopOver=false isHidden=false skipActivityType=false isHandlerType=true this: DecorView@955c001[NodeConfigurationActivity]
    V/MeshTransport: Src address: 0001
    V/MeshTransport: Dst address: 004B
    V/MeshTransport: Key:[Display removed by AR for public posting]
    V/MeshTransport: akf: 0
    V/MeshTransport: aid: 0
    V/MeshTransport: aszmic: 0
    V/MeshTransport: Sequence number: 19
    V/MeshTransport: Access message opcode: 8049
    V/MeshTransport: Access message parameters:
    V/AccessLayer: Created Access PDU 8049
    V/UpperTransportLayer: Device nonce: 02000000130001004B00000000
    V/UpperTransportLayer: Encrypted upper transport pdu: AA09B1B7C634
    V/LowerTransportLayer: Unsegmented Lower transport access PDU 00AA09B1B7C634
    V/NetworkLayer: Encryption key: [Display removed by AR for public posting]
    V/NetworkLayer: Privacy key: [Display removed by AR for public posting]
    V/NetworkLayer: Sequence Number: 000013
    V/NetworkLayer: Encrypted Network payload: [Display removed by AR for public posting]
    I/MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@1dec857[NodeConfigurationActivity]
    D/OpenGLRenderer: setSurface called with nullptr
    D/OpenGLRenderer: setSurface() destroyed EGLSurface
    D/OpenGLRenderer: destroyEglSurface
    D/OpenGLRenderer: endAllActiveAnimators on 0x79f382ec00 (RippleDrawable) with handle 0x7a4e2b50a0
    I/ViewRootImpl@15e3712[NodeConfigurationActivity]: DirectWriting, detachedFromWindow, clear editTexts
    I/ViewRootImpl@15e3712[NodeConfigurationActivity]: dispatchDetachedFromWindow
    D/InputTransport: Input channel destroyed: 'aed7941', fd=105
    I/BleManager: Data written to 00002add-0000-1000-8000-00805f9b34fb, value: (0x) 00-73-8C-AA-49-95-6B-9B-AE-6B-82-55-D6-E9-B0-62-9F-61-19-E9-CD
    V/MeshManagerApi: MeshNetwork pdu sent: 0x00738CAA49956B9B[Display removed by AR for public posting]
    I/ViewRootImpl@eb2c565[NodeConfigurationActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
    D/InputMethodManager: startInputInner - Id : 0
    I/InputMethodManager: startInputInner - mService.startInputOrWindowGainedFocus
    I/Dialog: mIsDeviceDefault = false, mIsSamsungBasicInteraction = false, isMetaDataInActivity = false
    I/DecorView: [INFO] isPopOver=false, config=false
    I/DecorView: updateCaptionType >> DecorView@fa86e1a[], isFloating=true, isApplication=true, hasWindowControllerCallback=false, hasWindowDecorCaption=false
    D/DecorView: setCaptionType = 0, this = DecorView@fa86e1a[]
    D/ScrollView: initGoToTop
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: setView = com.android.internal.policy.DecorView@fa86e1a TM=true
    I/MSHandlerLifeCycle: isMultiSplitHandlerRequested: ignored. pkg=no.nordicsemi.android.nrfmeshprovisioner isActivity=false callers=com.android.internal.policy.DecorView.setVisibility:4294 android.app.Dialog.show:445 androidx.fragment.app.DialogFragment.onStart:687 androidx.fragment.app.Fragment.performStart:3021 androidx.fragment.app.FragmentStateManager.start:589
    I/MSHandlerLifeCycle: removeMultiSplitHandler: no exist. decor=DecorView@fa86e1a[NodeConfigurationActivity]
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: Relayout returned: old=(0,36,2000,1128) new=(550,436,1449,727) req=(899,291)0 dur=19 res=0x7 s={true 523798609920} ch=true fn=-1
    D/OpenGLRenderer: eglCreateWindowSurface
    D/ScrollView:  onsize change changed
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: [DP] dp(1) 1 android.view.ViewRootImpl.reportNextDraw:11374 android.view.ViewRootImpl.performTraversals:4167 android.view.ViewRootImpl.doTraversal:2893
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: [DP] pdf(0) 1 android.view.ViewRootImpl.lambda$addFrameCompleteCallbackIfNeeded$3$ViewRootImpl:4969 android.view.ViewRootImpl$$ExternalSyntheticLambda16.run:6 android.os.Handler.handleCallback:938
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: [DP] rdf()
    D/ViewRootImpl@9676658[NodeConfigurationActivity]: reportDrawFinished (fn: -1)
    I/ViewRootImpl@eb2c565[NodeConfigurationActivity]: MSG_WINDOW_FOCUS_CHANGED 0 1
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: MSG_WINDOW_FOCUS_CHANGED 1 1
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: ViewPostIme pointer 0
    I/MSHandlerLifeCycle: isMultiSplitHandlerRequested: ignored. pkg=no.nordicsemi.android.nrfmeshprovisioner isActivity=false callers=com.android.internal.policy.DecorView.hasMultiSplitHandlerInNonFreeformMode:890 com.android.internal.policy.DecorView.dispatchTouchEvent:930 android.view.View.dispatchPointerEvent:15335 android.view.ViewRootImpl$ViewPostImeInputStage.processPointerEvent:7794 android.view.ViewRootImpl$ViewPostImeInputStage.onProcess:7567
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: ViewPostIme pointer 1
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: ViewPostIme key 0
    I/ViewRootImpl@9676658[NodeConfigurationActivity]: ViewPostIme key 1
    Here's the server/proxy receiving an 8049 opcode to node 0x0066 (I don't see it here)
    1680.8049 server_proxy.txt
