lte_ble_gateway on Thingy 91 (v1.9.1)
trying to get v1.9.1 lte_ble_gateway working on Thingy 91.
Using Thingy 2020:23 1.4.0, which works all good with zip thingy91_fw_2022-02-17_ec486dab (tracker, nrf cloud, mfw_nrf9160_1.3.1).
Using VS to build merged.hex for hci_lpuart (thingy91_nrf52840) and lte_ble_gateway (thingy91_nrf9160_ns),
and flash using 10-pin external debug probe onto nRF52 and nRF91 respectively on Thingy 91.
Not sure if this is the correct way to re-purpose lte_ble_gateway for Thingy 91,
probably not since the following did not produce flashing led or a connection to nrf cloud.
nrfjprog -f nRF52 --eraseall
nrfjprog -f nRF52 --program hci_lpuart-build_2-merged.hex --verify --reset --log
nrfjprog -f nRF91 --eraseall
nrfjprog -f nRF91 --program lte_ble_gateway-build_2-merged.hex --verify --reset --log
(build_1 is for nRF9160-DK which works fine to nrf cloud, build_2 is Thingy 91)(thing-91_build_2-log-1.txt)
Then going back to:
thingy91_nrf52_connectivity_bridge_2022-02-17_ec486dab.hex
thingy91_asset_tracker_v2_ltem_2022-02-17_ec486dab.hex
to use MCUboot,
using VS build_2 of app_signed for nrf52 and nrf91.
Then starting with lte_ble_gateway then hci_lpuart (because usb is lost to Programmer after flashing nrf52).
And this produced no results for led and nrf cloud, just like merged.hex.
I came across this post,
https://devzone.nordicsemi.com/f/nordic-q-a/52689/nrf9160-lte-sensor-gateway-on-thingy-91/225659#225659
which had two hex's to try, but built for an earlier modem, has Thingy 91 resetting without a stable connection.
nrfjprog -f nRF52 --program hci_uart_with_usb_uart_bridge_nrf52840_pca20035.hex --verify --reset --log
nrfjprog -f nRF91 --program lte_ble_gateway_nrf9160_pca20035ns.hex --verify --reset --log
In that ticket, the nrf52 hex was done by merging hci_uart sample with usb_uart_bridge (v1.3.0)
For v1.9.1, connectivity_bridge is now used instead of usb_uart_bridge.
This directory no longer exists in v1.9.1 nrf\samples\usb\usb_uart_bridge\src\main.c.
The solution here might be merging connectivity_bridge with hci_lpuart,
or if this will even get me to the appropriate solution for a lte_ble_gateway on Thingy 91?
Maybe I missed a recent solution somewhere on devzone, but not seeing anything like this on my searches.
thank-you,
4861.thing-91_build_2-log-1.txt
  • Should have tried RTT again after reinstalling v1.9.1, now receiving the log on VS.
    Usually there's an Application branch in VS where main.c is, but looks like you have to go to zephyr\samples,
    and not even nrf\samples, to get at the source.
    Since connectivity_bridge has a main.c in VS, went with that as the base for a merge,
    but a challenge right from prj.conf, and main.c was not any better ending in errors.
    (probably not ment to be)
    Looks like will have to define specific led's at each key step to know what's going on,
    if not able to get a standalone going by USB without a DK.
    thank-you,
    I've discussed the issue with Carl Richard, and there seems to be some documentation missing. He is trying to fix this.
    Combining hci_lpuart and connectivity_bridge isn't straight forward, and at this moment is not supported unfortunately.
  • that's fine, all good the way it is,
    thank-you,
