I'm trying to set up the DFU over the air mesh. Using the mesh SDK 5 and nRF SDK 7.1.0.
On nRF52832, I am using NRF SDK 7.1 and mesh SDK 5.
I appreciate your help in advance!
How did you change your ram start address? Can you show me a screenshot?
You should only need to send the application serial to one device. The other devices in the network with the same application ID and application key in their device page. But the device page must also be flashed on all other devices.
In the flash_placement.xml I have:
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
<MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
<ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
<ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
<ProgramSection alignment="4" load="Yes" name=".init" />
<ProgramSection alignment="4" load="Yes" name=".init_rodata" />
<ProgramSection alignment="4" load="Yes" name=".text" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ant_observers" inputsections="*(SORT(.sdh_ant_observers*))" address_symbol="__start_sdh_ant_observers" end_symbol="__stop_sdh_ant_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data" inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data" inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs" inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data" inputsections="*(.fs_data*)" runin=".fs_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_mesh_flash" inputsections="*(SORT(.nrf_mesh_flash.*))" address_symbol="__start_nrf_mesh_flash" end_symbol="__stop_nrf_mesh_flash"/>
<ProgramSection alignment="4" load="Yes" name=".dtors" />
<ProgramSection alignment="4" load="Yes" name=".ctors" />
<ProgramSection alignment="4" load="Yes" name=".rodata" />
<ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
<ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
<ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
<ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
</MemorySegment>
<MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
<ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
<ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_mesh_ram" inputsections="*(SORT(.nrf_mesh_ram.*))" address_symbol="__start_nrf_mesh_ram" end_symbol="__stop_nrf_mesh_ram"/>
<ProgramSection alignment="4" load="No" name=".fast_run" />
<ProgramSection alignment="4" load="No" name=".data_run" />
<ProgramSection alignment="4" load="No" name=".tdata_run" />
<ProgramSection alignment="4" load="No" name=".bss" />
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" address_symbol="__StackLimit" end_symbol="__StackTop"/>
<ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
</MemorySegment>
</Root>
And in the .emProject file I have the macro called RAM_START. So I changed it to 0x20002DF0.
When run again it stays on the old address
Does the application key means the public encryption key? where does the public and private keys which I generated and concated in the .json file stored?
Did you do any changes to the flash_placement file? If so, try to revert those changes.
I take it you are using SES, then.
Did you remember to select "Common" from the drop down menu before changing the start address?
D:\Nordic\mesh-nrfutil>nrfutil-mesh --verbose dfu serial -pkg dfu_test.zip -p COM3 -b 115200 --mesh Upgrading target on COM3 with DFU package D:\Nordic\mesh-nrfutil\dfu_test.zip. Flow control is disabled. Flushing com-port... Opened com-port Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 2416 Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing. 1: PC -> target: 0502aabbccdd target -> PC: 0582aabbccdd Got echo response Sending DFU init packet Sending ready packet 1: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 2: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 3: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 4: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 5: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 6: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 7: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 8: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 9: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e 10: PC -> target: 1378fdff040f77ea951b59000000010002000000 target -> PC: 0384788e Failed to upgrade target. Error is: Device returned an unknown status code (142) on a DFU state beacon packet. Possible causes: - bootloader, SoftDevice or application on target does not match the requirements in the DFU package. - baud rate or flow control is not the same as in the target bootloader. - target is not in DFU mode. If using the SDK examples, press Button 4 and RESET and release both to enter DFU mode. - if the error is ERROR_BUSY at the beginning of the DFU process,increase the value of PAGE_ERASE_TIME_MAX by few milliseconds. Closing serial port...
Does it stop after line 31, or did you just crop the output?
It may be caused by the keys. Did you generate your own keypair and use them in the devicepages?
